    Z Axis 2 Parallel Motors Synchronization
    2.9k
    • jaydevdaveundefined
      jaydevdave
      Even on no-load condition, the two Z motors are not able to generate sufficient torque. Rated current being 1.5A with a torque of 5.5kg/cm2 and using 24V supply. What could be the reason for it? And what could be the solution for the same? Should I increase supply voltage or should use Motors with higher rated current?
      Please find the link to the video wherein no-load condition the z motors are not generating proper torque.
      https://drive.google.com/open?id=1I50zJb8WMD2IF8rmksil2842Gv6Ds2Q4
        deckingman
        No doubt David will be along soon but from that video I'd say there has to be something wrong with either one of the motors or the wiring.
          jaydevdave
          The same motors run when connected on X and Y axis respectively and that too with high speed of 100mm per second.
            @jaydevdave:
            What is the maximum speed at which my printer can run, having stepper motors (1.5A current), torque 5.5kg/cm2 and using external power supply 24V?
            See the link that I posted in my previous reply for how to calculate this.
              @jaydevdave:
              Duet's X Y Z Motor Drivers and its capacity is same or different ?
              All the same.
                jaydevdave
                The same motors run when connected on X and Y axis respectively and that too with high speed of 100mm per second. why so?
                  @jaydevdave:
                  The maximum speed achievable is lower when you have two motors wired in series. But why are you trying to run your Z axis at 100mm/sec? Z doesn't need to move fast.
                    jaydevdave
                    We having two Y motors which have been swapped with the Z axis. So Two Y motors being connected at the Z axis and we need the speed of 100mm/sec.
                    Stepper motors Rating 1.5A
                    Power supply 24V.
                    How can it be achieved?
                      Try connecting them in parallel to just 1 of the connectors instead of in series using both connectors, and setting the current to 2A.
                      EDIT: alternatively, if you have any spare motor driver outputs left, connect them to separate outputs, use M584 to tell the firmware to drive both together, and use the existing current setting.
                        jaydevdave
                        Driving both the motors from a single connection(parallel) instead of two is safe? I hope it won't burn out the driver right?
                          jaydevdave
                          Tried what dc42 mentioned in the previous comments. We do not have extra driver nor it is working in parallel connection.
                          Should we increase the power supply or should I use 3A rated stepper motors?
                          Current motor having rating of 1.5A
                          Torque 5.5kg/cm2
                          Power supply 24V.
                          How to do it?
                            Like I said, connect them in parallel to a single stepper motor output, and try 2A current. The drivers are current-limited so it is safe.
                            What is the steps/mm for that axis?
                              jaydevdave
                              Alright
                                jaydevdave
                                Can we set motor current to 3A in config ?
                                • elmoretundefined
                                  elmoret
                                  @jaydevdave:
                                  Have you read the documentation?
                                  https://www.duet3d.com/wiki/Choosing_stepper_motors
