    Duet 2 Wifi - PT100 Daughter Board and Accelerometer
    • kuhnikuehnastundefined
      kuhnikuehnast
      Hi there,
      just got my Adafruit LIS3DH Accelerometer- now I am curious: I have a Duet 2 Wifi board and a PT100 Daughter Board connected- How do I connect de Accelerometer? Are the pins on "top" of the Daughter Board the same as the pins on the Duet 2 Board? (So I just plug everything in there the same way as I would plug it into the Duet Board?)
      hope you can help me! 🙂
      greetings kuhni
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @kuhnikuehnast
        @kuhnikuehnast pretty much yes. just use CS pins 3 and 4 rather than 1 and 2
          dc42 administrators @kuhnikuehnast
          @kuhnikuehnast said in Duet 2 Wifi - PT100 Daughter Board and Accelerometer:
          No, the CS3/CS4 pins on the bottom of the daughter board are routed to the positions above the CS1/CS2 pins. This is what lets you stack two daughter boards. So you can wire the accelerometer as if you were plugging the cable directly into the daughterboard connector on the Duet, but if you are plugging it on top of one daughter board then configure it to use CS3/4 instead of CS1/2.
