    Duet 2 WiFi Voron 2.4 - Multiple Z endstops query
    666
    • Chaos3dundefined
      Chaos3d
      Hi All, First Time posting here so hopefully this is enough info for you to see the issue I'm having
      First off here is the machine spec
      Heavily modified Voron 2.4 CoreXY design to increase build volume to approx 450mm Cubed (and a few other things)
      20mm Linear rails all round (yes I know thats overkill)
      Duet2 Wifi & Duex5 expansion board
      Paneldue 7i
      4 x Nema 23 Z motors
      2 x Nema 17 for A/B Drive
      1 x E3D Hermes bowden extruder (now known as Hemera)
      E3D V6 hotend with modified Stealthburner
      Will be a custom bed and heater when i get that far!
      I am running :
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later + DueX5
      Duet WiFi Server Version: 1.27
      Duet Web Control 3.4.5
      And this is the machine in its current part built state:
      I have got all the movement working and it homes as I want it to (max level on each axis so head ends up top right at the rear of the printer)
      I have installed 4 endstops one per z motor driver and verified each one triggers (led on duet board and on endstop - endstops are standard design makerbot mechanical v1.2 boards which require me to add the "!" mark in the pin names to inverse the signal to allow the axis movement)
      My current endstop and motor configuration looks like this (and there is a reason for only activating the first 3 endstops on the z axis which I will get to in a second:
      ; drive ---------------------------------------------------
      ;   ----+----   Z-Drives
      ;   | 6 | 7 |
      ;   | 5 | 8 |
      ;     Front
      M584 X0 Y1 Z5:6:7:8 E3		; motor bindings
      M569 P0 S0      ; X motor direction
      M569 P1 S0      ; Y motor direction
      M569 P3 S1      ; E0 motor direction
      M569 P5 S0      ; Z0 motor direction
      M569 P6 S1      ; Z1 motor direction
      M569 P7 S0      ; Z2 motor direction
      M569 P8 S1      ; Z3 motor direction
      ; endstops
      M574 X2 S1 P"!xstop"   ; X max active high endstop switch
      M574 Y2 S1 P"!ystop"   ; Y max active high endstop switch
      M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e4stop" ;+!duex.e5stop" ; Z max active high endstop switch
      so here is the issue - in the configuration shown above I have 4 z motors and 4 endstops aligned to the motors, so one endstop at the high end per motor - I want to run it like this to align the gantry when I home the machine, what I expected to happen (as I'm running RRF 3.4.5 ) was to declare the motors and associated endstops as per the documentation and the printer would home Z and as each motor hit its endstop it would stop (this is what I've read in the docs anyway) - what happens is really weird, firstly if I attempt to declare the endstops all together like this:
      M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e4stop+!duex.e5stop" ; Z max active high endstop switch
      it seems to totally ignore the end of the statement and none of the endstops actually function as written in the code and z will not home. If I remove the last endstop from the line it will home but will stop when ANY of the three configured endstops triggers rather than stopping just the motor its assigned to, I have tested this manually and any of the three will stop the z home but it wont do each motor in turn (which is what I expected to happen and what I understood from the docs and threads Ive read on the subject of multiple endstops and motors on an axis)
      all z motors and z endstops are on the duex board with the X/Y or A/B motors and endstops on the main Duet 2 Wifi board
      my homeall.g file calls another probe_zm.g file that contains this:
      G91                                    ; relative positioning
      M98 P"/macros/drive/z_downcurrent.g"
      G1 H1 Z430 F6000                       ; +Z probe move, fast. (*ADJUST* to 10mm larger than your Z size)
      M98 P"/macros/drive/z_fullcurrent.g"
      G1 H2 Z-2 F6000                      ; back off from the endstop
      G1 H1 Z3 F60                           ; +Z probe move, slow
      G1 H2 Z-5 F6000                        ; back off from the endstop
      Has anyone seen this kind of issue before? the endstop declaration issue looks like it not liking the length of the string between the "" not sure why the homeing is only looking at a single endstop (but any of the 3 !)
        droftarts administrators @Chaos3d
        @Chaos3d I think your issue is due to a limit on the number of characters allowed in the P parameter. "!duex.e2stop+!duex.e3stop+!duex.e4stop+!duex.e5stop" is 51 character between the quotes, and the limit is 50. That's why removing one endstop works. The only option, unless you want edit and recompile the firmware, is to reduce the length of the parameter.
        As you're using endstop boards, you can't change the wiring to make them Normally Closed rather than Normally Open, which would allow you to shorten the parameter length by removing the !. So, the easiest thing to do is to change the name of the pin; pins often have more than one name, and others are shorter, and should get you under the 50-character limit:
        E2_STOP: duex.e2stop, exp.e2stop, exp.4
        E3_STOP: duex.e3stop, duex.cs6, exp.e3stop, exp.9
        E4_STOP: duex.e4stop, duex.cs7, exp.e4stop, exp.14
        E5_STOP: duex.e5stop, duex.cs8, exp.e5stop, exp.19
        (See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names)
        So try:
        M574 Z2 S1 P"!exp.4+!exp.9+!exp.14+!exp.19" ; Z max active high endstop switch
        Which would make it 29 characters long.
        The reason it stops all motors with one of the endstops removed is because it realises there would be nothing to stop the fourth axis (because 4 axes are defined), so it stops all of them, in the same way that if you only had one endstop, it would stop all axes.
        You can check the endstop assignment is being configured correctly by sending M574 on its own in the console, eg (this is mine):
        M574
        Endstop configuration:
        X: high end switch connected to pin io1.in
        Y: low end switch connected to pin io2.in
        Z: none
        This sort of error should also be picked up if you send M98 P"config.g" from the console, or if you sent the M574 command manually. eg:
        Error: M574: string too long
        It just doesn't tell you how long it should be!
        • Chaos3dundefined
          Chaos3d
          Hi Ian,
          Many thanks for the help! - That makes a lot of sense I was wondering if it was a string too long error.
          So I've changed the config file and run the M574 command directly in the console and I now get this:
          M574
          X: high end switch connected to pin !xstop
          Y: high end switch connected to pin !ystop
          Z: high end switches connected to pins !(exp.e2stop,exp.4) !(exp.e3stop,exp.9,spi.cs6,duex.cs6) !(exp.e4stop,exp.14,spi.cs7,duex.cs7) !(exp.e5stop,exp.19,spi.cs8,duex.cs8)
          However something is really weird now as if I check the endstop state i see this:
          So the zstop state is now triggered and manually triggering all endstops does not clear that setting nor does removing the ! from each pin name
          executing the M574 Z2 S1 P"!exp.4+!exp.9+!exp.14+!exp.19" command at the console does not throw any errors either
          So the plot thickens!!!
          Richard
            @Chaos3d Try configuring each endstop individually and testing them. It may be one is wired incorrectly. eg send
            M574 Z2 S1 P"!exp.4"
            And test that one endstop, then do the same for !exp.9, !exp.14 and !exp.19. I don't think the endstop logic is switched (ie remove the !), but it might be.
            • Chaos3dundefined
              Chaos3d
              So I've now tried every combination of all the pin names and the only pin names that have any response are the Duex.eXstop versions the exp.4 /9 /14/19 have no response, duex.cs6/7/8 or exp.eXstop variations have no response in the interface at all on the endstop screen, all have been tested individually with and without the ! and none work 😞
              i dont understand why the pin names just dont work, it makes no sense
              Richard
              • Chaos3dundefined
                Chaos3d
                if I run the M571 command from the console whilst the endstop is configured as exp.4/9 etc i get:
                m571
                Extrusion ancillary PWM has no pin
                  dc42 administrators @Chaos3d
                  @Chaos3d unfortunately the pin name aliases listed by @droftarts are not correct. In particular the duex.estop pins are routed through the I2C expander on the DueX and the expansion pins that are labelled as exp.estop become the CS pins on the DueX daughterboard connector.
                  So one option is for you to connect the endstop switches to the CS pins on the daughter board connector. But there is no protection on these pins, in particular the maximum input voltage is 3.3V.
                  @chrishamm could you please do a build of RRF 3.4.6rc1 for Duet 2 with the max pin name length increased to about 55?
                  • chrishammundefined
                    chrishamm administrators @dc42
                    @dc42 @Chaos3d Yes, I can build new binaries with that change tomorrow morning.
                    Duet software engineer
                    • Chaos3dundefined
                      Chaos3d
                      @dc42 said in Duet 2 WiFi Voron 2.4 - Multiple Z endstops query:
                      Wow thank you, that would solve all my issues, you are all stars!! 🙂
                      droftartsundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                        @Chaos3d Ah! Sorry, my mistake about the pin names. I suppose, when it didn't say 'duex.e2stop' in the response to M574, I should have realised the mapping wasn't correct:
                        @dc42 is this table wrong, then? https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names
                        dc42undefined Chaos3dundefined 2 Replies Last reply Reply Quote 0
                          dc42 administrators @droftarts
                          @droftarts yes, the duex.e#stop pins are not aliases for or shared with anything else. Whereas the cs5..cs8 pins are indeed shared with expansion connector pins.
                          • Chaos3dundefined
                            Chaos3d @droftarts
                            @droftarts said in Duet 2 WiFi Voron 2.4 - Multiple Z endstops query:
                            Hey no worries you helped identify the issue so we are good - I'm still learning all this so everything is useful!! 🙂
                              droftarts administrators @dc42
                              Okay, I'll update the table.
                              • Chaos3dundefined
                                Chaos3d
                                @chrishamm Sorry to pester but did the change go into 3.4.6.rc1? only im seeing the date as last week - or am I looking at the wrong thing?
                                  @Chaos3d For a quick workaround, move one of the endstops to the Duet board if there are any available, eg e0stop, which is a shorter name and should get you under the 50 character limit.
                                  Chaos3dundefined 1 Reply Last reply Reply Quote 0
                                    chrishamm administrators @Chaos3d
                                    @Chaos3d Please try out this v3.4 firmware build for the Duet 2: https://drive.google.com/file/d/1LH90R3sbF8BGaFa6T-F-cP40oIsBkET1/view?usp=sharing It has a maximum port length of 60 instead of 50, but be aware I have not tested it yet.
                                    • Chaos3dundefined
                                      Chaos3d
                                      @chrishamm - That worked like a charm!! - all endstops triggered as expected and gantry is leveled out which was exactly what i was looking for - I will go through the stuff I had working to make sure its still ok but so far all looking good!! many many thanks!
                                      Rich
                                      • Chaos3dundefined
                                        Chaos3d @droftarts
                                        @droftarts ha ha I was just about to try that when I saw @chrishamm has posted an update 🙂 cheers @droftarts
                                        • Phaedruxundefined Phaedrux has marked this topic as solved
                                        • droftartsundefined droftarts referenced this topic
