    Connecting multiple duets to one SBC
    1.4k
    • benecitoundefined
      benecito @chrishamm
      @chrishamm Will report back after some experimenting, or when running into some issues šŸ˜‰
      • benecitoundefined
        benecito @chrishamm
        @chrishamm
        I just figured out the wiring but can't start a second DCS instance.
        I duplicated /opt/dsf/ in /opt/dsf2/ to keep things separate but also tried the config2.json. As neither of them worked I also tried to start the first (regular) DCS instance with
        sudo systemctl start duetcontrolserver -c /opt/dsf/conf/config.json
        but it returns:
        systemctl: invalid option -- 'c'
        Are you sure this works, or do I need to duplicate something else as well?
        I managed to start one instance on spi4, but figured spi1 und 4 don't work together - will need to search for an alternate wiring scheme I guess...
        • benecitoundefined
          benecito @chrishamm
          @chrishamm
          Managed to rewire to spi3 and have spi0 and spi3 running at the same time now. So just need to figure out how to start the second DCS
          • chrishammundefined
            chrishamm administrators @benecito
            @benecito You need to duplicate the service file and edit it (/usr/lib/systemd/system/duetcontrolserver.service) to start with a different config. Same applies to the duetwebserver service.
            Duet software engineer
            benecitoundefined 1 Reply Last reply Reply Quote 0
            • benecitoundefined
              benecito @chrishamm
              @chrishamm all right - duplicated both of them. Do I need to edit anything but line 6?
              [Unit]
              Description=Duet Control Server
              StartLimitIntervalSec=0
              [Service]
              ExecStart=/opt/dsf2/bin/DuetControlServer
              TimeoutStopSec=15
              Restart=always
              Type=notify
              User=dsf
              Group=dsf
              UMask=0002
              CapabilityBoundingSet=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH CAP_SYS_TIME
              AmbientCapabilities=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH CAP_SYS_TIME
              [Install]
              WantedBy=sysinit.target
                @benecito It won't work that way, because DCS defaults to /opt/dsf/conf/config.json. Use
                ExecStart=/opt/dsf/bin/DuetControlServer -c /opt/dsf2/conf/config.json
                instead. There is no need to copy the entire dsf directory but just conf and sd in it, although it should work nevertheless. You'll need to edit the second duetwebserver service in a similar way, too.
                • benecitoundefined
                  benecito @chrishamm
                  @chrishamm unfortunately it still does not work for me...
                  Also can't really find anything helpful in there.
                  pi@CR-3D-Server:~ $ sudo systemctl start duetcontrolserver2
                  Job for duetcontrolserver2.service failed because the control process exited with error code.
                  See "systemctl status duetcontrolserver2.service" and "journalctl -xe" for details.
                  pi@CR-3D-Server:~ $ systemctl status duetcontrolserver2.service
                  ā— duetcontrolserver2.service - Duet Control Server
                       Loaded: loaded (/lib/systemd/system/duetcontrolserver2.service; disabled; vendor preset: enabled)
                       Active: activating (start) since Wed 2023-05-03 19:00:23 CEST; 1s ago
                     Main PID: 14140 (DuetControlServ)
                        Tasks: 9 (limit: 3597)
                          CPU: 907ms
                       CGroup: /system.slice/duetcontrolserver2.service
                               └─14140 /opt/dsf/bin/DuetControlServer -c /opt/dsf/conf/config2.json
                  May 03 19:00:23 CR-3D-Server systemd[1]: Starting Duet Control Server...
                  May 03 19:00:24 CR-3D-Server DuetControlServer[14140]: Duet Control Server v3.4.1
                  May 03 19:00:24 CR-3D-Server DuetControlServer[14140]: Written by Christian Hammacher for Duet3D
                  May 03 19:00:24 CR-3D-Server DuetControlServer[14140]: Licensed under the terms of the GNU Public License Version 3
                  May 03 19:00:24 CR-3D-Server DuetControlServer[14140]: [info] Settings loaded
                  pi@CR-3D-Server:~ $ journalctl -xe
                  May 03 19:00:57 CR-3D-Server systemd[1]: duetcontrolserver2.service: Failed with result 'exit-code'.
                  ā–‘ā–‘ Subject: Unit failed
                  ā–‘ā–‘ Defined-By: systemd
                  ā–‘ā–‘ Support: https://www.debian.org/support
                  ā–‘ā–‘
                  ā–‘ā–‘ The unit duetcontrolserver2.service has entered the 'failed' state with result 'exit-code'.
                  May 03 19:00:57 CR-3D-Server systemd[1]: Failed to start Duet Control Server.
                  ā–‘ā–‘ Subject: A start job for unit duetcontrolserver2.service has failed
                  ā–‘ā–‘
                  ā–‘ā–‘ A start job for unit duetcontrolserver2.service has finished with a failure.
                  ā–‘ā–‘
                  ā–‘ā–‘ The job identifier is 180062 and the job result is failed.
                  May 03 19:00:57 CR-3D-Server systemd[1]: duetcontrolserver2.service: Scheduled restart job, restart counter is at 2629.
                  ā–‘ā–‘ Subject: Automatic restarting of a unit has been scheduled
                  ā–‘ā–‘
                  ā–‘ā–‘ Automatic restarting of the unit duetcontrolserver2.service has been scheduled, as the result for
                  ā–‘ā–‘ the configured Restart= setting for the unit.
                  May 03 19:00:57 CR-3D-Server systemd[1]: Stopped Duet Control Server.
                  ā–‘ā–‘ Subject: A stop job for unit duetcontrolserver2.service has finished
                  ā–‘ā–‘
                  ā–‘ā–‘ A stop job for unit duetcontrolserver2.service has finished.
                  ā–‘ā–‘
                  ā–‘ā–‘ The job identifier is 180128 and the job result is done.
                  May 03 19:00:57 CR-3D-Server systemd[1]: Starting Duet Control Server...
                  ā–‘ā–‘ Subject: A start job for unit duetcontrolserver2.service has begun execution
                  ā–‘ā–‘
                  ā–‘ā–‘ A start job for unit duetcontrolserver2.service has begun execution.
                  ā–‘ā–‘
                  ā–‘ā–‘ The job identifier is 180128.
                  lines 3564-3600/3600 (END)
                  this is my duetcontrolserver2.service:
                  [Unit]
                  [Service]
                  ExecStart=/opt/dsf/bin/DuetControlServer -c /opt/dsf/conf/config2.json
                  TimeoutStopSec=15
                  Restart=always
                  Type=notify
                  User=dsf
                  Group=dsf
                  UMask=0002
                  [Install]
                    @benecito That log doesn't show quite a lot. Please run journalctl -u duetcontrolserver2 -ef and post the bit that keeps repeating. It may be a good idea to share your second config file as well (config2.json).
                    • benecitoundefined
                      benecito @chrishamm
                      @chrishamm Sorry for the delay - was out of office yesterday.
                      I figured one part out: I messed up the SPI addresses in the config file
                      May 03 20:35:20 CR-3D-Server systemd[1]: duetcontrolserver2.service: Main process exited, code=exited, status=74/IOERR
                      May 03 20:35:20 CR-3D-Server systemd[1]: duetcontrolserver2.service: Failed with result 'exit-code'.
                      May 03 20:35:20 CR-3D-Server systemd[1]: Failed to start Duet Control Server.
                      May 03 20:35:20 CR-3D-Server systemd[1]: duetcontrolserver2.service: Scheduled restart job, restart counter is at 6981.
                      May 03 20:35:20 CR-3D-Server systemd[1]: Stopped Duet Control Server.
                      May 03 20:35:20 CR-3D-Server systemd[1]: Starting Duet Control Server...
                      May 03 20:35:20 CR-3D-Server DuetControlServer[26915]: Duet Control Server v3.4.1
                      May 03 20:35:20 CR-3D-Server DuetControlServer[26915]: Written by Christian Hammacher for Duet3D
                      May 03 20:35:20 CR-3D-Server DuetControlServer[26915]: Licensed under the terms of the GNU Public License Version 3
                      May 03 20:35:21 CR-3D-Server DuetControlServer[26915]: [info] Settings loaded
                      May 03 20:35:21 CR-3D-Server DuetControlServer[26915]: [info] Environment initialized
                      May 03 20:35:21 CR-3D-Server DuetControlServer[26915]: [fatal] Failed to open IO device: Error 2. Can not open SPI device file '/dev/spidev4.0'.
                      May 03 20:35:21 CR-3D-Server systemd[1]: duetcontrolserver2.service: Main process exited, code=exited, status=74/IOERR
                      May 03 20:35:21 CR-3D-Server systemd[1]: duetcontrolserver2.service: Failed with result 'exit-code'.
                      May 03 20:35:21 CR-3D-Server systemd[1]: Failed to start Duet Control Server.
                      May 03 20:35:21 CR-3D-Server systemd[1]: duetcontrolserver2.service: Consumed 1.017s CPU time.
                      May 03 20:35:21 CR-3D-Server systemd[1]: duetcontrolserver2.service: Scheduled restart job, restart counter is at 6982.
                      May 03 20:35:21 CR-3D-Server systemd[1]: Stopped Duet Control Server.
                      May 03 20:35:21 CR-3D-Server systemd[1]: Starting Duet Control Server...
                      May 03 20:35:21 CR-3D-Server DuetControlServer[26968]: Duet Control Server v3.4.1
                      May 03 20:35:21 CR-3D-Server DuetControlServer[26968]: Written by Christian Hammacher for Duet3D
                      May 03 20:35:21 CR-3D-Server DuetControlServer[26968]: Licensed under the terms of the GNU Public License Version 3
                      May 03 20:35:22 CR-3D-Server DuetControlServer[26968]: [info] Settings loaded
                      May 03 20:35:22 CR-3D-Server DuetControlServer[26968]: [info] Environment initialized
                      May 03 20:35:22 CR-3D-Server DuetControlServer[26968]: [fatal] Failed to open IO device: Error 2. Can not open SPI device file '/dev/spidev4.0'.
                      but hat SPI 3 enabled.
                      Figured out one or two more things but am stuck at starting DWC now
                      [Unit]
                      Description=Duet Web Server
                      Wants=duetcontrolserver.service
                      After=network.target duetcontrolserver.service
                      [Service]
                      WorkingDirectory=/opt/dsf2/sd/www
                      ExecStart=/opt/dsf/bin/DuetWebServer --SocketPath /run/dsf/dcs2.sock --urls http://*:8080
                      TimeoutStopSec=15
                      Type=notify
                      User=dsf
                      Group=dsf
                      CapabilityBoundingSet=CAP_NET_BIND_SERVICE
                      AmbientCapabilities=CAP_NET_BIND_SERVICE
                      [Install]
                      WantedBy=multi-user.target
                      and the corresponding config2.json:
                        "AutoUpdateFirmware": true,
                        "PluginSupport": true,
                        "RootPluginSupport": false,
                        "PluginsFilename": "/opt/dsf/conf/plugins.txt",
                        "LogLevel": "info",
                        "SocketDirectory": "/run/dsf",
                        "SocketFile": "dcs2.sock",
                        "StartErrorFile": "/run/dsf/dcs.err",
                        "Backlog": 4,
                        "SocketPollInterval": 2000,
                        "BaseDirectory": "/opt/dsf/sd2",
                        "PluginDirectory": "/opt/dsf/plugins",
                        "NoTerminateOnReset": false,
                        "HostUpdateInterval": 4000,
                        "MaxMessageAge": 60,
                        "SpiDevice": "/dev/spidev3.0",
                        "SpiBufferSize": 8192,
                        "SpiTransferMode": 0,
                        "SpiFrequency": 8000000,
                        "SpiConnectTimeout": 500,
                        "SpiTransferTimeout": 500,
                        "SpiConnectionTimeout": 4000,
                        "MaxSpiRetries": 3,
                        "GpioChipDevice": "/dev/gpiochip0",
                        "TransferReadyPin": 27,
                        "BufferedPrintCodes": 32,
                        "BufferedMacroCodes": 16,
                        "MaxBufferSpacePerChannel": 1536,
                        "MaxCodeBufferSize": 256,
                        "MaxMessageLength": 4096,
                        "FirmwareComments": [
                      but also tried
                      [Unit]
                      [Service]
                      ExecStart=/opt/dsf/bin/DuetWebServer -c /opt/dsf/conf/http2.json
                      TimeoutStopSec=15
                      Type=notify
                      User=dsf
                      Group=dsf
                      [Install]
                      with
                        "Logging": {
                          "LogLevel": {
                            "Default": "Information"
                        "Kestrel": {
                          "Endpoints": {
                            "Http": {
                              "Url": "http://*:8080"
                        "KeepAliveInterval": 30,
                        "SessionTimeout": 8000,
                        "ModelRetryDelay": 5000,
                        "UseStaticFiles": true,
                        "DefaultWebDirectory": "/opt/dsf/sd2/www",
                        "MaxAge": 3600,
                        "SocketPath": "/var/run/dsf/dcs2.sock",
                        "WebSocketBufferSize": 8192
                      both fail with
                      pi@CR-3D-Server:~ $ systemctl status duetwebserver2.service
                      ā— duetwebserver2.service - Duet Web Server
                           Loaded: loaded (/lib/systemd/system/duetwebserver2.service; disabled; vendor preset: enabled)
                           Active: failed (Result: signal) since Fri 2023-05-05 10:29:11 CEST; 5s ago
                          Process: 4310 ExecStart=/opt/dsf/bin/DuetWebServer -c /opt/dsf/conf/http2.json (code=killed, signal=ABRT)
                         Main PID: 4310 (code=killed, signal=ABRT)
                              CPU: 1.121s
                      May 05 10:29:11 CR-3D-Server DuetWebServer[4310]:    at Microsoft.AspNetCore.Hosting.GenericWebHostService.StartAsync(CancellationToken cancellationToken)
                      May 05 10:29:11 CR-3D-Server DuetWebServer[4310]:    at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
                      May 05 10:29:11 CR-3D-Server DuetWebServer[4310]:    at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
                      May 05 10:29:11 CR-3D-Server DuetWebServer[4310]:    at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
                      May 05 10:29:11 CR-3D-Server DuetWebServer[4310]:    at DuetWebServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetWebServer/Program.cs:line 25
                      May 05 10:29:11 CR-3D-Server systemd[1]: duetwebserver2.service: Main process exited, code=killed, status=6/ABRT
                      May 05 10:29:11 CR-3D-Server systemd[1]: duetwebserver2.service: Failed with result 'signal'.
                      May 05 10:29:11 CR-3D-Server systemd[1]: Failed to start Duet Web Server.
                      May 05 10:29:11 CR-3D-Server systemd[1]: duetwebserver2.service: Consumed 1.121s CPU time.
                        @benecito Are you certain that /dev/spidev4.0 exists? Perhaps you need /dev/spidev3.0 instead.
                        It looks like the --urls parameter doesn't work as documented, I just checked this. You need to change the second service file to something like ExecStart=ASPNETCORE_URLS="http://*:8080" /opt/dsf/bin/DuetWebServer --SocketPath /run/dsf/dcs2.sock. Also, it looks like the Kestrel section in /opt/dsf/conf/http.json overrides the ASPNETCORE_URLS setting. I suggest you remove that section in that file and change duetwebserver.service (preferably after copying it to /etc/systemd/system first to avoid issues on upgrade) to ExecStart=ASPNETCORE_URLS="http://*:80" /opt/dsf/bin/DuetWebServer instead.
                        • benecitoundefined
                          benecito @chrishamm
                          @chrishamm this throws
                          May 05 11:20:26 CR-3D-Server systemd[1]: /lib/systemd/system/duetwebserver2.service:8: Neither a valid executable name nor an absolute path: ASPNETCORE_URLS=http://*:8080
                          May 05 11:20:26 CR-3D-Server systemd[1]: duetwebserver2.service: Unit configuration has fatal error, unit will not be started.
                            @benecito Sorry, systemd requires a different format for environment variables:
                            Environment=ASPNETCORE_URLS="http://*:8080"
                            • benecitoundefined
                              benecito @chrishamm
                              @chrishamm
                              Hey,
                              finally managed to get to it again and without printers connected it is working right now.
                              Now just need to sort things in my head and make sure it also works fine with two machines actually printing at the same time.
                              You mentioned I should copy some files to be safe in case of an update here:
                              @chrishamm said in Connecting multiple duets to one SBC:
                              Can you please point out again which files you would recommend to copy where?
                              Over all I created:
                              /etc/systemd/system/duetcontrolserver2.service
                              /etc/systemd/system/duetwebserver2.service
                              /opt/dsf/sd2/ (as a duplicate of /opt/dsf/sd/)
                              /opt/dsf/conf/config2 .json (as a mostly duplicate of /opt/dsf/conf/config.json)
                              and edited:
                              /etc/systemd/system/duetwebserver.service
                              I assume the ones I edited but did not duplicate should be duplicated as well?
                                @benecito That structure sounds reasonable to me. The service files come from /usr/share/systemd/system AFAIR.
                                benecitoundefined 2 Replies Last reply Reply Quote 0
                                • benecitoundefined
                                  benecito @chrishamm
                                  @chrishamm quick update (and question)
                                  We finally finished the test setup with actual printers connected. Unfortunately on pretty much any print one of the looses it's connection with a "Waiting for transfer ready pin" message.
                                  Right now the wires are about 25cm long but well away from any other cables. We're trying to rearrange the setup to be able to use shorter cables but not sure if that's actually the issue.
                                  Can it be somehow related to two SPI connections running at quite a bit of throughput on the same pi and thus some timing errors or so happening? In all cases the connection is back less than a second after.
                                  Happy to hear any thoughts and maybe still get them running reliably!
                                  • benecitoundefined
                                    benecito @chrishamm
                                    @chrishamm Any thoughts on this?
                                    We now tried to run the Duets over SBC but print over USB. This went well so far but haven't run any long term tests.
                                    Therefore to me it sounds like a timing issue related to the transfer ready pin with the increased throughput of printing over SBC.
                                    Can you confirm if the USB print does not go trough the SBC connection back and forth?
                                    Still we would prefer to also print over SBC as we would have the whole ObjectModel available here.
                                      @benecito Hard to say. Do you get any TfrRdy glitches in the M122 diagnostics? If yes, there is probably noise on the TfrRdy line causing the culprit. Try shielding the transfer cables and see if that makes a difference. If that doesn't work, consider trying out a different GPIO pin on the Pi side, perhaps even from a different gpiochip device if possible.
                                      • benecitoundefined
                                        benecito @chrishamm
                                        @chrishamm now I was able to reproduce this. It might be a little different this time as DWC showed as disconnected at first but then eventually came back to life.
                                        That's the M122 diagnostics:
                                        M122
                                        RepRapFirmware for Duet 3 Mini 5+ version 3.4.5 (2022-11-30 19:41:16) running on Duet 3 Mini5plus WiFi (SBC mode)
                                        Board ID: N5HL0-0P6KL-K65J0-409N2-M612Z-7NY58
                                        Used output buffers: 1 of 40 (27 max)
                                        Static ram: 103652
                                        Dynamic ram: 99256 of which 204 recycled
                                        Never used RAM 34400, free system stack 118 words
                                        Tasks: SBC(ready,13.3%,434) HEAT(notifyWait,0.5%,326) Move(notifyWait,2.1%,265) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.2%,341) TMC(notifyWait,11.4%,106) MAIN(running,58.4%,557) IDLE(ready,0.1%,30) AIN(delaying,13.9%,263), total 100.0%
                                        Owned mutexes: HTTP(MAIN)
                                        Last reset 23:39:07 ago, cause: power up
                                        Last software reset at 2023-08-01 09:44, reason: User, GCodes spinning, available RAM 35960, slot 0
                                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
                                        Error status: 0x00
                                        MCU revision 3, ADC conversions started 85147781, completed 85147780, timed out 0, errs 0
                                        Step timer max interval 1490
                                        MCU temperature: min 31.4, current 38.1, max 52.0
                                        Supply voltage: min 23.4, current 23.8, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                        Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/106/0, gc cycles 0
                                        Events: 0 queued, 0 completed
                                        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 24846, writes 24, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 24846, writes 24, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 24845, writes 24, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6a
                                        Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 24846, writes 24, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 4: standstill, SG min 0, read errors 1, write errors 0, ifcnt 24, reads 24845, writes 24, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 5: not present
                                        Driver 6: not present
                                        Date/time: 2023-08-09 08:35:44
                                        Slowest loop: 56.65ms; fastest: 0.09ms
                                        === Storage ===
                                        Free file entries: 10
                                        SD card 0 not detected, interface speed: 0.0MBytes/sec
                                        DMs created 83, segments created 56, maxWait 39571259ms, bed compensation in use: none, comp offset 0.000
                                        === MainDDARing ===
                                        Scheduled moves 151579, completed 151579, hiccups 0, stepErrors 0, LaErrors 0, Underruns [3160, 0, 1], CDDA state -1
                                        === AuxDDARing ===
                                        Heater 1 is on, I-accum = 0.0
                                        Segments left: 0
                                        Movement lock held by null
                                        Telnet* is idle in state(s) 0
                                        File is idle in state(s) 0
                                        USB is idle in state(s) 0
                                        Aux is idle in state(s) 0
                                        Queue* is idle in state(s) 0
                                        LCD is idle in state(s) 0
                                        SBC is idle in state(s) 0
                                        Daemon is idle in state(s) 0
                                        Aux2 is idle in state(s) 0
                                        Code queue is empty
                                        === CAN ===
                                        Messages queued 766304, received 0, lost 0, boc 0
                                        Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 425738/0/0
                                        Tx timeouts 0,0,425737,0,0,340565 last cancelled message type 4514 dest 127
                                        === SBC interface ===
                                        Transfer state: 5, failed transfers: 0, checksum errors: 0
                                        RX/TX seq numbers: 545/545
                                        SPI underruns 0, overruns 0
                                        State: 5, disconnects: 2, timeouts: 2 total, 2 by SBC, IAP RAM available 0x0f1bc
                                        Buffer RX/TX: 0/0-0, open files: 0
                                        === Duet Control Server ===
                                        Duet Control Server v3.4.5
                                        Code buffer space: 4096
                                        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                                        Full transfers per second: 38.41, max time between full transfers: 190.0ms, max pin wait times: 40.1ms/1.4ms
                                        Codes per second: 2.74
                                        Maximum length of RX/TX data transfers: 6836/368
                                        And the end of the log file from the RepetierServer print should it be of any help:
                                        Send:21:14:35.295: N160496 G1 X183.139 Y141.32 E14.18028
                                        Send:21:14:35.295: N160497 G1 X183.746 Y141.494 E14.19944
                                        Recv:21:14:35.338: ok
                                        Send:21:14:35.338: N160498 G1 X184.369 Y141.6 E14.2186
                                        Recv:21:14:35.607: ok
                                        Send:21:14:35.607: N160499 G1 X185 Y141.636 E14.23776
                                        Recv:21:14:35.693: ok
                                        Send:21:14:35.693: N160500 G1 X185.631 Y141.6 E14.25692
                                        Recv:21:14:35.968: ok
                                        Send:21:14:35.968: N160501 G1 X186.254 Y141.494 E14.27608
                                        Recv:21:14:36.003: ok
                                        Send:21:14:36.003: N160502 G1 X186.861 Y141.32 E14.29524
                                        Exec:21:14:38.589: @getip
                                        Send:21:14:38.592: N160503 M117 192.168.187.49:3344
                                        Recv:21:14:38.693: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                                        Recv:21:14:38.693: Connection to Duet established
                                        Recv:21:14:38.696: start
                                        Send:21:14:38.696: N1 M110
                                        Exec:21:14:59.348: @call RHRead timer30 "null"
                                        Mesg:21:15:09.696: Warning: Communication timeout - resetting communication buffer.
                                        Mesg:21:15:09.696: This means that a expected firmware response was not seen within the expected time.
                                        Mesg:21:15:09.696: The typical reason is a communication error and print should continue after the communication reset.
                                        Mesg:21:15:09.696: Connection status: Buffered:8, Manual Commands: 30, Job Commands: 0
                                        Mesg:21:15:09.696: Buffer used:8 Enforced free byte:17 lines stored:1
                                        Offl:21:54:53.881: Ignored (offline):M119
                                        Exec:21:54:53.881: @syncAckState
                                        Offl:21:54:53.881: Ignored (offline):M117 Finished
                                        Offl:21:54:53.881: Ignored (offline):M105
                                        Offl:21:54:53.881: Ignored (offline):M115
                                        Offl:21:54:53.881: Ignored (offline):M114
                                        Offl:21:54:53.881: Ignored (offline):T0
                                        Since it has now been reproduced I'll look into some rewiring. I don't think it's noise though as the SBC wire bundle right now goes trough mid air to rule that out and we also tried shielded ethernet cables for that exact reason.
                                        • PrintManundefined
                                          PrintMan @benecito
                                          @benecito have you tried DuetPrintFarm? I'm waiting for their feature
                                          • benecitoundefined
                                            benecito @PrintMan
                                            @PrintMan what's DuetPrintFarm?
