    waiting for status
    Gcode meta commands
    427
    • chrishammundefined
      chrishamm administrators @Proschi3D
      @Proschi78 What status do you mean? In principle something like that will do:
      while state.status != "processing"
        G4 S1
      Duet software engineer
      • Proschi3Dundefined
        Proschi3D @Proschi3D
        @Proschi78
        I want to do a pid tuning and after the left extruder start tuning on the right.
        I want to start the pid on the right extruder when the status of the left one is either stanby or off
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
        chrishammundefined Proschi3Dundefined 2 Replies Last reply Reply Quote 0
          @Proschi78 So you're talking about heaters. In that case something like this should work:
          ; tune heater 1 and wait for it to finish
          M303 H1 S210
          while heat.heaters[1].state != "standby" && heat.heaters[1].state != "off"
            G4 S1
          ; tune heater 2 and wait for it to finish
          M303 H2 S210
          while heat.heaters[2].state != "standby" && heat.heaters[2].state != "off"
            G4 S1
          ; tuning finished, save parameters to config-override.g
          M500
          Proschi3Dundefined 1 Reply Last reply Reply Quote 2
            Proschi3D @chrishamm
            @chrishamm
            thank you very much I will test that
              @Proschi78 do I need something in deamone.g for that
              T3P3Tonyundefined Proschi3Dundefined 2 Replies Last reply Reply Quote 0
                T3P3Tony administrators @Proschi3D
                @Proschi78 i would do that in a macro for tuning heaters. you don't want it in deamon.g because that runs all the time and your heater tuning will only (presumably) run once or maybe a few times per machine.
                  @T3P3Tony have expressed myself wrong.
                  i meant do i need deamone.g to get the status of the heater?
                  or if the macro works without deamone.g
                    @Proschi78 daemon.g is a macro that the system runs every 10s, in other ways its no different for any other macro.
                    the information that you are using, e.g. heat.heaters[1].state comes from the object model:
                    https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation
                    so you can access it from any macro.
                    Proschi3Dundefined 1 Reply Last reply Reply Quote 1
                      Proschi3D @T3P3Tony
                      Is there a way to save the PID result directly in a filament config?
                      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                        @Proschi78 I got it.
                        Now I still have the problem that the file is always deleted and recreated.
                        Is it possible to only update the file and not delete it?
                        M303 H1 S210
                          G4 S1
                        M303 H2 S210
                          G4 S1
                        M291 S3 R"The results of the PID tune have been automatically saved" P"You can view the results of the PID tune in the PID_tune_E0.g file"
                        echo "You can view the results of the PID tune in the Filament PID file"
                        echo >"0:/filaments/PLA/PLA PID" "M307 H1 R"^{heat.heaters[1].model.heatingRate}, "K"^{heat.heaters[1].model.coolingRate}^":"^{heat.heaters[1].model.fanCoolingRate}, "D"^{heat.heaters[1].model.deadTime}, "E"^{heat.heaters[1].model.coolingExp}
                        echo >>"0:/filaments/PLA/PLA PID" "M307 H1 B0 S1.0 V"^{heat.heaters[1].model.standardVoltage}
                        echo >>>"0:/filaments/PLA/PLA PID" "M307 H2 R"^{heat.heaters[2].model.heatingRate}, "K"^{heat.heaters[2].model.coolingRate}^":"^{heat.heaters[2].model.fanCoolingRate}, "D"^{heat.heaters[2].model.deadTime}, "E"^{heat.heaters[2].model.coolingExp}
                        echo >>>"0:/filaments/PLA/PLA PID" "M307 H2 B0 S1.0 V"^{heat.heaters[2].model.standardVoltage}
                        ;M303 H0 S60
                        ;while heat.heaters[0].state != "standby" && heat.heaters[0].state != "off"
                        ;  G4 S1
                        M500
                        M570 H0 P5 T15							; set heater fault detection back to default
                        OwenDundefined 1 Reply Last reply Reply Quote 0
                        • OwenDundefined
                          OwenD @Proschi3D
                          @Proschi78
                          I'm not sure why you want to save the PID results in a filament config.g
                          The results should be the same regardless of filament.
                          Use M500 to save them to config-overide.g
                          In addition, I think you should change your wait state to
                          while heat.heaters[1].state = "tuning"
                              G4 S1
                          So that you are actually checking if it is tuning.
                          The available states are here
                          For example your code would continue immediately if the state was "fault"
                            Proschi3D @OwenD
                            @OwenD I call the PID over M703. The code works as I posted it above
