    Blown bed heating circuit on duet wifi
    543
      dc42 administrators @ageis
      @ageis said in Blown bed heating circuit on duet wifi:
      Just noticed I get -13v on the gate pin when its off
      If you are measuring the gate voltage relative to the VIN ground terminal, than that's not possible. What did you use as the ground reference?
      ageisundefined 1 Reply Last reply Reply Quote 0
      • ageisundefined
        ageis @dc42
        @dc42 Hehehe just checking you are awake lol. No I used the negative for the bed. I didn't know it makes a difference.
        I have re-measured the values. I get 5v when on and 0 when it's off.
        So dc42 are you looking to create a more indestructible duet. I have a PHD in breaking things.
        I have just checked the thermistor, its reading 10k. Prusa says it shud read 100k at room temp. I felt the bed it's cool to the touch. Could this be my problem
        Maestroundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • Maestroundefined
          Maestro @ageis
          @ageis Are you sure you're running a 100k thermistor? It would be remarkably coincidental if you happened to short out a 100k thermistor such that its room-temp resistance somehow dropped to be right in line with the 10k standard.
            When the bed is at room temperature, what temperature does DWC report for the bed?
            • ageisundefined
              ageis @Maestro
              So I measured the resistance of the thermistor by measuring across the terminal next to the bed pwr output.
              @Maestro
              I am only going off what prusa said on their website.
              It says so on this website https://help.prusa3d.com/article/heatbed-not-heating-up-properly_2086. Specifically in the measure voltage and resistence section.
              Plus I am very sure it would heat up to 65 degrees before and I have just checked my config, it says 100000.
              M305 P0 T100000 B4138 R4700
              what is the R4700 for?
              @dc42 it reports it to be 20C
              I can understand what @Maestro is saying. It's amazing that its work out to be a standard 10k. but my config says it's been configured as a 100k thermistor and was working till i shorted it out. I didnt know you can short out a thermistor.
              I dont think murphy likes me. He's always wanting to make a fool out of me.
              @dc42 why does it matter which ground I use to measure my voltages? Does the gnd for bed not end up at the vin gnd? Otherwise it wouldn't be a complete circuit, would it?
              • Maestroundefined
                Maestro @ageis
                @ageis Please unplug the thermistor from the board and measure its resistance directly, no board connections involved.
                • ageisundefined
                  ageis @Maestro
                  @Maestro Ok I suppose there could be parallel resistances. It's way out of spec at 120k.
                  Maestroundefined 1 Reply Last reply Reply Quote 0
                  • Maestroundefined
                    Maestro @ageis
                    @ageis That's not way out of spec; that's a 100k thermistor at about 21C. Now we can disregard the 10kOhm reading, and proceed on the more reasonable assumption that your thermistor is what it's expected to be and your board is reading it appropriately!
                    • ageisundefined
                      ageis
                      @Maestro that's disappointing. There's potential I have broken my duet then. Am sad now.
                      Sorry for the confusion. I lack the experience in troubleshooting electronics.
                      So what cud I have broken then?
                      ageisundefined Maestroundefined 2 Replies Last reply Reply Quote 0
                      • ageisundefined
                        ageis @ageis
                        This post is deleted!
                        • Maestroundefined
                          Maestro @ageis
                          @ageis Honestly, based on the picture you uploaded (the odds of someone diagnosing a component from that image are slim) I would suggest the following.
                          One; remove your board from the printer and clean all the crud off of it. Honestly mate, what on earth has been done to that poor board?
                          Two; take a real good look for damaged components, including solder joints (bed-heater connections have clearly seen better days).
                          Three; reassess.
                          • ageisundefined
                            ageis @Maestro
                            @Maestro
                            Hi thanks for replying still.
                            I have purchased a cheap 3d printer controller off amazon. I still have issues with the bed heating up so it has led me to believe it's the bed. The bed draws half the amount of power it should draw. I want to upgrade to the magnetic bed anyway so I have brought myself prusa mk52 bed. Hopefully the issue is the bed.
                              Like other control boards, the Duet switches the negative side of the bed heater output. So the negative terminal of the bed heater output is only at ground potential when the heater is commanded to turn on. At other times it will be at the VIN potential. So if you measured 13V with the bed heater commanded off, I guess that the gate voltage was 0V and your VIN is 13V.
