talked to oznest
481
    gardon64
    hi my duet 3 6xd wont boot it cannot be found on my pc they asked me to use the delete jumper done 6 times can yo help me
    undefined 1 Reply Last reply 17 May 2023, 14:57 Reply Quote 0
      droftarts administrators @gardon64
      @gardon64 The delete jumper deletes the firmware. You will need to follow the instructions here to flash the firmware to your board: https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
      However, before doing this, check what LEDs come on when you connect USB power to the board. Follow the troubleshooting guide here, and report back what works/doesn't work: https://docs.duet3d.com/User_manual/Troubleshooting/Duet_wont_respond
        gardon64
        thank you for that
        next to usb red then green then third red
          gardon64
          bossa downloaded but cannot install
          undefined 1 Reply Last reply 17 May 2023, 15:54 Reply Quote 0
            dc42 administrators @gardon64
            @gardon64 what error message do you get when you try to install it?
            undefined 1 Reply Last reply 17 May 2023, 18:25 Reply Quote 0
              gardon64 @dc42
              @dc42 no exe file
              undefined 1 Reply Last reply 17 May 2023, 18:37 Reply Quote 0
                @gardon64 download Bossa.exe from here: https://github.com/Duet3D/BOSSA/releases/tag/1.9.1a-duet3d
                  gardon64
                  thanks for the help this is where i got it from git hub
                    What exactly happens when you follow the steps in this link?
                      gardon64
                      Thanks for the help board running I have set up 1 stepper motor and driver to test stepper but dose not run software said it moveing but not .sorry for being so thick pls help
                      undefined 1 Reply Last reply 19 May 2023, 11:31 Reply Quote 0
                        @gardon64 It is almost impossible to support you when you supply so little information. See https://forum.duet3d.com/post/53522 for a list of information we need to help you. All we know so far is:
                        • You have a Duet 3 6XD
                        • You have managed to get some version of the firmware and Duet Web Control (DWC) working on it
                        • You are using an external driver and stepper motor
                        At the very least, we need to know:
                        • What version of RRF you installed (send M122 and post the response)
                        • What stepper driver you are using, with a link to the datasheet
                        • The config.g you are using (contains details of how the drive is setup)
                        • How you have wired the stepper driver to the 6XD
                        • From turning on, what commands are you sending to replicate the problem
                        There are a number of other threads dealing with external stepper drivers recently, and the issue is usually either the wiring to enable the driver or the stepper driver timing, for example:
                        https://forum.duet3d.com/topic/32437/external-driver-and-duet-1xd-issues
                        Really, Ooznest should not have told you to delete the firmware from the board. It's highly unlikely that is what caused the initial problem.
                          gardon64
                          hear is the m122 result
                          console.txt config.g
                          using dm542t drivers
                          wired up as in stepper motor on duet 3d for duet 3 6xd with sbc
                          sending m564 so ho first
                          then using x- and + on duet three
                          hear the motor make a sound but will not move
                            gardon64
                            hear is the data sheet DM542T_V4.0.pdf
                              @gardon64 Okay, so the stepper driver is connected to the 6XD driver 1 outputs? How have you wired it? Like in the documentation here: https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6XD_Hardware_Overview#connecting-external-motor-drivers ?
                              Post a picture if it helps.
                              How are the jumpers on the external stepper driver set?
                              Your config.g has no stepper driver timings, so it will be using the default, which are too fast for the external driver. According to the data sheet (page 10):
                              a) t1: ENA must be ahead of DIR by at least 200ms. Usually, ENA+ and ENA- are NC (not connected). See “Connector P1 Configurations” for more information.
                              b) t2: DIR must be ahead of PUL effective edge by 5us to ensure correct direction;
                              c) t3: Pulse width not less than 2.5us;
                              d) t4: Low level width not less than 2.5us;
                              e) Duty cycle of Pulse signal is recommend 50%
                              So try:
                              M569 P0.0 S1 T5:5:10:10                            ; physical drive 0.0 goes forwards
                              Also disconnect the enable wires as the driver expects these to be not connected by default. If you want to try keeping them connected, add R0 or R1 to the M569 command above.
                              This is pretty much exactly what was described in the post I linked in my earlier reply.
                                gardon64
                                Steppers now turning thank you so much
                                • undefined Phaedrux marked this topic as a question 19 May 2023, 19:51
                                • undefined Phaedrux has marked this topic as solved 19 May 2023, 19:51
                                4 out of 15
