Unsolved Reboots/resets randomly - RRF 3.5.0-b4
The printer haven't restartet (yet), but i just tried another print (one object) and it stopped extruding again!
Now it stopped on more or less the first print line on the first layer, and started agian in the second layer (then i canceled the print).M122's from when it's not extruding:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.3+ (2023-05-09 10:59:17) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 4 of 40 (40 max) === RTOS === Static ram: 101720 Dynamic ram: 130896 of which 228 recycled Never used RAM 4860, free system stack 134 words Tasks: NETWORK(ready,224.7%,179) HEAT(nWait,0.7%,327) Move(nWait,0.4%,270) CanReceiv(nWait,1.2%,772) CanSender(nWait,0.0%,327) CanClock(delaying,0.2%,341) TMC(nWait,30.8%,74) MAIN(running,62.8%,335) IDLE(ready,10.7%,29) AIN(delaying,21.2%,266), total 352.6% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 16:32:12 ago, cause: software Last software reset at 2023-06-01 00:47, reason: User, Gcodes spinning, available RAM 13792, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 59533190, completed 59533190, timed out 0, errs 0 MCU temperature: min 33.9, current 45.6, max 46.0 Supply voltage: min 23.1, current 23.5, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/1260/772, gc cycles 2264 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 39, reads 38057, writes 51, timeouts 0, DMA errors 0, CC errors 0 Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 39, reads 38056, writes 51, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 167, reads 38078, writes 29, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 168, reads 38078, writes 29, timeouts 0, DMA errors 0, CC errors 0 Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 167, reads 38079, writes 29, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 38098, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 38097, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-06-01 17:19:31 Cache data hit count 4294967295 Slowest loop: 239.37ms; fastest: 0.08ms === Storage === Free file entries: 16 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 9.0ms, write time 62.2ms, max retries 0 === Move === DMs created 83, segments created 29, maxWait 58897889ms, bed compensation in use: mesh, comp offset 0.000 next step interrupt due in 45 ticks, enabled === DDARing 0 === Scheduled moves 364, completed 358, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X181.195 Y162.316 E1.347" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is doing "M0" in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 538684, received 1190889, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 275, free buffers 18 (min 14), ts 297665/297664/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 216.97ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 = WiFi = Network state is active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43000 WiFi IP address 192.168.10.50 Signal strength -50dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-beta.3+ (2023-05-09 13:40:30) Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 4232, free system stack 38 words Tasks: Move(nWait,0.1%,93) HEAT(nWait,13.2%,57) CanAsync(nWait,0.0%,53) CanRecv(nWait,0.3%,74) CanClock(nWait,0.5%,67) ACCEL(nWait,0.0%,53) TMC(nWait,80.4%,57) MAIN(running,128.9%,346) IDLE(ready,0.0%,27) AIN(delaying,128.5%,142), total 351.9% Last reset 16:32:19 ago, cause: software Last software reset data not available Driver 0: pos 0, 568.8 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 67, reads 15903, writes 15, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 229311 Moves scheduled 2515, completed 2515, in progress 0, hiccups 133, step errors 0, maxPrep 1012, maxOverdue 4036, maxInc 2308, mcErrs 0, gcmErrs 0 Peak sync jitter -4/9, peak Rx sync delay 245, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 23.3, current 24.4, max 24.7 MCU temperature: min 40.7C, current 68.1C, max 69.8C Last sensors broadcast 0x00000012 found 2 202 ticks ago, 0 ordering errs, loop time 1 CAN messages queued 1191020, send timeouts 0, received 538754, lost 0, free buffers 37, min 36, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 513, adv 35873/74646 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, other errors 0
Debug log (with the M122 info scrubbed:
2023-06-01 17:17:13 [warn] Started printing file 0:/gcodes/print_job_0.16mm_ABS_0.4n_1h23m.gcode 2023-06-01 17:17:13 [debug] File 0:/gcodes/print_job_0.16mm_ABS_0.4n_1h23m.gcode selected for printing 2023-06-01 17:17:16 [info] M291: - [no title] - Print started, preheating. 2023-06-01 17:17:17 [info] G10 P0 S150 R150 2023-06-01 17:17:17 [debug] T:140.5 /150.0 T0:140.5 /150.0 B:110.2 /110.0 2023-06-01 17:17:18 [debug] T:139.9 /150.0 T0:139.9 /150.0 B:110.2 /110.0 2023-06-01 17:17:19 [debug] T:140.8 /150.0 T0:140.8 /150.0 B:110.2 /110.0 2023-06-01 17:17:20 [debug] T:143.6 /150.0 T0:143.6 /150.0 B:110.1 /110.0 2023-06-01 17:17:21 [debug] T:147.3 /150.0 T0:147.3 /150.0 B:110.1 /110.0 2023-06-01 17:17:23 [warn] HTTP client 192.168.10.100 login succeeded (session key 0) 2023-06-01 17:17:27 [warn] HTTP client 192.168.10.226 login succeeded (session key 0) 2023-06-01 17:17:36 [info] G10 P0 S150.0 2023-06-01 17:17:36 [info] G10 P0 S150.0 2023-06-01 17:17:36 [info] M291: - [no title] - Pre-print mesh probing enabled, probing new bed mesh! 2023-06-01 17:17:36 [debug] Default grid: X10.0:340.0, Y10.0:340.0, Number of points: X12 Y12, 144 points 2023-06-01 17:17:36 [debug] Adaptive grid: X160.918:189.082, Y147.261:202.739, Number of points: X3 Y3, 9 points 2023-06-01 17:17:38 [info] G10 P0 S150.0 2023-06-01 17:17:38 [debug] Z probe trigger height set to -1.361 mm 2023-06-01 17:17:39 [info] M291: - Mesh Probing - Probing now! Please wait... 2023-06-01 17:17:51 [info] G10 P0 S150.0 2023-06-01 17:17:52 [warn] 9 points probed, min error -0.017, max error 0.005, mean -0.007, deviation 0.006 Height map saved to file 0:/sys/heightmap.csv 2023-06-01 17:17:52 [debug] 9 points probed, min error -0.017, max error 0.005, mean -0.007, deviation 0.006 Height map saved to file 0:/sys/heightmap.csv 2023-06-01 17:17:52 [debug] Height map saved to file 0:/sys/adaptive_heightmap.csv 2023-06-01 17:17:54 [info] M291: - Mesh Probing - Done 2023-06-01 17:17:54 [info] G10 P0 S150.0 2023-06-01 17:17:55 [info] G10 P{global.initial_extruder} R{global.hotend_temp} S{global.hotend_temp} 2023-06-01 17:17:55 [debug] T:150.4 /255.0 T0:150.4 /255.0 B:110.0 /110.0 2023-06-01 17:17:56 [debug] T:150.5 /255.0 T0:150.5 /255.0 B:110.0 /110.0 2023-06-01 17:17:57 [debug] T:152.6 /255.0 T0:152.6 /255.0 B:110.0 /110.0 2023-06-01 17:17:58 [debug] T:156.5 /255.0 T0:156.5 /255.0 B:110.0 /110.0 2023-06-01 17:17:59 [debug] T:161.4 /255.0 T0:161.4 /255.0 B:110.0 /110.0 2023-06-01 17:18:00 [debug] T:167.0 /255.0 T0:167.0 /255.0 B:110.0 /110.0 2023-06-01 17:18:01 [debug] T:172.5 /255.0 T0:172.5 /255.0 B:110.0 /110.0 2023-06-01 17:18:02 [debug] T:178.2 /255.0 T0:178.2 /255.0 B:110.0 /110.0 2023-06-01 17:18:03 [debug] T:183.6 /255.0 T0:183.6 /255.0 B:110.0 /110.0 2023-06-01 17:18:04 [debug] T:189.0 /255.0 T0:189.0 /255.0 B:110.0 /110.0 2023-06-01 17:18:05 [debug] T:194.0 /255.0 T0:194.0 /255.0 B:110.0 /110.0 2023-06-01 17:18:06 [debug] T:199.3 /255.0 T0:199.3 /255.0 B:110.0 /110.0 2023-06-01 17:18:07 [debug] T:204.5 /255.0 T0:204.5 /255.0 B:110.0 /110.0 2023-06-01 17:18:08 [debug] T:209.7 /255.0 T0:209.7 /255.0 B:110.0 /110.0 2023-06-01 17:18:09 [debug] T:214.3 /255.0 T0:214.3 /255.0 B:110.0 /110.0 2023-06-01 17:18:10 [debug] T:219.3 /255.0 T0:219.3 /255.0 B:110.0 /110.0 2023-06-01 17:18:11 [debug] T:224.1 /255.0 T0:224.1 /255.0 B:110.0 /110.0 2023-06-01 17:18:12 [debug] T:228.9 /255.0 T0:228.9 /255.0 B:110.0 /110.0 2023-06-01 17:18:13 [debug] T:233.7 /255.0 T0:233.7 /255.0 B:110.0 /110.0 2023-06-01 17:18:14 [debug] T:238.0 /255.0 T0:238.0 /255.0 B:110.0 /110.0 2023-06-01 17:18:15 [debug] T:242.3 /255.0 T0:242.3 /255.0 B:110.0 /110.0 2023-06-01 17:18:16 [debug] T:246.4 /255.0 T0:246.4 /255.0 B:110.0 /110.0 2023-06-01 17:18:17 [debug] T:249.8 /255.0 T0:249.8 /255.0 B:110.0 /110.0 2023-06-01 17:18:18 [debug] T:252.4 /255.0 T0:252.4 /255.0 B:110.0 /110.0 2023-06-01 17:18:19 [info] M291: - [no title] - Purge location, X min: 135.918; Y min: 137.261; Purge move speed: 4.802495; Prepurge speed: 4.158004 2023-06-01 17:18:30 [debug] ABS filament loaded & config applied 2023-06-01 17:18:30 [debug] ABS filament loaded & config applied 2023-06-01 17:18:30 [debug] Maximum printing acceleration 5000.0, maximum travel acceleration 7000.0 mm/sec^2 2023-06-01 17:22:42 [warn] Resume state saved 2023-06-01 17:22:46 [warn] Printing paused at X179.6 Y161.4 Z1.4 2023-06-01 17:22:46 [debug] Printing paused at X179.6 Y161.4 Z1.4 2023-06-01 17:22:57 [debug] Done printing file 2023-06-01 17:22:57 [debug] Done printing file 2023-06-01 17:22:57 [warn] Cancelled printing file 0:/gcodes/print_job_0.16mm_ABS_0.4n_1h23m.gcode, print time was 0h 5m 2023-06-01 17:23:03 [info] G10 P0 R0 S0 2023-06-01 17:23:03 [debug] ABS filament unloaded & pressure advance disabled 2023-06-01 17:23:03 [debug] ABS filament unloaded & pressure advance disabled
@Exerqtor the issue with extrusion on tool boards stopping (actually reversing) is a known issue in 3.5beta3.
@dc42 said in Extruder stops extruding (again) & reboots randomly - RRF 3.5b3+:
Yeah i knew it was in 3.5b3, but i thought the patch in b3+ sorted it out
@Exerqtor OK, I didn't spot that you were running the patched version. There are still some extrusion issues on tool boards in that version.
Ok, if you have any newer binaries thats supposed to fix said issues i would be more than happy to try them if we put it like that
@Exerqtor PS - please run M122 P500 S1 after reset (you can put this in config.g temporarily). This will reduce performance somewhat, but will provide more accurate reset data in the M122 report.
Ok so i checked in on the debuglog now and the printer apparently restarted a couple times last evening (just been standing there collecting dust).
2023-06-02 20:55:23 [warn] HTTP client 192.168.10.100 disconnected power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.3+ (2023-05-09 10:59:17) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 0) 2023-06-02 21:19:35 [warn] Date and time set at power up + 00:00:08 power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.3+ (2023-05-09 10:59:17) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 0) 2023-06-02 21:24:36 [warn] Date and time set at power up + 00:00:08 power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.3+ (2023-05-09 10:59:17) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 0) 2023-06-03 05:24:05 [warn] Date and time set at power up + 00:00:08
Here is the M122:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.3+ (2023-05-09 10:59:17) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 15 of 40 (30 max) === RTOS === Static ram: 101720 Dynamic ram: 123664 of which 0 recycled Never used RAM 13816, free system stack 184 words Tasks: NETWORK(nWait,155.6%,219) HEAT(nWait,0.2%,329) Move(nWait,0.0%,358) CanReceiv(nWait,0.4%,772) CanSender(nWait,0.0%,336) CanClock(delaying,0.1%,341) TMC(nWait,9.8%,108) MAIN(running,107.8%,444) IDLE(ready,3.3%,29) AIN(delaying,6.8%,266), total 284.1% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 07:13:36 ago, cause: software Last software reset at 2023-06-03 05:23, reason: HardFault imprec, Gcodes spinning, available RAM 13792, slot 1 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011b98 Task NETW Freestk 482 ok Stack: 2002be78 00000000 200014e8 0000019f ffffffff 0002f6d1 00034064 810f0000 0002f6bd 00000000 00000000 00000000 20031a6c 00000800 20035760 2002be60 20018250 2002bd05 20018250 2001e438 0002f857 00000000 00000000 00000000 20011c48 00000014 b5dd9f97 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 26016866, completed 26016866, timed out 0, errs 0 MCU temperature: min 33.5, current 36.3, max 37.6 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/468/84, gc cycles 974 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 83, reads 5830, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 83, reads 5830, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 211, reads 5830, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 212, reads 5830, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 211, reads 5831, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 98, reads 5832, writes 10, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6f Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 98, reads 5833, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-06-03 12:37:44 Cache data hit count 4294967295 Slowest loop: 22.63ms; fastest: 0.12ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.2ms, write time 2.1ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 234159, received 520381, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 275, free buffers 18 (min 17), ts 130084/130083/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 19.72ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43000 WiFi IP address 192.168.10.50 Signal strength -54dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor thanks. I made a mistake: the command needed in config.g is M122 P500 S0 not S1. Please make that change and send me the next M122 main board report after that. You can check that the setting is correct by sending M122 P500 without the S parameter - it should report "Write buffer is disabled".
Aha, cool changed it to S0 now and checked, now it's disabled✌
NOW i think "we" got it!2023-06-03 13:59:24 [debug] Write buffer is disabled power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.3+ (2023-05-09 10:59:17) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:07 [warn] HTTP client 192.168.10.100 login succeeded (session key 0) 2023-06-03 15:52:38 [warn] Date and time set at power up + 00:00:07
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.3+ (2023-05-09 10:59:17) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 13 of 40 (28 max) === RTOS === Static ram: 101720 Dynamic ram: 123664 of which 0 recycled Never used RAM 13816, free system stack 184 words Tasks: NETWORK(nWait,68.6%,217) HEAT(nWait,0.1%,327) Move(nWait,0.0%,358) CanReceiv(nWait,0.2%,772) CanSender(nWait,0.0%,336) CanClock(delaying,0.0%,341) TMC(delaying,4.4%,108) MAIN(running,22.0%,444) IDLE(ready,1.5%,29) AIN(delaying,3.1%,266), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 02:09:59 ago, cause: software Last software reset at 2023-06-03 15:52, reason: HardFault bfarValid precise, Platform spinning, available RAM 13816, slot 2 Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x0000001c SP 0x20011b98 Task NETW Freestk 482 ok Stack: 2002be78 20030218 200014e8 00000000 20032c37 0002f6d1 0002f5e4 610f0000 0002f6bd 00000000 00000000 00000000 20030224 00000800 20035760 2002be60 20018250 2002bd05 20018250 2001e438 0002f857 00000000 00000000 00000000 20011c48 00000014 b5dd9f97 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 7800185, completed 7800184, timed out 0, errs 0 MCU temperature: min 35.7, current 36.9, max 40.4 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/1876/1492, gc cycles 291 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 97, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 97, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 225, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 226, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 225, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 109, reads 53698, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 109, reads 53698, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-06-03 18:02:30 Cache data hit count 4294967295 Slowest loop: 21.27ms; fastest: 0.12ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.2ms, write time 2.1ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 70207, received 156041, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 275, free buffers 18 (min 17), ts 39000/38999/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 20.23ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42288 WiFi IP address 192.168.10.50 Signal strength -50dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor thanks again. Please try the Mini5+ RRF file at https://www.dropbox.com/sh/in0t2j68ic66oa8/AADv_6WzRy07H6MhBOrkDt23a?dl=0. Leave the M122 command in config.g, and post the main board M122 main board if it resets again.
Will do, just installed the new binaries. This is just meant to remedy the restart issue right? Not the reversing extruder? -
@Exerqtor this may not remedy the resetting issue, but should remedy any extrusion issues.
Oh thats promising -
@Exerqtor I just remembered you are using a tool board, so I've now put the latest tool board firmware build in the same place.
Happy to say i'm able to melt some plastic for the first time in almost two weeks now with that new build!Looks like it fixed the extrusion issues!
@Exerqtor thanks, let me know ASAP if you get another main board reboot (and provide the M122 report) because I didn't really get to the bottom of that one.
Yeah I will shout out as soon as I see a reset in the debuglog!
Not any extrusion issues, but the print finishes off without completing the print for some reason. It's got status : "Cancelling" with 100% progress. And the printer is somewhat locked up in that state until i manually press Cancel in the status tab of DWC or PD (even though it's ran
stop.g
.This is the last part of the print that just "finished":
G1 X176.576 Y189.748 E.00789 G1 X176.726 Y190.157 E.01028 G1 X176.791 Y190.611 E.01082 G1 X176.764 Y190.87 E.00614 G1 X176.969 Y191.069 F12000 ; stop printing object print_job.stl id:0 copy 0 G10 ; retract ;TYPE:Custom set global.line_type = "Custom" ; Filament-specific end G-code START ; ; Filament specific end G-code: END ; End G-code: START M0 ; End G-code: END M73 P100 R0 ; filament used [mm] = 2401.91 ; filament used [cm3] = 5.78 ; filament used [g] = 6.01 ; filament cost = 1.68 ; total filament used [g] = 6.01 ; total filament cost = 1.68 ; estimated printing time (normal mode) = 1h 23m 7s ; estimated first layer printing time (normal mode) = 2m 51s ; prusaslicer_config = begin ; autoemit_temperature_commands = 0 ; avoid_crossing_curled_overhangs = 0 ; avoid_crossing_perimeters = 0 ; avoid_crossing_perimeters_max_detour = 0
And the debuglog:
2023-06-04 21:42:51 [debug] Done printing file 2023-06-04 21:42:51 [warn] Finished printing file 0:/gcodes/print_job_0.16mm_ABS_0.4n_1h23m.gcode, print time was 1h 12m 2023-06-04 21:42:56 [info] G10 P0 R0 S0 2023-06-04 21:42:56 [debug] ABS filament unloaded & pressure advance disabled 2023-06-04 21:42:56 [debug] ABS filament unloaded & pressure advance disabled
@Exerqtor that appears to be if M0 is used at all then a print gets stuck. Try having stop.g but not using M0 to call it
@jay_s_uk
Oh ok, I'll try that next time. I just started another print but disabled emitting M73's to see if that maybe was the issue. -
New reset yesterday evening while idle:M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.3+ (2023-05-24 17:47:02) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 3 of 40 (30 max) === RTOS === Static ram: 101720 Dynamic ram: 124184 of which 12 recycled Never used RAM 13284, free system stack 182 words Tasks: NETWORK(nWait,218.1%,219) HEAT(nWait,0.3%,327) Move(nWait,0.0%,358) CanReceiv(nWait,0.6%,662) CanSender(nWait,0.0%,337) CanClock(delaying,0.1%,342) TMC(nWait,14.4%,108) MAIN(running,134.0%,442) IDLE(ready,4.9%,29) AIN(delaying,10.1%,266), total 382.5% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 06:55:33 ago, cause: software Last software reset at 2023-06-04 23:50, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 11752, slot 0 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000004 SP 0x20011b98 Task NETW Freestk 482 ok Stack: 0000019f 00000002 200014e8 0000019e 20032ecb 0009bebd 0002f872 810f0000 0002f869 00000000 00000000 00000000 20031cfc 00000800 200359f0 2002c058 20018260 2002bef5 20018260 2001e428 0002fa03 00000000 00000000 00000000 20011c48 00000014 b5dd9f97 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 24933600, completed 24933600, timed out 0, errs 0 MCU temperature: min 34.3, current 35.1, max 42.6 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/1364/980, gc cycles 932 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 249, reads 38425, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 249, reads 38425, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 99, reads 38425, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 100, reads 38424, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 98, reads 38425, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 197, reads 38428, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 197, reads 38428, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-06-05 06:45:47 Cache data hit count 4294967295 Slowest loop: 20.35ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.4ms, write time 3.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 224410, received 498718, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 276, free buffers 18 (min 17), ts 124668/124667/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 20.32ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42988 WiFi IP address 192.168.10.50 Signal strength -61dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
