After update to 3.5.0-beta.4 - wifi module reported failed
Good afternoon, ladies and gentlemen! I have a duet 2 wifi board
I installed firmware version 3.5.0-beta.4 , files:
Duet2CombinedFirmware.bin
DuetWiFiServer.bin
After that I got no connection with my WiFi.
I connected the terminal, specified the access point again and the system began to connect to my home WiFi, but at startup I still have an error:
"wifi module reported failed"
I also installed the files
DuetWebControl-SD.zip
PanelDueFirmware-3.5.0-rc6-v3-5.0.binPlease help me understand what is the problem.
@Plohish
Are you sure that all updates were completed?
Have you checked the firmware versions in DWC and on the PanelDue? -
@OwenD
Yes, I'm sure everything ended well
My printer is working, it's printing now...
however I don't like this error at the beginning... -
M122
= WiFi =
Interface state: active
Module is connected to access point
Firmware version 2.1beta3
MAC address bc:dd:c2:57:ae:51
Module reset reason: Turned on by main processor, Vcc 3.36, flash size 2097152, free heap 42924
WiFi IP address 172.16.1.50
Signal strength -47dBm, channel 13, mode 802.11n, reconnections 0
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
If the error happens at every restart then please post
- your config.g
- the results of running M98 P"config.g"
- the RRF version you upgraded from
- if you run a daemon.g the contents of that
@OwenD
config.g; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 03 2020 22:57:59 GMT+0300 (Москва, стандартное время) ; General preferences M80 C"pson" G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Uni_Plo" ; set printer name M669 K1 ; select CoreXY mode M575 P1 S1 B57600 ;*** End of factory test lines to be removed ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 Z32 E16 I0 ; configure microstepping without interpolation M350 X16 Y16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z800.00 E414.00 ; set steps per mm ;M566 X600.00 Y600.00 Z40.00 E800.00 P1 ; Максимальный рывок (мм/сек) M205 X15 Y15 Z1 E12 ; Максимальный рывок (мм/сек) M203 X12000.00 Y12000.00 Z800.00 E6000.00 ; Максимальная скорость (мм/мин) ;M201 X1500.00 Y1500.00 Z60.00 E1500.00 ; Максимальное ускорение (мм/сек^2) M201 X2000 Y2000 Z60 E2000 ; Максимальное ускорение (мм/сек^2) M906 X1400 Y1400 Z1350 E700 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X280 Y186 Z288 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop ; Z-Probe ;M558 P5 C"zprobe.in+zprobe.mod" H0 F120 T6000 ; set Z probe type to switch and the dive height + speeds ;G31 P500 X20 Y20 Z0.25 ; set Z probe trigger value, offset and trigger height ;M557 X10:215 Y5:185 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 Q10 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S150 ; set temperature limit for heater 0 to 120C M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 ; M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M308 S1 P"spi.cs1" Y"rtd-max31865" ; create sensor number 1 as a PT100 sensor M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M911 S22.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z7 E-3 F500" ; Automatic power saving M501 ; Custom settings are not defined M98 P"config.g"
HTTP is enabled on port 80 FTP is enabled on port 21 TELNET is disabled Warning: Heater 0 predicted maximum temperature at full power is 321°C Warning: Heater 1 predicted maximum temperature at full power is 670°C I did an update from version 3_4_5
i don't have a file daemon.g -
@Plohish
I don't see any obvious problems there.
As you have updated from 3.4.5 you would have had to reset your access point using M587
I run almost the exact same setup without issues.
About the only difference I see is that I am specifying the SSID and gateway in M552 and M554
Is there any chance there's another WiFi network with a stronger signal? -
@Plohish
Also ensure that it's only trying to connect to a 2.4Ghz network.
If you have a dual band router and both networks have the same SSID it might be trying to connect to the 5.0Ghz network -
@OwenD
Until the update, I did not experience any problems with WiFi.
I have two bands on my router, but they have different SSIDs.
I didn't reset with M587, is that important? -
@Plohish
This is from the change log when wifi 2.1b2 was released.
Same would apply to 2.1b3For WiFi enabled boards, DuetWiFiServer version 2.1beta 2 is included with these files; however you can continue using version 1.27 if you wish. In some systems, version 2.1beta2 may give a lower upload speed than 1.27, however it supports additional features such as WiFi scanning and WPA Enterprise (details to follow) and it may work better with some WiFi access points than 1.27 does. Note, if you do upgrade to 2.1beta2 then you will have to re-enter your access point details using M587.
Maybe try deleting the access points and redoing again?
You'll need to do it via YAT or similarM552 S0
M588 S"*"
M587 S"yourSSID" -
i did only M587 S"your-network-ssid" P"your-network-password"
I will do it
M552 S0
M588 S"*"
M587 S"yourSSID"
if it doesn't work, I'll go back to the old version of WifiServer -
@Plohish
You will need the password in M587 of course
I omitted that -
@OwenD
Unfortunately it didn't help...
I returned to 1.27, no more problems! -
@OwenD
there is another small problem, the printer does not turn off the power at the end of printing
i read this:
The use of M1 to end a job is deprecated. The M1 command no longer runs file sleep.g, instead it runs stop.g like M0. In future we expect to change the behaviour of M1 to be in line with the NIST standard.
what should i use instead of M1 ? -
undefined Phaedrux moved this topic from Firmware installation 11 Jun 2023, 15:47
@Plohish
You should create a stop.g in the /sys directory if you don't already have one.
This will be run at the end of every print job or when M0 is called.
You used to have to call M0 implicitly, but I'm pretty sure in one of the 3.5 betas it started being run automatically.
It should contain your shutdown procedure such as turning off heaters and calling M81
Change your M1 calls to M0 -
@OwenD
The stop.g file is present in my system, I entered the code into it:
M81 S1
It works, I didn't have to change M1 to M0 in the final code -
@Plohish said in After update to 3.5.0-beta.4 - wifi module reported failed:
@OwenD
I returned to 1.27, no more problems!The initial release of 3.5beta4 was posted with the wrong version of DuetWiFiServer firmware; it was 2.1beta3, it has now been updated to 2.1beta4. Can you try that? You will have to connect via USB and re-enter your access point SSID and password using M587.
@droftarts
unfortunately my printer is busy for a few days now, maybe I can do it later... -
I have also seen the same issue using the DuetWiFiServer firmware 2.1beta4 with my Duet2 Wi-Fi, with YAT connected I get SPI errors" unable to get WIFI module status" but on returning to version 1.27 it works ok.
@droftarts
Now I think there is no need to repeat the experiment? boldnuts had the same problem with the 2.1beta4 update...
