3.5.0b1+ don't wait for commands to finish before moving on
Ok, what order things get displayed really don't bother me as long as it works irl.Uhm where should I start, nothing get's executed as I expect it to at this point
.I "want/think" this should happen:
- 1
start.g
gets called because i initialize a print. - 2
start.g
executes the codes in order from "line 1" downwards, with the first "visual" thing being that the the active bed temp changes to 65°C and starts heating up. - 3 Then continuing downwards, changing the toolhead lights, promting the
Print Started. Preheating and Homing
message for 10seconds (while in the background continuing to execute the code) until it gets toM190 S65
where it waits for the bed to reach 65°C. - 4 When the bed has reached 65°C it homes all the axis BEFORE, continuing to execute
print_tram.g
. - 5
print_tram.g
does it's thing, and that's the end ofstart.g
, so now it moves on the execute the actual sliced/job file. - 6 Runs the code in the sliced/job file from "line 1" downwards:
M107 M190 S110 ; set bed temperature and wait for it to be reached G10 S255 P0 ; set temperature ;TYPE:Custom ; Start G-code: START ; Inform of first layer height set global.first_layer_height = 0.2 ; Define print area set global.paMinX = 162.5 set global.paMaxX = 187.5 set global.paMinY = 162.5 set global.paMaxY = 187.5 ; Set temps & the initial extruder set global.bed_temp = 110 set global.hotend_temp = 255 set global.initial_extruder = 0 M83 ; use relative distances for extrusion
- 7 After executing
M83
it moves on to callingprint_start.g
. - 8
print_start.g
goes from "line 1" downwards, with first visual change being active bed temp changing to 110°C and it's starts heating up. - 9 The toolhead lights changes back to "heating-colors" and then
M116 H0 S5
get's executed, and everythings waits for the bed to reach 105°C before continuing. - 10 Bed temp has reached 105°C and
print_probe.g
gets called (for the sake of not writing a whole novel that does it things and we return to the next line ofprint_start.g
). - 11 Changes bed compensation taper in the background, then we see T0 active and standby temps change to 255°C and starts heating up.
- 12 The toolhead lights changes back to "heating-colors" again, and it executes
M116 H1
, so we wait for T0 to reach 255°C. - 13 T0 reaches 255°C, the chamber lights turn on, bed drops a tiny bit and
print_purge.g
gets called. - 14
print_purge.g
does it's thing and lays down the purge lines and the toolhead lights changes to "printing-colors". - 15
global.RunDaemon
changes tofalse
("turning off"daemon.g
) finishing ofprint_start.g
. - 16 We return to the sliced/job file and so on and so forth....
- 1
@Exerqtor thanks. What actually happens too soon, other than spurious output from echo commands? Do you see any motion before the bed has finished heating to 65C, or any other motion that happens too early ?
EDIT
Cleaned up the post.@dc42
It doesn't wait for the bed to reach 65°C even!😂😂
What happens is:- 1)
start.g
gets called because i initialize a print. - 2 Active bed temp changes to 65°C and
message gets displayed. - 3 Immediately while the message is displayed the active and standby hotend temps to 80°C and starts to home the axis.
- 4 The same millisecond the axis start to home it displays the "Response too long, see Console
- 5 It turns ONLY the hotend standby temp too 150°C while the homing sequence finish up.
- 6 I get the
M291 S1 R"Bed tramming" P"Bed allready trammed" T4
fromprint_tram.g
DESPITEglobal.bed_trammed
beingfalse
when i started the print. - 7 Then nothing more happens, both bed & hotend heaters gets turned off all movement stops, like the machine is in "limbo" (if I look at the DWC temp chart it's no visible changes in temps).
- 8 Switching over to DWC console this is what I see:
7.1.2023, 18:42:16 print_tram.g start print_tram.g end start.g end 7.1.2023, 18:41:57 print_tram.g start print_tram.g end start.g end Start G-code: START print_start.g start Error: No P or R parameter print_purge.g start Error: in file macro line 41 column 52: meta command: unknown variable 'x_origin' Cancelled printing file 0:/gcodes/Shape-Box_0.2mm_ABS_0.4n_5m.gcode, print time was 0h 0m 7.1.2023, 18:41:56 M32 "0:/gcodes/Shape-Box_0.2mm_ABS_0.4n_5m.gcode" File 0:/gcodes/Shape-Box_0.2mm_ABS_0.4n_5m.gcode selected for printing start.g start start.g start
This all happens so fast that either the bed OR hotend (E3D Revo 24v, so it's quite responsive) have any visible change in the temp chart.
The 80°C hotend temp part is something I'm going to remove, but it's a good thing that I forgot to remove that step since it highlights the fact that only the standby temp gets upped to 150°C when
G10 P0 S150 R150
is executed. - 1)
I must also add that:
When I check the object model browser after what happens above. All the globals have been parsed with the values from the sliced/job file like intended. AND
global.bed_trammed
has changed fromfalse
totrue
despite the no tramming has been performed.For referance this is how
bed.g
looks, and it works just like intended when i run it:; bed.g v2.1 ; Called as response to G32 ; Used to tram the bed ;---/ ; -/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!! ;--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ;-/ ; ====================--------------------------------------------------------- ; Question code ; ==================== ; Ask to make sure you want to tram the bed or not if !exists(global.bed_trammed) echo "global.bed_trammed missing, aborting! abort elif global.bed_trammed M291 S3 R"Bed tramming" P"The bed is allready trammed, want to tram it again?" else M291 S3 R"Bed tramming" P"Are you sure you want to tram the bed?" ; ====================--------------------------------------------------------- ; Prep phase ; ==================== ; LED status if exists(global.sb_leds) set global.sb_leds = "homing" ; Report whats going on M291 R"Bed tramming" P"Please wait..." T0 ; Tramming bed message M561 ; Clear any bed transform M290 R0 S0 ; Reset baby stepping M84 E0 ; Disable extruder stepper ; Lower Z currents if fileexists("/sys/lib/current/z_current_low.g") M98 P"/sys/lib/current/z_current_low.g" ; Set low Z currents else M913 Z60 ; Set Z motors to 60% of their max current ; ====================--------------------------------------------------------- ; Lower Z axis ; ==================== ; Lower Z relative to current position if needed if !move.axes[2].homed ; If Z ain't homed G91 ; Relative positioning G1 Z{global.Nozzle_CL} F9000 H1 ; Lower Z(bed) relative to current position G90 ; Absolute positioning elif move.axes[2].userPosition < {global.Nozzle_CL} ; If Z is homed and less than global.Nozzle_CL G1 Z{global.Nozzle_CL} F9000 ; Move to Z global.Nozzle_CL ; ====================--------------------------------------------------------- ; Homing check ; ==================== ; Make sure all axes are homed, and home Z again anyways if !move.axes[0].homed || !move.axes[1].homed ; If X & Y axes aren't homed ; Home X & Y axis M98 P"/sys/homex.g" Z A ; Home X axis, pass param.Z since we allready lowered Z & A to indicate this is part of a homing sequence M98 P"/sys/homey.g" Z C ; Home Y axis, pass param.Z since we allready lowered Z & C since XY currents/speeds are also ok ; ==================== ; Home Z axis ; ==================== M98 P"/sys/homez.g" Z A ; Home Z axis, pass param.Z since we allready lowered Z & A to indicate this is part of a homing sequence ; ====================--------------------------------------------------------- ; Tramming code ; ==================== ; LED status if exists(global.sb_leds) set global.sb_leds = "tramming" ; Coarse tramming pass M558 K0 H10 F300 A1 ; Increase the depth range, gets the bed mostly trammed immediately M98 P"/sys/bed_probe_points.g" ; Probe the bed ; Fine tramming pass while true ; Probe near lead screws - M558 K0 H2 F300:180 A3 ; Reduce depth range, probe slower for better repeatability M98 P"/sys/bed_probe_points.g" ; Probe the bed ; Check results - exit loop if results are good if move.calibration.initial.deviation < 0.02 ; If probing result is less than 0.02mm set global.bed_trammed = true ; Set global state break ; Stop probing ; Check pass limit - abort if pass limit reached if iterations = 5 ; If probed more than 5 times M291 P"Bed tramming aborted!" R"Pass Limit Reached!" ; Abort probing, something wrong set global.bed_trammed = false ; Set global state abort "Bed tramming aborted! - Pass Limit Reached!" ; Abort probing, something wrong ; ====================--------------------------------------------------------- ; Finish up ; ==================== ; Uncomment the following lines to lower Z(bed) after probing G90 ; Absolute positioning G1 Z{global.Nozzle_CL} F2400 ; Move to Z global.Nozzle_CL ; Home Z one last time now that the bed is trammed M98 P"/sys/lib/goto/bed_center.g" ; Move to bed center G30 K0 Z-99999 ; Probe the center of the bed M400 ; Wait for moves to finish ; Full currents if fileexists("/sys/lib/current/xy_current_high.g") M98 P"/sys/lib/current/xy_current_high.g" ; Set high XY currents else M913 X100 Y100 ; Set X Y motors to var.100% of their max current if fileexists("/sys/lib/current/z_current_high.g") M98 P"/sys/lib/current/z_current_high.g" ; Set high Z currents else M913 Z100 ; Set Z motors to var.100% of their max current ; Uncomment the following lines to lower Z(bed) after probing G90 ; Absolute positioning G1 Z5 F2400 ; Move to Z 10 M291 R"Bed tramming" P"Done" T5 ; Bed tramming done message ; If using Voron TAP, report that probing is completed if exists(global.TAPPING) set global.TAPPING = false M402 P0 ; Return the hotend to the temperature it had before probing ; LED status if exists(global.sb_leds) set global.sb_leds = "ready"
As you can see it's more or less functionally the same as
print_tram.g
, except some question and homing steps inbed.g
. But the check to see if the bed is allready trammed works like intended and is carried out in the same manner inprint_tram.g
Anyone else with 3.5.0b1+ thats willing to try recreating this issue?
Shouldn't be anything super exotic that needs to be changed to try this out on other machines
I've looked to the code so many times now I'm sure I wouldn't find a fault if it jumped at me lol
@Exerqtor what's happening is that there are now two GCode File channels used to process print files, one for each motion system. Normally, only the first one of them executes commands. The other typically reaches end of file or the M0 command if there is one, and waits for the first to catch up.
What I hadn't allowed for is that both File channels will execute GCode meta commands such as echo, and set. This is why you are seeing some echo commands being executed ahead of time, and why global.bed_trammed is being set to true.
I propose to change the behaviour as follows, which I hope will resolve this for you:
- Only execute echo, global and set global commands commands from the File channel that is currently selected.
When either channel reaches a command that involves waiting for temperatures to be reached, add a sync point there so that both File channels wait. no, that would not be appropriate e.g. when changing tools and waiting for a hot end to heat.
Uuuhm oook, how do i know what file channel is in use? Sounds easier/less issue proned (for me) to just don't usestart.g
and scrap it to be honest. -
@Exerqtor my aim is that you won't need to modify start.g; but if you do, the modification needed should be simple.
Ah I missunderstood what you meant! Do what you feel is the best way of solving/moving around it, I haven't got a good enough understanding of how it all ties together to weigh in on it -
@Exerqtor can you confirm if the issue with start.g other than the one with M190 you reported here: https://forum.duet3d.com/post/308884 are resolved?
@T3P3Tony
I've ditched using start.g totally because it made more problems for me than it solved.If my recollection serves me right though, i'm pretty sure the changes David did in b2 solved this perticular issue.
I'll remove this thread as a question so it won't remain as "unsolved" at least.
