    Web interface rejected my connection attempts
    Duet Web Control
    827
    • misanundefined
      misan @T3P3Tony
      @T3P3Tony One additional detail to the issue is this other capture, where pings can be seen responded with a huge time difference, suggesting the board receives the messages but respond to them abnormally late (once the issue has passed). Have a look at ICMP request issued at 130 and responded at 2020 (almost 50 seconds later).
      capture5.pcapng.bin
      • misanundefined
        misan @T3P3Tony
        @T3P3Tony A recent M122 output:
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
        Board ID: 0JD0M-9K662-MGPSS-6J1FG-3S46Q-KVUGY
        Used output buffers: 1 of 24 (18 max)
        Static ram: 23876
        Dynamic ram: 74152 of which 0 recycled
        Never used RAM 16388, free system stack 126 words
        Tasks: NETWORK(ready,647.7%,237) HEAT(delaying,0.3%,386) Move(notifyWait,52.2%,307) MAIN(running,544.4%,546) IDLE(ready,14.3%,29), total 1258.9%
        Owned mutexes: WiFi(NETWORK)
        Last reset 05:12:00 ago, cause: power up
        Last software reset at 2022-11-08 16:55, reason: User, GCodes spinning, available RAM 16388, slot 2
        Error status: 0x00
        Step timer max interval 0
        MCU temperature: min 18.8, current 24.2, max 24.8
        Supply voltage: min 23.6, current 23.8, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: position 75056, standstill, SG min/max not available
        Driver 1: position 42138, standstill, SG min/max not available
        Driver 2: position 6103, standstill, SG min/max not available
        Driver 3: position 0, standstill, SG min/max not available
        Driver 4: position 0, standstill, SG min/max not available
        Driver 5: position 0
        Driver 6: position 0
        Driver 7: position 0
        Driver 8: position 0
        Driver 9: position 0
        Driver 10: position 0
        Driver 11: position 0
        Date/time: 2023-01-16 12:09:06
        Slowest loop: 217.84ms; fastest: 0.11ms
        === Storage ===
        Free file entries: 9
        SD card longest read time 4.4ms, write time 42.8ms, max retries 0
        DMs created 83, maxWait 366651ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 164159, completed moves 164120, hiccups 5, stepErrors 0, LaErrors 0, Underruns [27567, 0, 0], CDDA state 3
        === AuxDDARing ===
        Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is doing "G1 X1172.75 Y718.41 Z42.40" in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 948.00ms; fastest: 0.00ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(2), 1 sessions
        HTTP sessions: 1 of 8
        - WiFi -
        Network state is active
        WiFi firmware version 1.25
        WiFi MAC address 48:3f:da:48:b2:81
        WiFi Vcc 3.43, reset reason Power up
        WiFi flash size 4194304, free heap 19872
        WiFi IP address 192.168.1.8
        WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        Socket states: 2 0 0 0 0 0 0 0
          T3P3Tony administrators @misan
          @misan said in Web interface rejected my connection attempts:
          That looks long. not sure if it could be waiting for an SD card read or write which is why i suggested that test.
          misanundefined 1 Reply Last reply Reply Quote 0
          • misanundefined
            misan @T3P3Tony
            @T3P3Tony I am going to test the SD replacement, but my order is in the mail 🙂
            Anyway, what seems to be the cause is Dropbox's operation. It looks like some of the network traffic it broadcasts might be setting the ESP8266 into a weird state.
            We know that the problem does not appear if we stop Dropbbox on our workshop computers from synchronizing.
            I have a longer traffic capture, with the problem starting at 15.2 seconds (approx) but the file is too long for your system, so it can be downloaded from here (for a limited time) https://we.tl/t-m0dDrqfM2K
              @misan ahh that's interesting, is dropbox doing some broadcast synchronisation on the LAN between your local computers? Maybe it has a setting that allows you to set the machines specifically and not broadcast?
              • misanundefined
                misan @T3P3Tony
                @T3P3Tony I have set the systems not to use LAN synchronization for a while to see if that helps or fixes the problem entirely. I will know more at the end of the day.
                Please note I added a link to a more comprehensive network capture in the previous email I edited.
                  dc42 administrators @misan
                  @misan you could try updating the wifi firmware to 2.1beta2 from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0beta1.
                  • misanundefined
                    misan @dc42
                    @dc42 Sure. I will do it and report back.
                    Oops, I just saw I cannot do that remotely (wifi parameters must be re-entered). That means I have to go to the workshop. This will then take longer.
                    • misanundefined
                      misan @misan
                      @dc42 since I disabled Dropbox LAN synchronization and moved all cell phones to another Wi-Fi network, the problem I reported is gone.
                      Given 2.1beta2 is reported to feature slower upload speeds plus being a beta version, and our use case is a CNC farm where every bit counts, I have decided not to update wifi firmware on our boards.
                        The initial tests we did on just one Duet and one router indicated that 2.x was slower than 1.x; however some users are getting higher speeds with 2.x than they did with 1.x.
                        • misanundefined
                          misan @dc42
                          @dc42 Hmm, maybe I will try it the next time I visit the workshop. Thanks for the clarification.
