    New beta firmware 1.20beta11
    Firmware installation
    10
    29
    3.9k
      I've just released this in the usual Edge folders.
      The main purpose of this release is to fix two serious bugs that were reported in earlier betas:
      • Layer shifts and other oddities in 1.20beta10. I believe these were caused by the system running out of RAM.
      • Occasional spin lockups or watchdog resets in betas 7 to 10 inclusive. The ones I was able to reproduce were caused by a bug in the updated version of the Atmel USB driver.
      I've also fixed a number of lesser bugs. See https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for the details.
      • frafaundefined
        frafa
        Hi David
        OK for me on Scara
        Thanks 🙂
        Scara with DuetWifi => Scarlette3D
        https://youtu.be/mBF5cO8vGhI
        • zlowredundefined
          zlowred
          David,
          I'm happy to report that I spent an hour dry-running the print (without the filament, just to test for the watchdog reset) and I wasn't able to reproduce any of the major problems I had before (watchdog reset and wifi disconnect).
          I was usually getting resets within 10 minutes into the print.
          M122 after the print is showing considerable number of step errors, not sure if I should be concerned:
          M122
          Used output buffers: 3 of 32 (16 max)
          RepRapFirmware for Duet WiFi version 1.20beta11 running on Duet WiFi 1.0
          Board ID: 08DDM-9FAM2-LW4S8-6JTDD-3SJ6P-9MXBY
          Static ram used: 15488
          Dynamic ram used: 98168
          Recycled dynamic ram: 1032
          Stack ram used: 1368 current, 9264 maximum
          Never used ram: 7120
          Last reset 00:53:32 ago, cause: software
          Last software reset reason: User, spinning module GCodes, available RAM 7072 bytes (slot 1)
          Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
          Error status: 2
          Free file entries: 9
          SD card longest block write time: 0.0ms
          MCU temperature: min 30.4, current 30.7, max 31.2
          Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0
          Driver 0: standstill
          Driver 1: standstill
          Driver 2: standstill
          Driver 3: standstill
          Driver 4: standstill
          Date/time: 2017-11-29 00:15:11
          Slowest main loop (seconds): 0.117362; fastest: 0.000108
          MaxReps: 5, StepErrors: 1774, FreeDm: 240, MinFreeDm 120, MaxWait: 8ms, Underruns: 2, 1
          Scheduled moves: 189136, completed moves: 189136
          Bed compensation in use: none
          Bed heater = 0, chamber heater = -1
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 12
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          Network state is running
          WiFi firmware version 1.20b10
          WiFi MAC address xxx
          WiFi Vcc 3.35, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 26824
          WiFi IP address xxx
          WiFi signal strength -51dBm, reconnections 0, sleep mode modem
          HTTP sessions: 1 of 8
          Socket states: 2 0 0 0 0 0 0 0
          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          • KeeganBundefined
            KeeganB
            Updated to DuetWifiFirmware 1.20beta11 and DuetWifiServer 1.20beta10 and now I can't load DWC at all. I had to run M997 S1 a second time to get the server firmware loaded. M552 via Pronterface reports connected. Router client list shows the Duet. I can ping the Duet. I just can't get DWC to load.
            I will continue to poke it.
            EDIT: Got it. I had to remove the SD card. Delete the wifiserver.bin that was on it, put a fresh copy on it, then run M997 S1 again.
            Successfully updated to all the latest betas.
            Artemis
            Rostock Max v2
            Orion
              deckingman
              David,
              It seems the changes to allow M201/203 etc to hidden axes in M584 doesn't work in this beta. I just tried adding the P3 parameter to my M584 X0:3 Y1:4 Z2 U10 V11 E5:6:7:8:9 at the start of the drive section and commenting out the line at the end of config.g that had P3 at the end, but when I tried to home, the axes were not moving together. Not sure what U and V were trying to do but it wasn't the same motion as X and Y and I had to hit emergency stop. Also, I had put M584 X0:3 Y1:4 Z2 U10 V11 E5:6:7:8:9 P3; at the end of my homing files instead of simply M584 X0:3 Y1:4. This has the effect of making U and V appear in DWC at the start of homing (due to this M584 X0 U3 Y1 V4) then disappear at the end of homing. This works a treat in bet10 but with beta11, I can home all successfully once but if I try it a second time, the upper axis tries to move differently to the lower one. It's almost as if M584 X0:3 Y1:4 Z2 U10 V11 E5:6:7:8:9 P3 deletes the M201/203 etc settings for U and V or that it causes U and V to revert to Cartesian or some other Kinematics. Very strange….....
              • lolorcundefined
                lolorc
                hi,
                is it possible to free more RAM by disabling the network stack at compile time ?
                • KeeganBundefined
                  KeeganB
                  No issues with print, step errors, or layer shifting for me. I do continue to have the disconnect issues. I ran a print overnight, and when I came back to the computer it looked like it was still connected, but when I went to preheat the hot end, it immediately gave an AJAX error and was locked out. I could still ping the Duet, it still shows connected in my router client list, and M552 still reports connected.
                  M122 from immediately following disconnect. 96 reconnects….
                  [c]SENDING:M122
                  Used output buffers: 7 of 32 (14 max)
                  Board ID: 08DDM-9FAM2-LW4SD-6JTF0-3S86N-TLWZX
                  Dynamic ram used: 97952
                  Recycled dynamic ram: 1248
                  Stack ram used: 4328 current, 9276 maximum
                  Never used ram: 7108
                  Last reset 08:22:44 ago, cause: power up
                  Last software reset reason: User, spinning module GCodes, available RAM 7296 bytes (slot 3)
                  Error status: 0
                  [ERROR] Error status: 0
                  Free file entries: 10
                  SD card longest block write time: 81.1ms
                  MCU temperature: min 25.8, current 28.5, max 36.0
                  Supply voltage: min 12.3, current 12.7, max 12.9, under voltage events: 0, over voltage events: 0
                  Date/time: 2017-11-29 07:42:29
                  Slowest main loop (seconds): 2.637146; fastest: 0.000040
                  MaxReps: 5, StepErrors: 0, FreeDm: 240, MinFreeDm 120, MaxWait: 1261068800ms, Underruns: 0, 0
                  Bed probe heights: -0.133 -0.108 -0.113 -0.150 -0.265
                  Heater 0 is on, I-accum = 0.3
                  Heater 1 is on, I-accum = 0.4
                  Segments left: 0
                  file is idle in state(s) 0
                  serial is ready with "M122" in state(s) 0
                  WiFi MAC address 5c:cf:7f:ef:51:6f
                  WiFi Vcc 3.38, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 28432
                  WiFi IP address 10.0.1.161
                  WiFi signal strength -39dBm, reconnections 96, sleep mode modem
                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)[/c]
                  Artemis
                  Rostock Max v2
                  Orion
                  • KeeganBundefined
                    KeeganB
                    in addition to my previous post above….
                    After capturing the the M122 report, I sent an M552 S-1 followed by M552 S1 to restart the wifi. This nearly always works, but this time it took three times. The first two times It reconnected in DWC and IMMEDIATELY threw up the small (not ajax) disconnected error box. The 3rd time seems to have worked fine for now.
                    Artemis
                    Rostock Max v2
                    Orion
                    • franzelkaundefined
                      franzelka
                      Layer shifting has been resolved with this version!
                        @KeeganB:
                        Those 96 reconnections look abnormal. Please can you connect a PC to the Duet via USB, send M111 S1 P14 to enable wifi debugging, then run a print (or do anything else that provokes reconnections other than due to poor signal strength). After the print, post the debug output along with a M122 report.
                        • KeeganBundefined
                          KeeganB
                          David,
                          I will enable and test that this evening.
                          Artemis
                          Rostock Max v2
                          Orion
                          • Forgvn77undefined
                            Forgvn77
                            Layer shifting and extruder issues are fixed here! I did have to take apart my diamond hot end to unclog two of the filament chambers due to extruder issues in the previous beta. But, hey, we're off and running again!
                            Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
                            Make A Difference!
                              @KeeganB:
                              David,
                              I forgot to ask: are you now using DWS 1.20beta10?
                                @Forgvn77:
                                Thanks for the feedback!
                                • KeeganBundefined
                                  KeeganB
                                  @dc42:
                                  @KeeganB:
                                  David,
                                  Yes.
                                  Artemis
                                  Rostock Max v2
                                  Orion
                                    deckingman
                                    Further to my earlier post, I can confirm that having an M584 with the P3 parameter anywhere after an M584 without the P3 parameter completely messes up the movement of the U and V axes. That includes having M584 with P3 in a homing file instead of, or as well as, at the end of config.g. To be clear, that is with this beta11 version - the beta10 was fine in that respect as long as I had an M584 without the P3 at the beginning of config.g then subsequent M584 commands with the P3 parameter would simply hide the axes in DWC but movement was unaffected.
                                    Edit. Just tried a print and everything is fine as long as I keep all the axes visible at all times (no M584 with P3 anywhere) so it's not huge issue. Also, I tried a quick print with beta10 and a 3 colour mix but had huge layer shift issues but there is no sign of these problems with this beta11.
                                    • k3lagundefined
                                      k3lag
                                      I noticed on beta10 (although I thought I was crazy) and now on beta11 that the layer count is wrong. It is off by 2. For a print 50 layers high, it will finish on layer 52. Right now I am printing the first layer of a print and duet web control says it is on layer 3.
                                      I'm pretty sure it wasn't like this before the last beta or two.
                                      Larry
                                      • KeeganBundefined
                                        KeeganB
                                        Ok, After running a print overnight I came back to a disconnected printer. It reconnected no problem with a single click of "Connect" in DWC.
                                        Here is what was in Pronterface:
                                        [c]WiFi: lwip: ../src/src/core/ipv4/ip.c(808) p->ref == 1
                                        WiFi: lwip: ../src/src/core/ipv4/ip.c(652) p->ref == 1
                                        [/c]
                                        Here is the M122:
                                        [c]SENDING:M122
                                        Used output buffers: 6 of 32 (15 max)
                                        Recycled dynamiWiFi:
                                        c ram: 1248
                                        Last reset 31:44:09 ago, cause: power up
                                        Software reset code 0x0003, HFSR 0x00000000, CFWiFi: LINK
                                        SR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed3WiFi: xmit: 0
                                        8, SP 0xffffffff
                                        Error status: 0
                                        SD card longest block write time: 72.3ms
                                        MCU temperature: min 28.1, current 28.8, max 35.9
                                        Supply voltaWiFi: recv: 0
                                        ge: min 0.0, current 12.7, max 13.0, under voltage events: 1, over voltage eventWiFi: fw: 0
                                        s: 0
                                        Date/time: 2017-11-30 07:03:54
                                        SloWiFi: drop: 0
                                        west main loop (seconds): 0.118605; fastest: 0.000034
                                        MaxReps: 5, StepErrors: 0, FreeDm: 240, MinFreeDmWiFi: chkerr: 0
                                        120, MaxWait: 34853746ms, Underruns: 0, 0
                                        Bed probe heights: -0.018 -0WiFi: lenerr: 0
                                        .050 0.010 0.026 -0.034
                                        === GCodes ==WiFi: memerr: 0
                                        Segments left: 0
                                        WiFi: rterr: 0
                                        queue is idle in state(sWiFi: proterr: 0
                                        ) 0
                                        Network state is runniWiFi: opterr: 0
                                        ng
                                        WiFi Vcc 3.38, reset reason Turned on by main pWiFi: err: 0
                                        rocessor
                                        WiFi flash size 4194304, free heap 28704
                                        WiFi: cachehit: 0
                                        WiFi signal strength -40dBm, reconnections 135, sleep mode modem
                                        WiFi:
                                        WiFi: ETHARP
                                        WiFi: xmit: 409
                                        WiFi: recv: 8988
                                        WiFi: fw: 0
                                        WiFi: drop: 51083
                                        WiFi: chkerr: 0
                                        WiFi: lenerr: 0
                                        WiFi: memerr: 0
                                        WiFi: rterr: 0
                                        WiFi: proterr: 51083
                                        WiFi: opterr: 0
                                        WiFi: err: 0
                                        WiFi: cachehit: 43344
                                        WiFi:
                                        WiFi: IP
                                        WiFi: xmit: 44098
                                        WiFi: recv: 42967
                                        WiFi: fw: 0
                                        WiFi: drop: 0
                                        WiFi: chkerr: 0
                                        WiFi: lenerr: 0
                                        WiFi: memerr: 0
                                        WiFi: rterr: 0
                                        WiFi: proterr: 0
                                        WiFi: opterr: 0
                                        WiFi: err: 0
                                        WiFi: cachehit: 0
                                        WiFi:
                                        WiFi: IGMP
                                        WiFi: xmit: 342
                                        WiFi: recv: 1110
                                        WiFi: drop: 0
                                        WiFi: chkerr: 0
                                        WiFi: lenerr: 0
                                        WiFi: memerr: 0
                                        WiFi: proterr: 0
                                        WiFi: rx_v1: 0
                                        WiFi: rx_group: 0it: 2228
                                        WiFi: recv: 15760
                                        WiFi: fw: 0
                                        WiFi: drop: 0
                                        WiFi: chkerr: 0
                                        WiFi: lenerr: 0
                                        WiFi: memerr: 0
                                        WiFi: rterr: 0
                                        WiFi: proterr: 0
                                        WiFi: opterr: 0
                                        WiFi: err: 0
                                        WiFi: cachehit: 0[/c]
                                        Artemis
                                        Rostock Max v2
                                        Orion
                                          Thanks, that p->ref==1 does indicate an error, and it has been reported by other users too. I have it on my list to investigate.
                                            @k3lag:
                                            Larry
                                            Thanks for the report, I'll check it out.
