    Web interface rejected my connection attempts
    Duet Web Control
    827
    • misanundefined
      misan @T3P3Tony
      @T3P3Tony A recent M122 output:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9K662-MGPSS-6J1FG-3S46Q-KVUGY
      Used output buffers: 1 of 24 (18 max)
      Static ram: 23876
      Dynamic ram: 74152 of which 0 recycled
      Never used RAM 16388, free system stack 126 words
      Tasks: NETWORK(ready,647.7%,237) HEAT(delaying,0.3%,386) Move(notifyWait,52.2%,307) MAIN(running,544.4%,546) IDLE(ready,14.3%,29), total 1258.9%
      Owned mutexes: WiFi(NETWORK)
      Last reset 05:12:00 ago, cause: power up
      Last software reset at 2022-11-08 16:55, reason: User, GCodes spinning, available RAM 16388, slot 2
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 18.8, current 24.2, max 24.8
      Supply voltage: min 23.6, current 23.8, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 75056, standstill, SG min/max not available
      Driver 1: position 42138, standstill, SG min/max not available
      Driver 2: position 6103, standstill, SG min/max not available
      Driver 3: position 0, standstill, SG min/max not available
      Driver 4: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2023-01-16 12:09:06
      Slowest loop: 217.84ms; fastest: 0.11ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 4.4ms, write time 42.8ms, max retries 0
      DMs created 83, maxWait 366651ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 164159, completed moves 164120, hiccups 5, stepErrors 0, LaErrors 0, Underruns [27567, 0, 0], CDDA state 3
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is doing "G1 X1172.75 Y718.41 Z42.40" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 948.00ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(2), 1 sessions
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.25
      WiFi MAC address 48:3f:da:48:b2:81
      WiFi Vcc 3.43, reset reason Power up
      WiFi flash size 4194304, free heap 19872
      WiFi IP address 192.168.1.8
      WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Socket states: 2 0 0 0 0 0 0 0
        T3P3Tony administrators @misan
        @misan said in Web interface rejected my connection attempts:
        That looks long. not sure if it could be waiting for an SD card read or write which is why i suggested that test.
        misanundefined 1 Reply Last reply Reply Quote 0
        • misanundefined
          misan @T3P3Tony
          @T3P3Tony I am going to test the SD replacement, but my order is in the mail 🙂
          Anyway, what seems to be the cause is Dropbox's operation. It looks like some of the network traffic it broadcasts might be setting the ESP8266 into a weird state.
          We know that the problem does not appear if we stop Dropbbox on our workshop computers from synchronizing.
          I have a longer traffic capture, with the problem starting at 15.2 seconds (approx) but the file is too long for your system, so it can be downloaded from here (for a limited time) https://we.tl/t-m0dDrqfM2K
            @misan ahh that's interesting, is dropbox doing some broadcast synchronisation on the LAN between your local computers? Maybe it has a setting that allows you to set the machines specifically and not broadcast?
            • misanundefined
              misan @T3P3Tony
              @T3P3Tony I have set the systems not to use LAN synchronization for a while to see if that helps or fixes the problem entirely. I will know more at the end of the day.
              Please note I added a link to a more comprehensive network capture in the previous email I edited.
                dc42 administrators @misan
                @misan you could try updating the wifi firmware to 2.1beta2 from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0beta1.
                • misanundefined
                  misan @dc42
                  @dc42 Sure. I will do it and report back.
                  Oops, I just saw I cannot do that remotely (wifi parameters must be re-entered). That means I have to go to the workshop. This will then take longer.
                  • misanundefined
                    misan @misan
                    @dc42 since I disabled Dropbox LAN synchronization and moved all cell phones to another Wi-Fi network, the problem I reported is gone.
                    Given 2.1beta2 is reported to feature slower upload speeds plus being a beta version, and our use case is a CNC farm where every bit counts, I have decided not to update wifi firmware on our boards.
                      The initial tests we did on just one Duet and one router indicated that 2.x was slower than 1.x; however some users are getting higher speeds with 2.x than they did with 1.x.
                      • misanundefined
                        misan @dc42
                        @dc42 Hmm, maybe I will try it the next time I visit the workshop. Thanks for the clarification.
