    duet 2 change wifi to ethernet
    • oolykundefined
      oolyk
      having no luck connecting to my duet 2 wifi, I bought duet ethernet module and just received it. the headers in the module are different pitch and number, so an adaptor is needed. is there an available adaptor? or if not what is the connection diagram from the module to the removed wifi soldering holes?
        T3P3Tony administrators @oolyk
        @oolyk the ethernet module plugs into headers on the Duet 2 board. those headers are not soldered on the wifi version as the wifi module overlaps them
        oolykundefined 1 Reply Last reply Reply Quote 0
        • oolykundefined
          oolyk @T3P3Tony
          @T3P3Tony thanks! so once the wifi module is removed, the ethernet can be soldered in the newly exposed headers?
          have you yourself done it?
            @oolyk in production we use low profile headers to plug the ethernet module into
            https://www.toby.co.uk/board-to-board-pcb-connectors/254mm-sockets/b01-valcon-254mm-single-row-socket-strip-35mm-profile/
            You could solder it directly to the board but then if you needed to change it in the future it would me more complicated.
            I have not personally done this swap.
            • oolykundefined
              oolyk @T3P3Tony
              @T3P3Tony thanks
