    Home Assistant Integration
    Third-party software
    14
    47
    5.1k
    • Reineundefined
      Reine @repier37
      @repier37 just installed your plugin but it doesn't seam to connect to my printer (6HC/v3.4.5 with SBC).
      If I send a manual http request it seams like I get access without a password.
      http://10.0.0.68/machine/connect?password=
      Any ideas what I might have done wrong? All sensors are setup, but values do not change.
        duet3d_printer:
          host: !secret duet3d_host
          name: !secret duet3d_name
          password: !secret duet3d_password
          number_of_tools: 1
          bed: true
          sensors:
            monitored_conditions:
              - 'Current State'
              - 'Temperatures'
              - 'Job Percentage'
              - 'Time Elapsed'
              - 'Time Remaining'
              - 'Position'
      Reineundefined 1 Reply Last reply Reply Quote 0
      • Reineundefined
        Reine @Reine
        Seams like rr_status has been deprecated in v3.4.5, http://10.0.0.68/machine/Status works though so for this to work with the current version of RRF some work needs to be done on this integration. unfortunately I'm not a Python dev.
        Btw, is there a websocket or webhooks that can be used or can we only rely on polling updates?
        Lyr3xundefined 1 Reply Last reply Reply Quote 0
        • Lyr3xundefined
          Lyr3x @Reine
          Hey folks,
          i picked this topic up yesterday and refactored the integration to make it work again with the new /machine/status endpoint.
          https://github.com/Lyr3x/hass-Duet3D
          Not happy yet with the position entity and the fact that there is no proper config flow and entities are not attached to a device. I will work on that in the next days. Might take some time as I need to dig into that to understand how custom components are built and what the spaghetti code in the integration is doing πŸ˜„
          I removed the job percentage yesterday temporarily to get this out of my way, because there is not such attribute, but I already spotted that it can be easily calculated with the file size. Contributions are welcomed!
          I also removed the password property, as this is not needed for the endpoint. Furthermore, I might need to set up a proper session when the integration has maybe a service to send G/M codes as well. We'll see.
          Hope that it is of some help for you as well πŸ™‚
          nikschaundefined 1 Reply Last reply Reply Quote 2
          • izemanundefined
            izeman @pkos
            @pkos said in Home Assistant Integration:
            While waiting, you can easily use this:
            https://github.com/iz3man/duet3d/blob/main/duet3d.yaml
            Just add the lines to your configuration.yaml, modify for your printer and restart HA.
            LOL. Looking for a way to get MQTT running on Duet-Wifi board, find this thread, and then a link to MY github πŸ˜‰
            Btw: This is still using perfectly fine with the latest betafirmware
            And I found this github for MQTT integration which gives basically the same info - but haven't tested yet, as I'm waiting for native MQTT support before I start ripping everything apart again.
            https://github.com/keyz182/DuetMQTT
            Marshalldogundefined Lyr3xundefined 2 Replies Last reply Reply Quote 2
            • nikschaundefined
              nikscha @Lyr3x
              @Lyr3x good work, wow! I'll check it out in the next few days!
              Stay in school
              • Marshalldogundefined
                Marshalldog @izeman
                @izeman Looks Awesome
                how did you get the controls for PLA and that switch into HASS?
                • Lyr3xundefined
                  Lyr3x @izeman
                  @izeman this is only working if you are not using SBC mode if I am not mistaken.
                  I worked on updating the integration to work asynchronous without blocking requests, which is working fine now (still need to merge).
                  There is quite some rework necessary to get config and options flow running, but I finally understood how the flows should be implemented. Can’t give a timeline yet though.
                  Configuration via configuration.yaml is working fine including time elapsed and remaining. I also added the progress sensor back and calculating the progress via total layers and printed layers.
                  nikschaundefined 1 Reply Last reply Reply Quote 0
                  • nikschaundefined
                    nikscha @Lyr3x
                    @Lyr3x I'm gettting an error when setting up the integration, could you help me out?
                    I have two printers, one running Duet Wifi 2 without SBC (RRF 3.4.5), and one running a Duet 3 Mini5+ WITH SBC (RRF 3.5.0beta3).
                    However both gave the same error as above. Navigating to 'printerip'/maschine/status also returns the json, so I doubt the issue is related to the printers? What else can I try? It might be noteworty that I run HASS on Docker?
                    Stay in school
                    • nikschaundefined
                      nikscha @nikscha
                      @nikscha
                      Here's the HASS log:
                      Logger: aiohttp.server
                      Source: data_entry_flow.py:387
                      First occurred: 15:43:51 (17 occurrences)
                      Last logged: 16:20:39
                      Error handling request
                      Traceback (most recent call last):
                        File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
                          resp = await request_handler(request)
                        File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
                          resp = await handler(request)
                        File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
                          return await handler(request)
                        File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
                        File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
                        File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
                        File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 81, in ban_middleware
                        File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
                        File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
                          result = await result
                        File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 180, in post
                          return await super().post(request, flow_id)
                        File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
                          result = await method(view, request, data, *args, **kwargs)
                        File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
                          result = await self._flow_mgr.async_configure(flow_id, data)
                        File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 286, in async_configure
                          result = await self._async_handle_step(
                        File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 387, in _async_handle_step
                          if not isinstance(result["type"], FlowResultType):
                      TypeError: 'NoneType' object is not subscriptable
                      Stay in school
                      • Lyr3xundefined
                        Lyr3x @nikscha
                        @nikscha as Said before the config flow is not working. You need to configure it via the configuration.yaml at the moment
                        • nikschaundefined
                          nikscha @Lyr3x
                          @Lyr3x Ohh I see. Fair enough. I'm still having problems though:
                          I added the follwoing to my config:
                          # Duet Integration
                          duet3d_printer:
                            host: !secret duet3d-host
                            name: !secret duet3d-name
                            number_of_tools: 1
                            bed: true
                            sensors:
                                - 'Current State'
                                - 'Temperatures'
                                - 'Job Percentage'
                                - 'Time Elapsed'
                                - 'Time Remaining'
                                - 'Position'
                          I also added the entries for host and name to the secrets.yaml.
                          However HASS wont restart:
                          Stay in school
                          • Lyr3xundefined
                            Lyr3x @nikscha
                            @nikscha oh the readme is still wrong. It is not Job percentage but Progress
                            nikschaundefined 1 Reply Last reply Reply Quote 1
                            • nikschaundefined
                              nikscha @Lyr3x
                              @Lyr3x that did the trick, thanks!
                              The integration is working well, can I do anything to test it for you?
                              Stay in school
                              Lyr3xundefined 2 Replies Last reply Reply Quote 0
                              • Lyr3xundefined
                                Lyr3x @nikscha
                                @nikscha thanks πŸ™‚ will let you know! Of course if something is not working as intended don’t keep it to yourself.
                                • Lyr3xundefined
                                  Lyr3x @nikscha
                                  Configflow is still giving me a headache. I need to refactor the code more to get this working properly.
                                  But I added a home assistant service to send gcodes:
                                  service: duet3d_printer.hevors_send_gcode
                                  data:
                                    gcode: G28
                                  Feedback appreciated!
                                  • nikschaundefined
                                    nikscha @Lyr3x
                                    @Lyr3x Hmm now it doesn't work anymore^^
                                    I updated the integration though HACS, and after a restart the integration was gone from the integration panel. Didn't make any other changes. How can I debug this? Logs are empty too πŸ˜•
                                    Stay in school
                                    • Lyr3xundefined
                                      Lyr3x @nikscha
                                      Edit: Alright, I just released a new version of the integration. ConfigFlow is now working as well as the service. The binary sensor is still dead. You need to remove the configuration from your configuration.yaml and just setup the integration via UI. I unfortunately need to ask you to reconfigure the Integration later again, because I want to attach the entities to a device. But its in a working mode now! Please do not hesitate with feedback.
                                      @nikscha Yep realized that as well, sorry. I decided to stop trying to patch the stuff I want to remove anyway and fix the config flow setup and remove the configuration.yaml code completely. I already have a working unpolished state. Bear with me a little more. Ill update you all here later!
                                      • nikschaundefined
                                        nikscha @Lyr3x
                                        @Lyr3x No worries! It's working now, config flow as well. I suggest naming the fields in the config flow. I tried doing this myself and creating a pull request but honestly I am just not that good at Python ^^
                                        I also tried making a textfield card to send typed Gcodes, but I also gave up and instead asked for help here
                                        I also tested some gcodes, most of them seem to work just fine but I noticed a strange delay when sending a M291 P"X" R"X" S3. This doesn't happen with S2, S1 or S0. Maybe this is intentional behaviour? Sending the same command from within DWC returns instantly though.
                                        Stay in school
                                        • Lyr3xundefined
                                          Lyr3x @nikscha
                                          @nikscha what do you mean with naming the fields? They all have labels
                                          I’ll test the gcode tomorrow and see if I can find out what causes the delay!
                                          • nikschaundefined
                                            nikscha @Lyr3x
                                            @Lyr3x The fields are prefilled, but it doesn't say what should be in there. This is what it looks like with the prefilled values removed: 4b9af3c0-5a02-49dc-b3d5-bad0a1dc0d38-image.png
                                            What does the checkbox do for example?
                                            Looking at the code I can figure out its the field "has_bed", and I think that should be mentioned in the config flow as well
                                            Stay in school
