    New beta firmware 1.20beta8
    Firmware installation
    10
    31
    3.9k
      @mchiriciuc:
      @fma:
      David, I won't be able to test sensorless homing for CoreXY, as I need to replace my belt… If someone else can test it, and check than any of motors stall is detected, when moving along X or along Y (both motors turn in these directions)...
      I'm using sensorless homing on my CoreXY with 1.20beta7. Stalling is detected, but sometimes, instead of going to -x or -y, the move is executed in the opposite direction. After moving the head using the controls it gows in the right direction. I have not been able to replicate this behaviour. Other than this, stalling seems to be detected properly.
      This is my X home.g file content:
      ; Lift Z relative to current position
      G91
      G1 Z5 F6000
      G90
      M400 ; make sure everything has stopped before we make changes
      M913 X50 Y50 Z50 ; drop motor currents to 50%
      M574 X1 Y1 S3 ; set endstops to use motor stall
      M915 X Y S4 R0 F0 ; set X and Y to sensitivity 4, do nothing when stall, unfiltered
      G91 ; use relative positioning
      G1 S1 X-400 F4000 ; move left 400mm, stopping at the endstop
      G1 X5 ; move away from end
      G90 ; back to absolute positioning
      G92 X ; set new X home possition
      M400 ; make sure everything has stopped before we reset the motor currents
      M913 X100 Y100 Z100 ; motor currents back to 100%
      M574 X1 Y1 S0 ; Define active low and unused microswitches
      ; Lower Z again
      G91
      G1 Z-5 F6000
      G90
      I will test today 1.20beta8 in a few hours, I'll report if anything changes.
      Regarding the reset problem, I have been printing more then 24 hours without any reset or any other problems. I have a Duet Ethernet, not Wifi, so it might be wifi related?
      I suggest you remove this:
      and use parameter X-5 in your M208 S1 command to define the endstop position. I'm not sure it will fix the homing issue, but at least the printer won't think it is homed if the stall is not detected.
      • mchiriciucundefined
        mchiriciuc
        The homing issue occurs an the G1 S1 X-400 F4000 command, so the G92 X should have nothing to do with it. I will go with your suggestion since is the better and safer way of doing this. Thank you.
        But, I think I have an ideea what is happening.
        Sometimes, a stall is detected when the motor accelerates and only the G1 X5 is executed (as far as movement is perceived by me).
        I will test this further, and report back.
          Yes, that's entirely possible. You may need to increase the M915 S parameter, or reduce the acceleration.
          • DjDemonDundefined
            DjDemonD
            Any thoughts on the probing issue DC? I only ask as the difference in results between firmware versions is so stark there has to be something going on? I've replicated that now on two different machines.
            www.precisionpiezo.co.uk
              @DjDemonD:
              Thanks for the reminder. I've made a note to look at it next week.
              • Forgvn77undefined
                Forgvn77
                Just installed the 1.20beta8+1 and noticed right away that while printing my always on fan for my hot end is no longer always on. As the hot end moves, it revs up and down. The only change made to the printer was to update the firmware.
                Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
                Make A Difference!
                • Forgvn77undefined
                  Forgvn77
                  I worked the issue and determined it was a break in the fan connector or wiring somewhere that happened at the same time I updated the firmware. Checked further and found a broken ground wire at the board connector for the hot end fan.
                  Make A Difference!
                  • okerchoundefined
                    okercho
                    Question about the stall detection (I'm still in 1.19, so this is a theoretical question, not a bug report). I'm having issues since couple of prints ago with motors loosing steps, and of course, layer shifting. This is not happening always though. My suspect is that X carriage bushings has a problem, but I wasn't able to reproduce it, as it only happens from time to time.
                    Yesterday I was executing the mesh bed levelling, and I heard how the X carriage was stuck, and it checked twice the same point, assuming that it moved… Anyway, here my question, if the stall detection is enabled, and for any reason some steps are missed during the mesh bed levelling... what happens? is the procedure cancelled? it will home again and continue?
                    Regards
                    Okercho
                    Custom Prusa i3 Hephestos with Duet Wi-Fi
                    E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                    Rebuilding Hypercube Evolution
                      Currently, stall detection will only pause or rehome when you are printing from SD card.
                      • okerchoundefined
                        okercho
                        @dc42:
                        Ok, thanks 🙂
                        Okercho
                          @DjDemonD:
                          I just ran your file on my delta with the smart effector, and I added the results in a new column on your sheet. Looks OK to me. Probing speed is 1000mm/min, which is 16.7mm/sec or 16.7um/millisec. As the Z probe is only sampled once per millisecond, a range of commonly 15us and occasionally just over that is to be expected.
                          I am running a later build than 1.20b8+1, so things may have changed.
                          • DjDemonDundefined
                            DjDemonD
                            Thanks for having a look David. And for appending the results. For now if I am using my corexy as a sensor test rig then I'll just flash 1.19 temporarily. I'll test with whatever the latest edge build is and see if the behaviour changes when they're released.
                              btw in the next 1.20 beta there will be a new Z probe type 8, which is the same as type 5 without filtering, so faster response (no 1ms sampling). I've just tested it with your file again:
                              x16 microstepping, F1000: 25 instances of -0.166mm, 5 instances of -0.171mm
                              x32 microstepping, F1000: 1 instance of -0.158, 2 instances of -0.166, remainder -0.161 or -0.163.
                              If you want to try this version, the Duet WiFi build is at https://www.dropbox.com/s/tr3be3v9o5iqxxa/DuetWiFiFirmware.bin?dl=0.
                              • DjDemonDundefined
                                DjDemonD
                                Thanks I will try it now, that sounds right up my street.
                                • DjDemonDundefined
                                  DjDemonD
                                  Probing is much more accurate now, thanks David this really helps, now that z-probes are a whole new league more accurate than before.
                                  Did have one heavy contact on kossel XL during autocal, just wanted to see if this more precise probing improves calibration, oddly it doesn't seem to make any difference (just goes to show we're getting more into the "physics" of these sensors, not the engineering, they're plenty accurate for 3D printing). Its quite reassuring from a sensor accuracy point of view that the calibration doesn't improve once you reach a certain level of accuracy, as the mechanics are not changing and the sensors are accurate enough.
                                  I'll try a few more (with lower motor current) and just see if it happens again. Interestingly my hotend temp shot up to 51 deg C when it crashed the bed, a wire had come loose.
                                  I'm finding my results at 1/32 less accurate than at 1/16th with interpolation.
                                  • whosrdaddyundefined
                                    whosrdaddy
                                    would Z probe type 8 also affect piezo probing?
                                      @whosrdaddy:
                                      Yes.
                                      • DjDemonDundefined
                                        DjDemonD
                                        If by affect you mean possibly make it appear more accurate then yes.
                                        It's very interesting using RRF when doing probing tests usually you will see the minimum unit is 0.005mm/5microns. I think raising your microstepping above 1/16 will reduce this minimum unit. But when you are looking at a device with accuracy around 10-15 microns, but each micostep is (at 200steps/mm) just 5 microns, and only the best machines can be expected to actually move (or stop) on one single microstep, then, to be honest, the validity of comparison is limited at best.
                                        This change removes ?some/all of the signal processing, sharpening up the response to the probe triggering, and in theory increasing the accuracy. As I said above the fact that my delta doesn't suddenly start calibrating more accurately confirms that with piezo probes and smart effectors, both very precise systems, you really are measuring your machine's abilities, its frame rigidity, the smoothness of its linear motion components, the stiffness of carriages, axes, and beds etc, not the accuracy of the probe.
                                        I tested my corexy with this new firmware using direct electrical contact an got 10 microns range (using 1/16th microstepping) and 3 microns std deviation. With our prototype Piezo20 V2 unit that we are working on at present, we get 15 microns range and 4 microns deviation. So the probes are affecting the accuracy by 5 microns compared to electrical contact which should in theory be as good as it gets.
                                        Given that a 1st layer might be at most extreme 100 microns, but more than likely 200-300 microns, the effect of 5 microns either way when probing will undetectable in terms of printing (or bed leveling/grid levelling/calibration).
                                        • resamundefined
                                          resam
                                          Could Z probe type 8 also be beneficial for BLTouch users?
                                          The short pulse of the BLTouch that gets sent is already logic-level - so no filtering should be necessary AFAIK.
                                          • DjDemonDundefined
                                            DjDemonD
                                            I'd love to see some detailed results from BL touch, both with P8 and without, at varying probe speeds, with varying microstepping. Does the Bltouch deploy and retract for each probing dive, or just once at the start and end of probing?
                                            The reason why I ask is that my hypothesis is that most systems with a deploy/retract, suffer poor repeatability between sessions as they fail to re-deploy at exactly the same height each time. Th exception being the systems using optical endstops/IR boards above fixed above deployable metal probes since the metal probe is fixed length and the opto sensor is fixed to the print head, in theory, although they have to deploy/stow there is no repeatability issue. They are still often offset from the nozzle though.
