Solved Wifi empty
Yes it did change the ssid and I've moved so it's a different network. When I do the M588 it shows the right ssid
Duet wifi 2
So it came up with src/socket server.cpp(353):
Found network wiskers2
(This is correct )
Next line says
No known networks found wifi module idle -
@ziggymanpopo i would clear the wifi networks with
M588 S"*"
and re-add the network withM587
Will do tomorrow bed time for now and thank you for the input
Same. Results as before ho well thought I'd try
it -
Well I'm stuck in scandone and the esp8266 stayed in idle mode after the M552 S1 command
It's saving the network and all other networks were removed once again at a loss but for some reason the thing isn't connecting. I know that the network is up I checked it with my phone. Yat working fine ...also blue led on constantly. -
@ziggymanpopo maybe its time to upgrade the firmware
What perplexed me is it says found network wiskers2. This is correct
But then two lines later it says no known networks found ????? Is it possible that no password was saved -
@ziggymanpopo when it says its been found it means by a scan of the wifi networks, not that its saved in its memory
@ziggymanpopo said in Wifi empty:
I believe the tncapefcc19 is the Wifi ver
And the ver2.02 (rtos) I k own its really old but it's been good and I'm not up to speed yet to kown how to update the firmware ...yet that gonna have to wait a bitThat's not the wifi version. To find the WiFi version, run M122 and look in the WiFi section of the report.
RRF 2.02 is really old so I don't know which version of the WiFi software is the most compatible, but most likely 1.27 is.
Wifi ver 1.22
It's always worked before
Before what? Before you changed your router?
Yes and the board is completely installed I'm thinking that I have the power on. do I need to shut down the printer when I try to save the ssid and password... maybe????? I believe the wifi assword isn't being save somehow???
I also noticed the blue led is on when the printer is on might u have a conflict because with the power on the esp8266 is already fired off???
My thinking was that in config.g already fires up the wifi
Well that wasn't it either
SO FOR OTHERS TO HAVE THIS INFO!!!
After trying several things with the starlink router I did not have any success
I believe that starlinks router can't recognize that I'm working with 2.4g. Even though ther is a switch in ther programing to split out 2.4g.
How I overcame this was to get a network adapter for the starlink system...
Then plugged in a separate router that had band steering (linksys EA8300) which recognized I'm working with 2.4 g. Problem solved
Thanks again for the help guys !!!!
Hope this will help someone else down the line who is dependent on a starlink system. -
@ziggymanpopo glad you got it all sorted
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
