    Problem with Duet 2 Wifi
    643
    • mesacrashundefined
      mesacrash @Phaedrux
      @Phaedrux Yes, in the sys folder was the config.g file, which was empty.
        Can you send M20 P"/www/" and see what it responds with? It should gives you the contents of the www folder.
        mesacrashundefined 4 Replies Last reply Reply Quote 0
          mesacrash @Phaedrux
          @Phaedrux I can only send via YAT:
          M20 P"/www/"
          Begin file list<LF>NONE<LF>End file list<LF>ok<LF>
            mesacrash @Phaedrux
            @Phaedrux If I put the SD card in my computer, I can see folders and files.
              mesacrash @Phaedrux
              @Phaedrux I remembered that I had an archive of the original SD card. I found there was a folder missing from my operational SD card. I put the folder in it and it still won't work. The board seems to know the SD card is mounted but doesn't recognize there are files on it.
                mesacrash @Phaedrux
                @Phaedrux This is the second time this has happened to me. The board in the machine is a replacement for the first board. 3dWorld replaced the first board, should I contact them, perhaps? The first one lasted about a month. This one has been running about 5 months. And running well, I might add.
                  The first one blew a fuse as well?
                  Can you post some close up photos of the board please? Perhaps we can spot some damage.
                  It would be a good idea to find out what is shorting a damaging the boards before replacing it again.
                  mesacrashundefined 3 Replies Last reply Reply Quote 0
                    mesacrash @Phaedrux
                    @Phaedrux The first one did NOT blow a fuse, however the symptoms are similar. I am very skilled in electronics and I don't find anything that would cause a short. I have replaced the fuse with a 1 amp fuse and it is still good after 4 days. Things other than a short can cause a fuse to blow. Like the board itself.
                    The similarities start and end with the SD card no longer reading the card. The first board lasted a month, yet this one ran for 5 months. This machine has printed a lot of filament, well. I see no reasonable answer for this.
                      mesacrash @Phaedrux
                      @Phaedrux I think I got it. Sometimes a change in the weather will accelerate oxidation between connections. I went through the screw connections, loosened them then tightened them. Boom, it connected and is reading everything. I will test it tomorrow.
                        mesacrash @Phaedrux
                        @Phaedrux It is working fine.
                        • Phaedruxundefined Phaedrux has marked this topic as solved
