    Updating a Duet2Wifi DuetWifiServer
    Firmware installation
    1.1k
      Phaedrux Moderator @Milan R
      @Milan-R said in Updating a Duet2Wifi DuetWifiServer:
      i was wondering, if it was searching a "Firmware" Folder on the SD Card, so i created that folder and copied the DuetWifiServer.bin file into this folder too. Still didn´t work.
      Yes after version 3.3 the firmware files are located in a firmware folder on the root of the SD card.
      What error message did it give this time after putting the bin in the firmware folder?
      Milan Rundefined 1 Reply Last reply Reply Quote 0
      • Milan Rundefined
        Milan R @Phaedrux
        Hello @Phaedrux
        i just tested it again to be sure it is the following error:
        M997 S1
        Error: M997: File 0:/firmware/DuetWiFiServer.bin not found<LF>ok<LF>
        The .bin File is on the SD Card in a Folder "Firmware" that i created.
        Is it Possible, that the folder should be created while the instalation of the newer Firmware?
        And i read somewhere to rename or not rename the file. Do i have to give it a diverent name? But the Errorcode says it is searich for a file without the Version number.
        I was wondering, if there are other files needed on the SD card.
          Can you send M122 in the terminal and copy and paste the results here?
          Can you send M20 P"0:/" as well? This should list the contents of the root of the SD card. Then send M20 P"0:/firmware/"
          • Milan Rundefined
            Milan R @Phaedrux
            @Phaedrux
            First the diagnose command:
            M122
            === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later<LF>Board ID: 08DDM-9FAM2-LW4S4-6J9FL-3S86M-KJSBX<LF>Used output buffers: 1 of 26 (1 max)<LF>=== RTOS ===<LF>Static ram: 23836<LF>Dynamic ram: 73384 of which 0 recycled<LF>Never used RAM 14860, free system stack 193 words<LF>Tasks: NETWORK(ready,7.2%,517) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,88.8%,619) IDLE(ready,3.9%,30), total 100.0%<LF>Owned mutexes: USB(MAIN)<LF>=== Platform ===<LF>Last reset 00:00:20 ago, cause: reset button or watchdog<LF>Last software reset details not available<LF>Error status: 0x00<LF>Step timer max interval 0<LF>MCU temperature: min 28.1, current 28.9, max 29.0<LF>Supply voltage: min 1.3, current 1.4, max 1.4, under voltage events: 0, over voltage events: 0, power good: no<LF>Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0<LF>Events: 0 queued, 0 completed<LF>Driver 0: ok, SG min n/a<LF>Driver 1: ok, SG min n/a<LF>Driv[Warning: Maximal number of characters per line exceeded! Check the line break settings in Terminal > Settings > Text or increase the limit in Terminal > Settings > Advanced.]
            M20 P"0:/"
            Begin file list<LF>System Volume Information<LF>.dropbox.device<LF>firmware<LF>sys<LF>End file list<LF>ok<LF>
            M20 P"0:/firmware/"
            Begin file list<LF>DuetWiFiServer.bin<LF>End file list<LF>ok<LF>
            So it seems to find the .bin file. hmm.
            Milan Rundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            • Milan Rundefined
              Milan R @Milan R
              @Milan-R
              I noticed there was a warning, so i tried to increas the number of characters.
              === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later<LF>Board ID: 08DDM-9FAM2-LW4S4-6J9FL-3S86M-KJSBX<LF>Used output buffers: 1 of 26 (11 max)<LF>=== RTOS ===<LF>Static ram: 23836<LF>Dynamic ram: 73384 of which 0 recycled<LF>Never used RAM 14860, free system stack 193 words<LF>Tasks: NETWORK(ready,7.5%,517) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,92.5%,471) IDLE(ready,0.0%,30), total 100.0%<LF>Owned mutexes: USB(MAIN)<LF>=== Platform ===<LF>Last reset 00:07:54 ago, cause: reset button or watchdog<LF>Last software reset details not available<LF>Error status: 0x00<LF>Step timer max interval 0<LF>MCU temperature: min 28.5, current 29.4, max 29.8<LF>Supply voltage: min 1.3, current 1.3, max 1.4, under voltage events: 0, over voltage events: 0, power good: no<LF>Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0<LF>Events: 0 queued, 0 completed<LF>Driver 0: ok, SG min n/a<LF>Driver 1: ok, SG min n/a<LF>Driver 2: ok, SG min n/a<LF>Driver 3: ok, SG min n/a<LF>Driver 4: ok, SG min n/a<LF>Driver 5: <LF>Driver 6: <LF>Driver 7: <LF>Driver 8: <LF>Driver 9: <LF>Driver 10: <LF>Driver 11: <LF>Date/time: 1970-01-01 00:00:00<LF>Cache data hit count 4294967295<LF>Slowest loop: 2.52ms; fastest: 0.14ms<LF>I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0<LF>=== Storage ===<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest read time 0.8ms, write time 0.0ms, max retries 0<LF>=== Move ===<LF>DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000<LF>=== MainDDARing ===<LF>Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1<LF>=== AuxDDARing ===<LF>Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1<LF>=== Heat ===<LF>Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0<LF>=== GCodes ===<LF>Segments left: 0<LF>Movement lock held by null<LF>HTTP is idle in state(s) 0<LF>Telnet is idle in state(s) 0<LF>File is idle in state(s) 0<LF>USB is ready with "M122" in state(s) 0<LF>Aux is idle in state(s) 0<LF>Trigger is idle in state(s) 0<LF>Queue is idle in state(s) 0<LF>LCD is idle in state(s) 0<LF>Daemon is idle in state(s) 0<LF>Autopause is idle in state(s) 0<LF>Code queue is empty<LF>=== Network ===<LF>Slowest loop: 0.20ms; fastest: 0.00ms<LF>Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)<LF>HTTP sessions: 0 of 8<LF>= WiFi =<LF>Network state is disabled<LF>WiFi module is disabled<LF>Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485<LF>Socket states: 0 0 0 0 0 0 0 0<LF>ok<LF>
                You need to change the line endings.
                We need to see the end of the M122 report because that's where it reports the wifi module info.
                • Milan Rundefined
                  Milan R @Phaedrux
                  @Phaedrux
                  I hope it is everything this time. But i can read something about Wifi at the end so i hope thats it.
                  M122<CR>
                  Static ram: 23836
                  Never used RAM 14860, free system stack 184 words
                  Tasks: NETWORK(ready,7.5%,517) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,91.9%,620) IDLE(ready,0.6%,30), total 100.0%
                  Last reset 00:02:13 ago, cause: power up
                  Error status: 0x00
                  MCU temperature: min 26.5, current 31.3, max 31.5
                  Supply voltage: min 0.5, current 1.4, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
                  Driver 5:
                  Driver 6:
                  Driver 7:
                  Driver 8:
                  Driver 9:
                  Driver 10:
                  Driver 11:
                  Slowest loop: 2.22ms; fastest: 0.14ms
                  === Storage ===
                  SD card longest read time 0.6ms, write time 0.0ms, max retries 0
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  Code queue is empty
                  === Network ===
                  Slowest loop: 0.18ms; fastest: 0.00ms
                  = WiFi =
                  ok
                    Can you extract the full contents of this zip file into your firmware folder?
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
                    Then try sending these commands and report back what they return.
                    M552
                    M552 S-1
                    M552 S0
                    M552 S1
                    M997 S1
                    • Milan Rundefined
                      Milan R @Phaedrux
                      @Phaedrux
                      M552
                      ok
                      M552 S-1
                      ok
                      M552 S0
                      ok
                      M552 S1
                      Turn off the current WiFi mode before selecting a new one
                      ok
                      M997 S1
                      ok
                      • Milan Rundefined
                        Milan R @Milan R
                        @Milan-R
                        "WiFi module started
                        Error: failed to initialise WiFi module: bad reply format version"
                        This Message Came after some secounds too.
                        Complete answer to the M997 S1:
                        M997 S1
                        ok
                        WiFi module started
                          Do you have a new SD card to test with? Formatted as FAT32.
                          • Milan Rundefined
                            Milan R @Phaedrux
                            Hello @Phaedrux ,
                            The SD Card i used was FAT32 already, but i have a 32GB FAT 32 that i just tested, unfortunatly the result of the:
                            M552
                            M552 S-1
                            M552 S0
                            M552 S1
                            M997 S1
                            Commands were the same:
                            M552
                            ok
                            M552 S-1
                            ok
                            M552 S0
                            ok
                            M552 S1
                            ok
                            M997 S1
                            ok
                            WiFi module started
                              Do you still have the wifi server bin file in the sys folder as well?
                              Try M997 S1 P"0:/sys/DuetWiFiServer.bin"
                              • Milan Rundefined
                                Milan R @Phaedrux
                                @Phaedrux
                                after the SD Card Swap there was only the files from the Zip file in the firmware folder.
                                But now i copied the firmware folder and called it sys.
                                I tried the command in YAT:
                                <LF>
                                Trying to connect at 230400 baud: success<LF>Erasing 8192 bytes...<LF>Erasing 269216 bytes...<LF>Uploading file...<LF>5% complete<LF>10% complete<LF>15% complete<LF>20% complete<LF>25% complete<LF>30% complete<LF>35% complete<LF>40% complete<LF>45% complete<LF>50% complete<LF>55% complete<LF>60% complete<LF>65% complete<LF>70% complete<LF>75% complete<LF>80% complete<LF>85% complete<LF>90% complete<LF>95% complete<LF>Upload successful<LF>ok<LF>
                                  Ok so that's promising. The firmware was updated successfully.
                                  Can you now try the same sequence of commands?
                                  M552
                                  M552 S-1
                                  M552 S0
                                  M552 S1
                                  Have you tried adding an SSID with M587 yet? https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m587-add-wifi-host-network-to-remembered-list-or-list-remembered-networks
                                  Not sure why your firmware folder didn't work before. I think you have something wrong with your SD card folder structure.
                                  See here for details on what folders are required to be present on the SD card: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
                                  • Milan Rundefined
                                    Milan R @Phaedrux
                                    @Phaedrux
                                    Unfortonatly something still went wrong, the error messages do not give me a clue to what it might be.
                                    M552
                                    ok
                                    M552 S-1
                                    ok
                                    M552 S0
                                    ok
                                    WiFi module started
                                    M552 S1
                                    ok
                                    Error: WiFi module reported: no known networks found
                                    WiFi module is idle
                                    WiFi module is idle
                                    M587 S"MyWifi" P"MyPW"
                                    Error: M587: Failed to add SSID to remembered list: SPI timeout
                                    ok
                                    Error: failed to retrieve WiFi status message: SPI timeout
                                    WiFi module is idle
                                    Error: failed to change WiFi mode: SPI timeout
                                    "Error: WiFi module reported: no known networks found
                                    WiFi module is idle"
                                    This message comes now quite often. Before today i never had this, but i read that it is not unusual.
                                    I even did the reformating the 4 GB SD Card.
                                      Well the module is responding now.
                                      Can you send M122 again and share the results again?
                                      Please send M588 S"*" to clear out any saved networks and try adding again.
                                      • Milan Rundefined
                                        Milan R @Phaedrux
                                        @Phaedrux
                                        thats good to hear, that it is moving into the right direction.
                                        M122
                                        Static ram: 23836
                                        Dynamic ram: 74792 of which 20 recycled
                                        Never used RAM 13432, free system stack 193 words
                                        Tasks: NETWORK(ready,8.6%,335) HEAT(notifyWait,0.0%,353) Move(notifyWait,0.0%,363) MAIN(running,91.3%,458) IDLE(ready,0.0%,30), total 100.0%
                                        Last reset 00:01:29 ago, cause: reset button or watchdog
                                        Error status: 0x00
                                        Aux0 errors 0,0,0
                                        MCU temperature: min 32.6, current 32.8, max 33.7
                                        Driver 5:
                                        Driver 6:
                                        Driver 7:
                                        Driver 8:
                                        Driver 9:
                                        Driver 10:
                                        Driver 11:
                                        Cache data hit count 3638083520
                                        Slowest loop: 2.24ms; fastest: 0.14ms
                                        === Storage ===
                                        === MainDDARing ===
                                        === AuxDDARing ===
                                        Segments left: 0
                                        Code queue is empty
                                        === Network ===
                                        Slowest loop: 99.91ms; fastest: 0.00ms
                                        = WiFi =
                                        Failed messages: pending 0, notready 0, noresp 3
                                        ok
                                        For the other command:
                                        M588 S""
                                        Error: M588: Failed to reset the WiFi module to factory settings: WiFi module is disabled
                                        ok
                                        M552
                                        ok
                                        M552 S-1
                                        ok
                                        M552 S0
                                        ok
                                        WiFi module started
                                        M588 S"
                                        ok
                                        i´m waiting for your response before trying to safe an other network again. Not that I undo something by accident
                                          Can you send M552 S1 and then send M122?
                                          M588 S""
                                          There needs to be an * between the quotes.
                                          • Milan Rundefined
                                            Milan R @Phaedrux
                                            @Phaedrux
                                            weird it was in Yat but somehow got lost.
                                            Well but i tried:
                                            M588 S"*"
                                            M552 S1
                                            M122
                                            M588 S""
                                            ok
                                            M552 S1
                                            ok
                                            WiFi module is idle
                                            WiFi module is idle
                                            WiFi module is idle
                                            WiFi module is idle
                                            M122
                                            Static ram: 23836
                                            Tasks: NETWORK(ready,7.6%,335) HEAT(notifyWait,0.0%,349) Move(notifyWait,0.0%,363) MAIN(running,92.4%,458) IDLE(ready,0.0%,30), total 100.0%
                                            Last reset 00:51:52 ago, cause: reset button or watchdog
                                            Error status: 0x00
                                            Aux0 errors 0,0,0
                                            MCU temperature: min 32.5, current 36.3, max 36.5
                                            Supply voltage: min 1.3, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
                                            Driver 5:
                                            Driver 6:
                                            Driver 7:
                                            Driver 8:
                                            Driver 9:
                                            Driver 10:
                                            Driver 11:
                                            Slowest loop: 99.50ms; fastest: 0.14ms
                                            === Storage ===
                                            SD card longest read time 2.0ms, write time 0.0ms, max retries 0
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Segments left: 0
                                            Code queue is empty
                                            === Network ===
                                            Slowest loop: 1.35ms; fastest: 0.00ms
                                            = WiFi =
                                            Network state is changingMode
                                            WiFi module is idle
                                            Failed to get WiFi status
                                            ok
                                            WiFi module is idle
                                            M588 S"
                                            ok
