LIS3DSH orientation on a Delta printer
Yes, I think you've annotated the photo correctly.
I have a board that looks very very similar to that, labelled LIS3DSH, advertised as a LIS3DSH, but actually I think it's a LIS3DH. The top of the chip on my board has clearly been abraded, presumably to try and conceal the markings.
I did some playing around with lighting and magnification and got as far as seeing the ghost of the markings, and the expected dot at the corner where the board has a dot. This photo has the markings a lot more visible than I can see with the naked eye:
I have now connected it, but the printer says it does not exists:
Error: M955: Accelerometer not found on specified port
This is how I have wired it:
I put them on IO_6 instead of 3, since it was occupied. Any ideas?
@Velvia this is probably caused by the CS wire picking up noise from other wires. Here are some suggestions:
- Drive CS from one of the spi.cs pins on the daughter board connector, if one of them is free, because they have greater drive strength.
- Change the cabling so that the CS wire does not run close to any other wires except for Vcc and Gnd.
@dc42 You were right. It works now. Split the CS cable and ran it far away from everything else. Was able to make measurements now. Thanks!
Are there shielded ribbon cables available?
@Velvia said in LIS3DSH orientation on a Delta printer:
Yes, however I have used unshielded ribbon cable successfully with these boards. If you use a 10-way ribbon cable and IDC connector to plug into the daughter board connector, then spi.cs1 can be used for CS because it is on the outside of the cable and the adjacent wire is ground.
I'm planning on using a shielded guitar wire for the cs wire when i wire mine up.
@dc42 I was able to get three readings, but now every time I try to get readings, it freezes the mainboard and it restarts.
@Velvia which firmware version are you using?
@dc42 3.4.1
@Phaedrux Thanks. I do that by running "M997 S0:1", right? Been a while
Upload this zip file to the system tab in DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
@Phaedrux Thank you for the help. Now I run as many times as I want, even with the Input Shaping plugin. No more crashes!
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
undefined tas referenced this topic
undefined Lee referenced this topic
