    laser engrave
    Laser Cutters
    525
      jay_s_uk @yuval
      @yuval in which case to use laser mode you will have to switch RRF into that mode using M452 whenever you need to use the laser https://docs.duet3d.com/User_manual/Reference/Gcodes#m452-select-laser-device-mode
      yuvalundefined 1 Reply Last reply Reply Quote 0
      • yuvalundefined
        yuval @jay_s_uk
        @jay_s_uk im not sure i understand what you said
        As ive wrote above, i am using m452 ("M452 C"out9" R255 F500")
        so, in order to activate the laser, i should send the gcode :
        t2 g1 s255
        and yet, i measure 0v from out9 to ground
        jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
          jay_s_uk @yuval
          @yuval sorry, i misread.
          you can't measure PWM with a voltmeter (not quick enough). you'd need an oscilloscope or the like
          • yuvalundefined
            yuval @jay_s_uk
            @jay_s_uk but wait, if ill try to enable the laser full power, s255, i should read 5v with any voltmeter, shouldnt I?
              jay_s_uk @yuval
              @yuval you should ready 5v at any power level. The only time you shouldn't read anything is when its off
              • yuvalundefined
                yuval @jay_s_uk
                @jay_s_uk i understand.
                i ask you this:
                if i set the pwm to 100%, any volmeter should be able to read the voltage.
                therefore, i think somthing is wrong in my setup, because i read 0v even at 100% power
                  jay_s_uk @yuval
                  @yuval you can test the output using M42 if you're concerned it doesn't work.
                  (until recently) I ran my laser cutter on RRF so I know it works.
                  Are you using the Out9 connector or the VFD/Laser connector?
                  • yuvalundefined
                    yuval @jay_s_uk
                    @jay_s_uk doesnt m42 work only on GPIO?
                    ive tried
                    M42 P"OUT0" S255/S1
                    M42"LASER" S255/S1
                    nothing changed..
                      jay_s_uk @yuval
                      @yuval you have to set the pins up with M950 first as described in the docs to use M42
                      • Phaedruxundefined Phaedrux moved this topic from Duet Hardware and wiring
                      • yuvalundefined
                        yuval @jay_s_uk
                        @jay_s_uk i dont think the laser pin is bad.
                        i think somthing is wrong in my setup.
                        do you have any ideas on what could i do?
                        let's say ill test it with m42 and i see it works, what next? why doesnt it works normally?
                          dc42 administrators @yuval
                          @yuval said in laser engrave:
                          t2 g1 s255
                          The S parameter is intended to be used on G1 commands that also command movement, so you won't get any PWM output unless you command movement in that G1 command; then the laser will be on during that movement.
