G30 Question
I built a Voron 2.4R2 using a klicky probe. I have a couple macros written to assist with Z offset calibration. I probe the bed using G30 3 times to get the height average for Z offset. The problem is every time I run G30 to get a measurement the firmware docks the klicky then undocks it takes a measurement, then docks and undocks the probe again for each subsequent probe. The macros are included. Is there a command that will just probe the bed without docking and undocking the probe ever time? Thanks
The process starts with running the macro Z Offset Calibration in the macro file
M561 ;clear Bed Mesh
M568 P0 S240 ;set active temperatures for tool 0
M140 S70 ;set Bed to 60C
M116 S5 ;wait until bed 0 and tool 0 are up to temperature
M564 S0 ;allow Z axis to exceed preset limits; Home, but only if homing is needed
if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
G28G1 E-30 ;retract filament so nozzle does not ooze
G1 Z55 F12000 ;raise Z axis 50mm for cleaning;M291 P"Clean All Residue From Nozzle before setting Z0"
M98 P"Clean Nozzle"
G1 Z2; Home, but only if homing is needed
G28
M291 P"Use to pieces of paper and jog the nozzle down to the right tension on the bed" R"Press Ok when Done?" S3 X1, Y1, Z1 ;instruct user to manualy move nozzle to bed
G92 Z0 ;Sets current location as Z0 Position
M98 P"Z Offset Calibration Finish" ;Call Macro to finish jobZ Offset Calibration Finish
G90 ;set absolute
G1 Z30 ;raise Z up 10 mm
G30 S-1 ;(G30) home z (S-1) record z height
G4 P1000 ;pause 1 sec
G1 X175 Y175 ;move Hot End to X175 Y175
M291 P"Check Consul for Results of Probing " ;instruct user to check results in Consol
;G28 -
@JADoglio At present
G30
always deploys/retracts the probe because that's required to drive a BLTouch and possibly other probes. Perhaps it would make more sense to define your Z-probe as a second tool and to do the dock/undock procedures in the corresponding tpre/tfree.g. -
@JADoglio you could send M401 before running any G30's and then M402 when finished. This should override the deploy for the G30
@chrishamm Thanks I will investigate.
@jay_s_uk Again, thanks I will play with this as well
@JADoglio I tried the 401/402 option first since it seemed simpler than creating another tool which I suspect would have also worked. This option worked as expected. Problem solved, Thanks
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
