ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
Link to a zip with the config files in
https://drive.google.com/file/d/1JSyTzxHwKSFLeYJ-qqXJ88_kIwULIfp4/view?usp=sharing
let me know if this works.
@blacksheep99 Hi I think I may be having a small problem when I load gcode (from cura) onto a Micro SD card and put it in the printer the printer says no models found. To set up cura I just copied and pasted the start and gcode from your ST3Di_Modelsmart_200.def.json.zip file. Was this the right way to that or have I done it wrong. Or do you know if this may be another Issue.
Additionally, do you know what I should put for the X and Y offsets for the nozzles because I don't really know what they are and how to find them out. (I just measured the distance between the nozzles with a vernier callipers and but that as the X offset Which I'm sure is not the right way, Do you possibly know how to do it and/or have the offsets?) Thanks for all your help so far. -
@blacksheep99 Also I just checked the Gcode files that cura is putting out are 0 bytes. Do you have any idea why this may be happening and possibly how to fix it?
@asdfasdf426 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
Additionally, do you know what I should put for the X and Y offsets for the nozzles because I don't really know what they are and how to find them out. (I just measured the distance between the nozzles with a vernier callipers and but that as the X offset Which I'm sure is not the right way, Do you possibly know how to do it and/or have the offsets?) Thanks for all your help so far.Hi, I'm struggling to remember if I'm honest. I'll check for old configs for the 280 as the ones in the zip are for the 200 (principle is the same). Did you save those files to the folders as per the guide?
For the 280 I think you need 2 extruder files and they should be referenced in the definition file.
I don't recall needing to change the offset of the two extruders as I think they FW controls it. You may be able to use Cura to tweak it though if they are slightly out.
These are my old 280 files. Maybe a better starting point.
https://drive.google.com/file/d/1K6EtdznTIZRGNCmrj5GTYIlvQVWrrL8o/view?usp=sharing
These were my notes to myself.
Printer Profile
Explains how to setup a new printer profile, also where to save/edit the files.
https://github.com/Ultimaker/Cura/wiki/Definition-Files-ExplainedCreated by GH (15/5/19)
Updated version (20/05/2019) NOTE: May need to switch the left and right extruders in the definitions to match Cura. Currently Material 1 prints on the right extruder, I think logically you'd want it on the left and Material 2 on the right?
If you want a representation of the build plate (helps with positioning). Then save this to the meshes folder
Material I created (PLA)
In addition I wanted to find a way to have Cura save out the gcode files with the ebp extension. Using this link I was able to find a way….
https://github.com/Ultimaker/Cura/issues/1059
Save the file below to this location.
C:\Program Files\Ultimaker Cura 4.0\plugins\GCodeWriterCopyright (c) 2015 Ultimaker B.V.
Cura is released under the terms of the LGPLv3 or higher.
from . import GCodeWriter
from UM.i18n import i18nCatalog
catalog = i18nCatalog("cura")def getMetaData():
return {"mesh_writer": { "output": [{ "extension": "ebp", "description": catalog.i18nc("@item:inlistbox", "G-code File"), "mime_type": "text/x-gcode", "mode": GCodeWriter.GCodeWriter.OutputMode.TextMode }] } }
def register(app):
return { "mesh_writer": GCodeWriter.GCodeWriter() }The next thing I'd like to figure out is how to edit or stop Cura adding text to the start of the output file. This needed to be deleted before you can print.
Example: Yellow text need deleting or a way of having the ebp@280 line first (I think the printer FW looks for this to authenticate the file is suitable for the printer).
;FLAVOR:Marlin
;TIME:5405
;Filament used: 5.85157m, 0m
;Layer height: 0.2
;Generated with Cura_SteamEngine 4.0.0
T0
M82 ;absolute extrusion mode
ebp@280
pla@1
pla@1
null@0
version@1_2_36@null@null
T0
M190 S40.0
M104 TO S210.0
G21
G90
M107
T0
G28
G29
M109 TO S210.0
M107
T0 -
Hello Blacksheep99,
i am trying to get my stedi 280 running again and update to standard Marlin control is there any chance you have a configuration.f file that i can use?
any other tips would be very much appreciated
I would also like to get away from theb cassettes and use standard filament, do you see any problems there?
regards hpnonthuis -
@Hpnonthuis I swapped out the control board for a Duet so it runs RRF. The original board was locked so it wasn't possible to upgrade the FW.
@Blacksheep99 Hi, very new to 3D printing. I recently bought a new ST3Di 3D-FP-ST-1001-00 3D Printer, ModelSmart Pro 280 but when I tried to download the software from the site as directed by the manual but it no longer exists. Sorry if this is the wrong forum but I am struggling to find it anywhere. Is there an alternative at all. Thanks very much for any help you offer.
@robinzulu I have the old slicer on my google drive.
https://drive.google.com/file/d/1f1yuOidiOxlcGvqfJhKm9rftpKGLOB2k/view?usp=share_link
You can create a profile in something like Prusaslicer and use this with the ST3Di as well. Just takes a bit of work.
@Blacksheep99 Thanks very much for you help, I will let you know how I get on.
undefined droftarts referenced this topic 8 Jun 2023, 23:00
