Z offset changes every print.
1.8k
    Karim
    Hey guys Voron 0.2 which is corexy with the bed Moving Up/Down. I have no Bed probe because the bed is only 120x120mm, So I do manual bed leveling. The problem I am having is the bed move up to the nozzle after every print so I have to Z babystepping every time I start printing,
    ; homez.g
    ; called to home the Z axis
    G91
    G1 H1 Z300 F800 ; move Z down until the endstop is triggered
    M400
    G1 H2 Z-5 F300 ;back away
    G1 H1 Z300 F60 ;second pass
    G4 S1 ; wait 1s
    G90
    G92 Z119.5 ; set Z position to axis minimum
    M400
    Start G-code
    M83 ; set extruder to relative mode
    G21 ; set units to mm
    T0 ; select tool 0
    G92 E0.0 ; reset extruder position
    M220 S100 ; reset speed multiplier
    G28 ; Home All Axes
    End G-code
    G91 ; relative positioning
    M83 ; extruder relative positioning
    G1 E-5.00 F1000 ; retract 5mm of filament
    G1 Z1.00 X20.0 Y20.0 F20000 ; short quick move to disengage from print
    G28 Z ; Home Z
    G90 ; absolute positioning
    G1 X310 Y310 F9000 ; move gantry close to home
    M104 S0 ; turn off hotend
    M140 S0 ; turn off heatbed
    M106 S0 ; shut off blower
    M84 ; turn off motors
      Post the homeall.g as well.
      @Karim said in Z offset changes every print.:
      If you're homing to Zmax, how did you determine this value?
      If the value is changing after a print, have you accounted for thermal expansion?
      undefined 1 Reply Last reply 26 Feb 2023, 04:12 Reply Quote 0
        Karim @Phaedrux
        @Phaedrux
        ; homeall.g
        ; called to home all axes
        M98 P"/sys/homez.g"
        M98 P"/sys/homex.g"
        M98 P"/sys/homey.g"
        G1 F9000 X60 Y60 Z60
        undefined 1 Reply Last reply 26 Feb 2023, 17:02 Reply Quote 0
          Karim @Karim
          @Karim how do I set z offset if the limit switch is at the bottom on the printer. As you can see I am homing at z max.
            Well you'd need to first identify the actual Z0 point by manually jogging the nozzle down to touch the bed, then send G92 Z0 to set Z0. Then send G1 H3 Z300 F600 to move the z axis to the zmax endstop and measure the distance. Then send M500 to save the updated M208 Z value to config-override.g. You'd need M501 at the end of config.g to load it again. In your homez.g you would want to remove your existing G92 Z119.5 entirely.
            undefined 1 Reply Last reply 26 Feb 2023, 20:30 Reply Quote 0
              Karim @Phaedrux
              @Phaedrux ok, I got 118.85 from nozzle to bed switch. Look like it’s working, so I noticed z babystepping not working. I have to disable axis limit (M564 S0) to go closer to nozzle.
                The babystepping won't let you go below the z minima value. You can change your M208 Z minima to be slightly negative like -0.5 to give you more baby stepping room.
                But if you have your Z0 set accurately there shouldn't be much need for baby stepping. If your first layer isn't accurate, there's still a problem with homing.
                undefined 1 Reply Last reply 26 Feb 2023, 22:57 Reply Quote 0
                  Karim @Phaedrux
                  @Phaedrux ok I let the nozzle top a piece of paper and then zero. But when I go to print the nozzle it a little too high. Do I change the Z0 to Z18.35
                  40 M208 X0 YO Z0 S1
                  41 M208 X120 Y120 Z120 SO
                  undefined 1 Reply Last reply 27 Feb 2023, 03:23 Reply Quote 0
                    Post your full config.g and override file and home z and slicer start gcode as they are now please.
                    Are you allowing for thermal expansion when you measure the z0 position?
                    undefined 1 Reply Last reply 26 Feb 2023, 23:10 Reply Quote 1
                      Karim @Phaedrux
                      @Phaedrux yes bed is at print temperature always.
                      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
                      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sat Feb 04 2023 22:42:11 GMT-0500 (Eastern Standard Time)
                      M550 P"Zero" ; set printer name
                      M669 K1 ; select CoreXY mode
                      M551 P"Zero" ; set password
                      M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M569 P0.1 S1 D2 ;F3 B2 Y5:3 ; physical drive 0.1 goes forwards
                      M569 P0.2 S1 D2 ;F3 B2 Y5:3 ; physical drive 0.2 goes forwards
                      M569 P0.0 S1 D3 V50 ; physical drive 0.0 goes forwards
                      M569 P0.3 S0 ;D2 ; physical drive 0.3 goes forwards
                      ;M915 X Y R0 F0
                      M584 X0.1 Y0.2 Z0.0 E0.3 ; set drive mapping
                      ;M592 D0.3 A0.01139 B0.00088 ;Set Non-Linear Extrusion
                      M92 X80 Y80 Z400.00 E413.52 ; set steps per mm
                      M566 X480 Y480 Z100 E1200 ; set maximum instantaneous speed changes (mm/min)
                      M203 X18000.00 Y18000.00 Z1800.00 E12000 ; set maximum speeds (mm/min)
                      M201 X10000 Y10000 Z200.00 E2500 ; set accelerations (mm/s^2)
                      M906 X650 Y650 Z300 E550 I40 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X120 Y120 Z120 S0 ; set axis maxima
                      M574 X2 S3 ;P"^io3.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^io3.in
                      M574 Y2 S3 ;P"^io5.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !^io5.in
                      M574 Z2 S1 P"^io6.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !^io6.in
                      ;M950 S1 C"out6" ; assign GPIO port 1 to out6 (Servo header), servo mode
                      M558 P0 ;P5 K0 C"^io1.in" R0.1 A5 H1 F600:400 T6000
                      ;G31 X60 Y60 Z0
                      M557 X0:120 Y0:120 P3
                      M671 X60:5:115 Y5:-10:115 P0.5 ; adjusting screws
                      M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
                      ;M307 H0 R0.616 K0.698:0.000 D3.15 E1.35 S1.00 B0 V24
                      M307 H0 R0.240 K0.131:0.000 D5.22 E1.35 S1.00 B0 V24
                      ;E3d Revo Voron)
                      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"out1" T1 ; create nozzle heater output on e0heat and map it to sensor 1
                      ;M307 H1 R4.091 K0.614:0.000 D1.92 E1.35 S1.00 B0 ; disable bang-bang mode for heater and set PWM limit
                      M307 H1 R4.167 K0.511:0.000 D2.11 E1.35 S1.00 B0 V23.7
                      M308 S2 P"temp2" Y"thermistor" A"Chamber" T100000
                      M308 S11 Y"drivers" A"Duet stepper drivers"
                      M950 F0 C"out3" ;Q250 ; create fan 0 on pin out3 and set its frequency
                      M106 P0 S0 H-1 C"Part" ; set fan 0 value. Thermostatic control is turned off
                      M950 F1 C"out5" ;Q500 ; create fan 1 on pin out5 and set its frequency
                      M106 P1 S1 H1 T45 C"Hotend" ; set fan 1 value. Thermostatic control is turned on
                      M950 F2 C"out4"
                      M106 P2 C"Filter" S0 H-1
                      ;M106 P2 C"Filter" S1 H0 T45
                      M563 P0 S"Main" D0 H1 F0 ; define tool 0
                      ;Neopixel
                      M150 X1 Q3000000 ; set LED type to NeoPixel and set SPI frequency to 3MHz
                      M150 U150 P100 ; set to red, half brightness,
                      ; Misc
                      ;M912 P0 S-4 ; MCU temperature calibration (yours will be different)
                      ;M572 D0 S0.075 ; Pressure Advance
                      M572 D0 S0.01 ; Pressure Advance
                      M592 D0 A0.015 B0.0012 L0.2 ; Non-linear extrusion
                      M376 H10 ; Fade mesh out compensation over 10mm Z
                      ; DAA tuning (you will need to change this for your slicer)
                      ;M593 F26.6 ; Cura 4.5 stock profile @ 40mm/s outer printing speed
                      ;M593 F42.5 ; PrusaSlicer @ 40mm/s outer perimeter
                      T0 ; select first tool
                      M280 P1 S1
                      M400
                      M280 P1 S-1
                      M98 P"/sys/lib/init.g"
                      M501
                      ; config-override.g file generated in response to M500 at 2023-02-26 17:50
                      ; Heater model parameters
                      ; Probed axis limits
                      M208 S0 Z118.17
                      ; Workplace coordinates
                      G10 L2 P1 X0.00 Y0.00 Z0.00
                      G10 L2 P2 X0.00 Y0.00 Z0.00
                      G10 L2 P3 X0.00 Y0.00 Z0.00
                      G10 L2 P4 X0.00 Y0.00 Z0.00
                      G10 L2 P5 X0.00 Y0.00 Z0.00
                      G10 L2 P6 X0.00 Y0.00 Z0.00
                      G10 L2 P7 X0.00 Y0.00 Z0.00
                      G10 L2 P8 X0.00 Y0.00 Z0.00
                      G10 L2 P9 X0.00 Y0.00 Z0.00
                      ; homez.g
                      G91
                      M400
                      G4 S1 ; wait 1s
                      G90
                      ;G92 Z119 ; set Z position to axis minimum
                      M400
                      ;Start G-code
                      T0 ; select tool 0
                      G28 ; Home All Axes
                      ;End G-code
                      ;G1 Z10.00 F20000 ; move Z-Axis 10mm away from part
                      G28 Z
                      G1 X120 Y3120 F9000 ; move gantry close to home
                        Phaedrux Moderator @Karim
                        If you need to baby step a little lower than it's letting you try M208 Z-1.
                        I don't see anything else in your config that is off. If you're still getting strange behaviour it could be mechanical, or thermal expansion.
                        After homing to Z max, and you send G90 G1 Z0 does the nozzle tip just touch the bed again?
                        undefined 1 Reply Last reply 27 Feb 2023, 14:13 Reply Quote 0
                          Karim @Phaedrux
                          @Phaedrux ok I change the Z value in M208 S0 Z118.17 in config-override.g and then restart to get the nozzle closer to the bed. I will test and report back the evening.
                          2 out of 12
