    Duet 3 mini 5+ wifi sensorless homing - Help
    1.8k
    • moth4017undefined
      moth4017 @Karim
      @Karim core XY valkyrie
      https://vkingprinter.com/project-valkyrie/
      Karimundefined 1 Reply Last reply Reply Quote 0
        dc42 administrators @moth4017
        @moth4017 said in Duet 3 mini 5+ wifi sensorless homing - Help:
        @dc42 3.5.0 beta2. The stall is after the small movement
        Try using M201.1 to reduce the acceleration during homing.
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • Karimundefined
          Karim @moth4017
          @moth4017 Very nice Printer, I never heard of it.
          • Karimundefined
            Karim @Karim
            @Karim This is my X Axis homing, it's not stalling now .I will let you know if this is working.
            ; homeX.g
            ; called to home the X axis
            M84 X
            M400						    ; Wait for current moves to finish
            M569 P0.1 D3 V10				; X -> B axis reduce V parameter so driver operates in stealthChop
            M569 P0.2 D3 V10				; Y -> A axis reduce V parameter so driver operates in stealthChop
            G4 P200						    ; Pause for 200ms to let StealthChop do some sh!t
            M17 X						    ; Energize Motors X Y
            M913 X20 Y20				    ; drop motor current to 20%
            M915 X S20 R0 F0 H200	        ; Sensitivity 9 [-64 --> 64], R - take no action, F - No filter, 200steps/sec
            M201.1 X250 Y250
            G4 P200						    ; wait 200ms
            G91					            ; set relative
            M400                            ; Wait for moves to finish
            G1 H2 X-1 F3000                 ; Move X axis back a little bit to clear stall flag if it's triggered
            G1 H1 X350 F3500			    ; [ First Pass ] move quickly to X axis endstop and stop there
            M400
            G90						        ; absolute positioning
            M913 X100 Y100				    ; return current to 100%
            M569 P0.1 D2					; Take driver out of StealthChop Mode
            M569 P0.2 D2					; Take driver out of StealthChop Mode
            M201.1 X650 Y650
            • moth4017undefined
              moth4017 @dc42
              I had a whole weekend without a stall for the first time ,
              Thanks everyone
              ;homey.g
              echo "Home Y"
              M569 P0.0										; check status in console Y
              M569 P0.1										; check status in console X
              G91												; Relative positioning
              M569 P0.0 S1 D3 V10                             ; set to stelth chop
              M569 P0.1 S1 D3 V10								; set to stelth chop
              M915 P0.0 S10 F0 R1 H200						; Configure y-Axis Stall Detection
              M915 P0.1 S10 F0 R1 H200                    	; Configure x-Axis Stall Detection
              M201.1 X300 Y300
              echo "stall detection setup"
              M17 X Y
              G1 P140
              G1 H2 X-1 F3000                               ; move a  little  for cal of sensorless homing / not stalled
              G1 H2 Y-1 F3000    							; move a  little  for cal of sensorless homing / not stalled
              echo "lower motor current"
              M913 X60 Y60									; Lower motor current %
              G4 P150
              M574 X1 Y2 S3                           		; Configure Z-Axis stall detection homing
              echo "Home Y"
              G1 H1 Y350 F6000
              G1 H2 X-10 Y10
              G1 H1 Y350 F6000                       			; Home Z-Axis actuators independently
              G1 Y150 F6000									; move to center of bed
              ;revert back
              echo "after revert  back"
              M915 P0.0 S128 F0 R1 H550						; Configure x-Axis Stall Detection
              M915 P0.1 S128 F0 R1 H550                    	; Configure x-Axis Stall Detection
              M913 X100  Y100                               	; Reset motor current
              M569 P0.0 S1 D2                                 ; reset motors back to spread cycle,
              M569 P0.1 S1 D2									; reset motors back to spread cycle,
              M201.1 X1000 Y1000
              • moth4017undefined
                moth4017
                @dc42 Mark as solved ... i think 🙂
                moth4017undefined 1 Reply Last reply Reply Quote 1
                  What did you end up changing to get it right?
                  • moth4017undefined
                    moth4017 @moth4017
                    @moth4017 i added the M201.1 x300 y300 just before the stall detection setup
                    • Karimundefined
                      Karim @moth4017
                      @moth4017 I don’t know what’s going on with my setup because mine works for a few days and the have homing problems and then works again, I guess it’s have to deal with it the way it’s working.
                      • moth4017undefined
                        moth4017 @Karim
                        @Karim post you config and homing files
