    DueUI Compatibility issues with RRF/DSF 3.5
    DueUI
    736
    • gtj0undefined
      gtj0
      There are some issues related to RRF/DSF 3.5 that I'm currently working on. Right now, you can't run DueUI on an DSF based printer because the way DueUI detects whether you're in DSF or Standalone mode is by trying to issue an "rr_connect" command. That used to fail when the printer was in DSF mode but now succeeds and returns a JSON response so DueUI thinks it's instandalone mode when it isn't. Fix in progress.
      stuartofmtundefined 1 Reply Last reply Reply Quote 1
      • stuartofmtundefined
        stuartofmt @gtj0
        @gtj0
        I'm confused, blind, or both ... well, I'm often confused 🙂
        I too, in my projects check for rr_connect to detect standalone and if that fails, I try /machine/connect to detect SBC.
        I've looked at the various release notes (and googled etc) but cannot see anything about rr_connect being implemented for SBC in 3.5. Can you point me to the reference?
        In any case, what about reversing the order i.e. check for /machine/connect first and then, if it fails, check for rr_connect.
        ... or do you have a cunning plan ?
        • chrishammundefined
          chrishamm administrators @stuartofmt
          @stuartofmt See here:
          - Added rr_ compatibility layer to DuetWebServer (HTTP calls in standalone mode)
          @gtj0 DSF adds isEmulated: true to the rr_connect JSON response, which is checked by DWC on connect. If that key/value pair is present, the connection attempt is aborted and the next connector (for DSF) tries to establish a connection using the other API.
          Duet software engineer
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
            stuartofmt @chrishamm
            @chrishamm said in DueUI Compatibility issues with RRF/DSF 3.5:
            So logically (with minimum code changes) - something like:
            Try connecting with rr_connect
               If isEmulated: true:
                   treat as invalid connection attempt
              Try connecting with /machine/connect
                     get session key etc
            • gtj0undefined
              gtj0
              Yep, I got it sorted. Also had to add the call to /machine/connect to get the sessionKey and add it to all requests and to the websocket open.
              stuartofmtundefined 1 Reply Last reply Reply Quote 2
                stuartofmt @gtj0
                @gtj0
                Have you release an updated version ?
                • gtj0undefined
                  gtj0 @stuartofmt
                  @stuartofmt said in DueUI Compatibility issues with RRF/DSF 3.5:
                  @gtj0
                  Oy. I fixed it but then forgot to release it. Another victory for ADHD.
                  Will get it published today.
                  gtj0undefined 1 Reply Last reply Reply Quote 1
                  • gtj0undefined gtj0 referenced this topic
                  • gtj0undefined
                    gtj0 @gtj0
                    @gtj0 said in DueUI Compatibility issues with RRF/DSF 3.5:
                    @gtj0
                    Done. Sorry for the delay.
                      stuartofmt @gtj0
                      @gtj0
                      If it's any consolation ... err ... what was I going to say?
