My "Temp 0" port always returns NA on my Duet 3 Mini 5+
I am trying to install a bed heater, and my Temp 0 is not reading, at all. I know it's not the thermistor, because I have tested it. I can move that same thermistor to Temp 1 and Temp 2 and it reads just fine, but I have one extruder thermistor in each of those ports already.
How can I fix this? My setup code for the bed heater is:
M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"
M950 H0 C"out0" T0
M307 H0 B0 S.50
M140 H0
M143 H0 S85I believe I am using Reprap 3.4, and I am using a Keenovo silicon heater pad, and here is the thermistor table:
https://www.keenovo.com/NTC-Thermistor-R-T-Table.pdfThank you for your help.
Here is my entire config file config(3).g
@tylersuard ``` here is mine from duet3 mini5
; Heaters + temperature sensors
;Bed
M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed T °C" ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"out2" T0 Q10 ; create bed heater output on bedheat and map it to sensor 0
M307 H0 R0.838 K0.331:0.000 D3.08 E1.35 S0.90 B0 ; PDI info for 8mm aluminium bed 700w Heater NTC 100K 3950
M143 H0 S130 ; set temperature limit for heater 0 to max C
;extruder
M308 S1 P"temp1" Y"pt1000" A"Extruder T °C" ; configure sensor 1 as PT1000
M950 H1 C"out1" T1 ; create nozzle heater output
M307 H1 R4.449 K0.705:0.000 D6.21 E1.35 S1.00 B0 V23.8 ; PDI
M570 H1 P10 T20 = heater fault timer sec ,T= temperature excursion deg C
M143 H1 S360 -
@tylersuard if you send M308 S0 from the DWC console, what is the response?
