Z Axis stepper driver / motor query
Firmware installation
366
    900turbo @jay_s_uk
    @jay_s_uk I have included a screenshot of the RepRap site , How do I add my Z2 and Z3 drivers? When i click on + it will only add E0 ect...
    Thank You.
    undefined 1 Reply Last reply 11 Apr 2023, 14:43 Reply Quote 0
      droftarts administrators @900turbo
      @900turbo Thanks. I've updated the Configuring motors page https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_configuring#drive-limits, and noticed the Heaters page was out of date too, so updated that https://docs.duet3d.com/User_manual/Connecting_hardware/Heaters_overview#heater-configuration-limits
        jay_s_uk @900turbo
        @900turbo you currently can't. there is a revision of the config tool coming that allows it but I don't think it'll be ready until the release of 3.5
        For now you'll just have to edit the config manually afterwards.
        Assuming you're using drivers 2 and 3 for Z, the only changes you need to make are to M584 e.g.
        M584 Z2:3
        undefined 1 Reply Last reply 11 Apr 2023, 14:45 Reply Quote 0
          900turbo @jay_s_uk
          @jay_s_uk Okay I see , so for now I will just config Z1 for the "starter pack of code"
          Thank You.
          undefined 1 Reply Last reply 11 Apr 2023, 14:49 Reply Quote 1
            @900turbo You should add M569 commands for each additional driver, then M584 to define which driver gets used for each axis. See https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_configuring#using-more-than-one-motor-on-an-axis-with-a-separate-driver-for-each-motor for an example.
            undefined 1 Reply Last reply 11 Apr 2023, 15:04 Reply Quote 2
              900turbo @droftarts
              @droftarts @jay_s_uk
              When selecting the Endstop Pin how am i meant to be deciding what to select from the list I have screenshot below.
              Thank You.
              undefined 1 Reply Last reply 11 Apr 2023, 15:07 Reply Quote 0
                jay_s_uk @900turbo
                @900turbo what type of switch is it? normally open or normally closed?
                undefined 1 Reply Last reply 11 Apr 2023, 15:10 Reply Quote 0
                  900turbo @jay_s_uk
                  @jay_s_uk I have set up my microswitches to be Normally Closed to avoid interference on the XY axis. However the Z Axis uses 3 Photomicrosensors with adjustable Flags https://docs.rs-online.com/9ecf/0900766b800b4c3a.pdf
                  Thank you.
                    jay_s_uk @900turbo
                    @900turbo just treat them as io0.in and so on
                    undefined 1 Reply Last reply 11 Apr 2023, 15:11 Reply Quote 1
                      900turbo @jay_s_uk
                      @jay_s_uk Okay does that apply to all Axis?
                      Thank You.
                      undefined 1 Reply Last reply 11 Apr 2023, 15:11 Reply Quote 0
                        jay_s_uk @900turbo
                        @900turbo yep
                        15 out of 16
