    Problems with WIFI in Duet 3 Mainboard 6HC
    • Duncanundefined
      Duncan
      we bought in E3D-Online a Duet 3 Mainboard 6HC and WIFI stops working after a few months, started to lost the configuration of wifi and now we can't make it work anyway.
      It's updated to the latest firmware and we can't make wifi works, see photo.
      Anny suggestions?
      Thanks
      dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @Duncan
        @Duncan if it's starting up in SBC mode that means the SD card isn't being read at startup.
          droftarts administrators @Duncan
          @Duncan From the M115, it's a Mini 5+, not a 6HC. As @dc42 says, most likely it is not reading the SD card, so the Duet assumes it is connected to a Raspberry Pi.
          See the following troubleshooting section: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
          Try a fresh SD card, following the instructions further up the page of the link above to format and setup the card for Duet. If that doesn't help, take a picture of the area around the SD card slot on the Duet board; we have had a few boards that have had component failures in this area, though it is rare.
          • Duncanundefined
            Duncan
            Hello again,
            thank you so much, we just follow all the steps and WIFI is working again.
            Thanks 🙂
            • dc42undefined dc42 marked this topic as a question
            • dc42undefined dc42 has marked this topic as solved
