    PanelDue will not display temperature
    255
    • CHARLI55undefined
      CHARLI55
      PanelDue does not show temperature or extruder everything else if any solution?_075014.jpg
        droftarts administrators @CHARLI55
        @CHARLI55 Most likely, you need to add M575 P1 S1 B57600 to your config.g. See https://docs.duet3d.com/User_manual/Connecting_hardware/Display_PanelDue#firmware-configuration
        Otherwise, we need more information. Send M115 to your Duet to show what firmware and hardware you are using. Post your config.g. On the PanelDue, click on 'Setup' (I think 'Configuracion' on yours) and report what firmware version your PanelDue is using. How is the PanelDue connected to the Duet? Check the wiring is correct: https://docs.duet3d.com/User_manual/Connecting_hardware/Display_PanelDue
        CHARLI55undefined 1 Reply Last reply Reply Quote 0
        • CHARLI55undefined
          CHARLI55 @droftarts
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2022-03-15 18:58:33
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 10 2021 17:47:01 GMT+0200 (hora de verano de Europa central)
          M550 P"My Printer" ; set printer name
          M669 K1 ; select CoreXY mode PONIA K1
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S1 ; physical drive X goes forwards P0 S0
          M569 P1 S1 ; physical drive Y goes forwards P0
          M569 P2 S1 ; physical drive Z goes forwards
          M569 P3 S1 ; physical drive E0 goes forwards
          ;M569 P4 S1 ; physical drive E1 goes forwards
          M569 P5 S1 ; physical drive Z goes forwards
          M569 P6 S1 ; physical drive Z goes forwards
          M584 X0 Y1 Z2:5:6 E3 ; set drive mapping
          M671 X182:320:30 Y65:320:320 S15 ;M671 X181:30:320 Y65:320:320 S1 ; leadscrews at rear left, front middle and rear right
          M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X320 Y320 Z400 S0 ; set axis maxima
          M950 S0 C"duex.pwm1" ;M950 S0 C"!exp.heater6" ;M950 S2 C"exp.heater5" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H10 F320 T6000 ; set Z probe type to bltouch and the dive height + speeds
          M574 Z1 S2 ; set endstop controlled by probed
          G31 P500 X0 Y0 Z6.5 ;PONIA G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
          M950 H2 C"e1heat" T2 ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M143 H2 S280 ; set temperature limit for heater 1 to 280C
          M563 P1 D1 H2 F0 ; define tool 1
          G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
          M501
          Connection from Paneldue to Duet Wifi 4 cables.
            @CHARLI55 Check the cable between the Duet and PanelDue. Most likely the green cable in the image below, that transmits data from the Duet to the PanelDue, is not making contact.
            • CHARLI55undefined
              CHARLI55 @droftarts
              Yes, it's okay, I tried another cable from the other Duet and it does the same thing to me, however it works on one duet and on another it doesn't, the one that works seems to connect to something because the connection ip appears on a screen.
              Could it be that the Duet is faulty?
                @CHARLI55 said in PanelDue will not display temperature:
                Can you connect using the ribbon cable? The CONN_SD connector has the same pins as the PanelDue connector for communication, so it is a good test to check the UTXD0 and URXD0 pins are working correctly. If that works, have a look at the back of the Duet board and check that the PanelDue header is soldered correctly.
                It's always a possibility!
                • CHARLI55undefined
                  CHARLI55 @droftarts
                  @droftarts
                  If it works then I don't know what to do.
                  s
                  • CHARLI55undefined
                    CHARLI55 @CHARLI55
                    Solved, I soldered the 4-wire connections of the Duet and it works, thank you very much for the help GREETINGS.
                    droftartsundefined 1 Reply Last reply Reply Quote 1
                      @CHARLI55 Great, glad you fixed it. Sorry that you were the victim of some poor soldering during manufacture!
                      • dc42undefined dc42 marked this topic as a question
                      • dc42undefined dc42 has marked this topic as solved
