    3.5.0-B3 Reboot in Laser mode
    Beta Firmware
    514
      jay_s_uk @cichaczech
      @cichaczech post an output of M122 after the reboot
      • cichaczechundefined
        cichaczech
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-beta.3 (2023-04-14 11:27:37) running on Duet WiFi 1.02 or later
        Board ID: 0JD0M-9P6M2-NW4SS-6JKDD-3S86R-KAZ7L
        Used output buffers: 1 of 26 (15 max)
        Static ram: 22192
        Dynamic ram: 74716 of which 244 recycled
        Never used RAM 15992, free system stack 184 words
        Tasks: NETWORK(nWait,11.0%,238) HEAT(nWait,0.0%,386) Move(nWait,0.0%,364) MAIN(running,80.9%,559) IDLE(ready,8.1%,29), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:00:11 ago, cause: software
        Last software reset at 2023-06-09 12:21, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 15492, slot 2
        Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0041f803 BFAR 0x6b4bd9b0 SP 0x20003b38 Task Move Freestk 379 ok
        Stack: 20008908 00000001 00000270 6b4bd450 a5a5a5a5 0042a6e3 0043cee0 a1000000 00000000 00000000 00000000 00000000 3f800000 00000000 00000000 00000000 2000bcf8 00000000 00000001 2000bcfc 2000487c 00000000 00000000 a5a5a5a5 0042a6e3 a5a5a5a5 a5a5a5a5
        Error status: 0x00
        Aux0 errors 0,0,19
        MCU temperature: min 23.8, current 24.1, max 24.4
        Supply voltage: min 23.6, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min n/a
        Driver 1: standstill, SG min n/a
        Driver 2: standstill, SG min n/a
        Driver 3: standstill, SG min n/a
        Driver 4: standstill, SG min n/a
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Date/time: 2023-06-09 12:21:49
        Cache data hit count 418033720
        Slowest loop: 8.31ms; fastest: 0.19ms
        === Storage ===
        Free file entries: 10
        SD card 0 detected, interface speed: 12.0MBytes/sec
        SD card longest read time 1.0ms, write time 0.0ms, max retries 0
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
        no step interrupt scheduled
        === DDARing 0 ===
        Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
        Movement locks held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is assembling a command in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Q0 segments left 0
        Code queue 0 is empty
        === Filament sensors ===
        Extruder 0 sensor: ok
        === Network ===
        Slowest loop: 111.47ms; fastest: 0.00ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 1 of 8
        = WiFi =
        Network state is active
        Module is connected to access point
        Firmware version 1.27
        MAC address bc:ff:4d:45:e0:c1
        Module reset reason: Power up, Vcc 3.39, flash size 4194304, free heap 27176
        WiFi IP address 10.0.0.120
        Signal strength -59dBm, channel 0, mode 802.11n, reconnections 0
        Clock register 00002002
          dc42 administrators @cichaczech
          @cichaczech as we're in the process of releasing 3.5.0-beta4 please can you test it again using that release and report back. If it happens in beta4 then please post a M122 report after the reset again.
          cichaczechundefined 2 Replies Last reply Reply Quote 0
            cichaczech @dc42
            @dc42 Ok, will do.
            Thank you.
              cichaczech @dc42
              @dc42 still the same
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-beta.4 (2023-06-08 23:39:39) running on Duet WiFi 1.02 or later
              Static ram: 23236
              Dynamic ram: 74836 of which 244 recycled
              Never used RAM 14828, free system stack 184 words
              Tasks: NETWORK(2,nWait,12.2%,238) HEAT(3,nWait,0.0%,385) Move(4,nWait,0.0%,364) MAIN(1,running,81.7%,819) IDLE(0,ready,6.1%,29), total 100.0%
              Last reset 00:00:15 ago, cause: software
              Last software reset at 2023-06-09 17:27, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 14328, slot 0
              Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0041f803 BFAR 0x6b4bddd0 SP 0x20003f60 Task Move Freestk 379 ok
              Stack: 20008d28 00000001 00000270 6b4bd870 a5a5a5a5 004291c3 0043c218 a1000000 00000000 00000000 00000000 00000000 3f800000 00000000 00000000 00000000 2000c168 00000000 00000001 2000c16c 20004bb4 00000000 00000000 a5a5a5a5 004291c3 a5a5a5a5 a5a5a5a5
              Error status: 0x00
              Aux0 errors 0,0,18
              MCU temperature: min 22.9, current 23.5, max 23.6
              Supply voltage: min 23.6, current 23.7, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 5:
              Driver 6:
              Driver 7:
              Driver 8:
              Driver 9:
              Driver 10:
              Driver 11:
              Date/time: 2023-06-09 17:28:13
              Cache data hit count 558914657
              Slowest loop: 8.27ms; fastest: 0.19ms
              === Storage ===
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
              === DDARing 0 ===
              Q0 segments left 0
              === Network ===
              Slowest loop: 111.94ms; fastest: 0.00ms
              = WiFi =
              Interface state: active
              Module reset reason: Power up, Vcc 3.39, flash size 4194304, free heap 27096
                @cichaczech please try again. The stack trace in your M122 report doesn't match the 3.4.0-beta.4 code, so I suspect you were running different firmware when that last reset happened.
                cichaczechundefined 1 Reply Last reply Reply Quote 0
                  cichaczech @dc42
                  @dc42 Today I tried delete old FW and instal beta4 with BOSSA, but it still keeps rebooting when I try to home it.
                  For now I am moving back to last stable release 🙂
                  this is my latest M122
                  Used output buffers: 13 of 26 (20 max)
                  Static ram: 23236
                  Never used RAM 14828, free system stack 186 words
                  Tasks: NETWORK(2,nWait,12.5%,238) HEAT(3,nWait,0.0%,383) Move(4,nWait,0.0%,364) MAIN(1,running,78.8%,819) IDLE(0,ready,8.7%,29), total 100.0%
                  Last reset 00:00:10 ago, cause: software
                  Last software reset at 2023-06-12 09:11, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 14328, slot 2
                  Error status: 0x00
                  Aux0 errors 0,0,18
                  MCU temperature: min 22.2, current 22.7, max 23.0
                  Supply voltage: min 23.7, current 23.7, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 5:
                  Driver 6:
                  Driver 7:
                  Driver 8:
                  Driver 9:
                  Driver 10:
                  Driver 11:
                  Date/time: 2023-06-12 09:11:56
                  Cache data hit count 397729243
                  Slowest loop: 9.39ms; fastest: 0.19ms
                  === Storage ===
                  === DDARing 0 ===
                  Q0 segments left 0
                  === Network ===
                  Slowest loop: 114.56ms; fastest: 0.00ms
                  Responder states: HTTP(0) HTTP(0) HTTP(2) HTTP(0) FTP(0) Telnet(0)
                  HTTP sessions: 3 of 8
                  = WiFi =
                  Firmware version 2.1beta3
                  Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 38084
                  Signal strength -54dBm, channel 1, mode 802.11n, reconnections 0
                  dc42undefined 2 Replies Last reply Reply Quote 0
                    @cichaczech please can you provide your config.g and homing files, so that I can try to reproduce this.
                      @cichaczech I haven't managed to reproduce the problem, but I believe I have identified the issue. It's specific to laser mode. Please try the Duet 2 firmware binary at https://www.dropbox.com/sh/c4aatfdsejjjab0/AACGuZ4qUBvZz49zxErkhmnWa?dl=0 and see if it resolves the problem.
                      I think a workaround for this issue using the original 3.5.0-beta4 firmware binary would be to issue a G1 move with an S parameter after switching to laser mode with M452 but before doing the very first real move (i.e. before homing). Even G1 S0 with no other parameters should be sufficient.
                        cichaczech @dc42
                        @dc42 Both of your solutions work.
                        3.5.0-beta4 -> you have to send G1 S0 after switching laser mode
                        3.5.0-beta4+ -> works normally in laser mode, without any additional commands
                        Thank you.
                          @cichaczech thanks for confirmation! The fix will be included in 3.5.0-rc.1. I'll mark the Github issue I created at https://github.com/Duet3D/RepRapFirmware/issues/869 solved.
                          dc42 created this issue in Duet3D/RepRapFirmware
                          closed [3.5beta3, beta4] Unexpected reset when using laser mode #869
