Digital input problem's / pwm signal output
Hello i have problem that i can't read input or send out output signal
if i use optical end stop everything works fine i get detection.
Mean while i have tool locking mechanisem which have 2 end stop switches in serias with NC contact used. i have 3.3v from same connector and back to ( 1HCL board) and i can't read it.Same is for emergency stop on main board (6HC). i have 3.3V connected to COM on emergency contact and than signal back to io0.in.
here is config file:
; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.0-beta.4 on Wed Jul 19 2023 13:39:45 GMT+0200 (Srednjeevropski poletni čas) M98 P"Turn_printer_on" ; General ############################################################################################################# M550 P"3D MONSTRUM" ; set hostname ; Network ############################################################################################################# M552 P192.168.0.39 S1 ; configure Ethernet adapter M586 P0 S1 ; configure HTTP ; Wait a moment for the CAN expansion boards to become available ###################################################### G4 S2 ; Smart Drivers ####################################################################################################### M569 P0.0 S0 D2 ; driver 0.0 goes backwards (Z axis) M569 P0.1 S0 D2 ; driver 0.1 goes backwards (Z axis) M569 P0.2 S0 D2 ; driver 0.2 goes backwards (Z axis) M569 P0.3 S0 D2 ; driver 0.3 goes backwards (X axis) M569 P0.4 S0 D2 ; driver 0.4 goes backwards (Y axis) M569 P121.0 S0 D2 ; driver 121.0 goes forwards (extruder 0) M569 P122.0 S0 D2 ; driver 122.0 goes forwards (extruder 1) M569 P123.0 S0 D2 ; driver 123.0 goes forwards (extruder 2) M569 P124.0 S0 D2 ; driver 124.0 goes forwards (extruder 3) M569 P125.0 S1 D2 ; driver 125.0 goes forwards (extruder 4) ; NOTE: This is later generated in the Axes and/or Extruders section ################################################## M906 X800 Y800 Z800 E1500:1500:1500:1500 U10 ; set motor driver currents ; Motor Idle Current Reduction ######################################################################################## M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; External Drivers #################################################################################################### ; no external drivers mapped to axes or extruders ; Closed-Loop Drivers ################################################################################################# ; no drivers with encoders configured ; Kinematics ########################################################################################################## M669 K1 ; configure CoreXY kinematics ; Axes ################################################################################################################ M584 X0.3 Y0.4 Z0.0:0.1:0.2 ; set axis mapping M350 X16 Y16 Z1600 I1 ; configure microstepping with interpolation ; NOTE: See Smart Drivers section for motor currents M92 X80 Y80 Z400 ; configure steps per mm M208 S1 X0 Y0 Z0 ; set axis minima M208 S0 X420 Y386 Z450 ; set axis maxima M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z300 ; set maximum speeds (mm/min) M201 X800 Y800 Z60 ; set accelerations (mm/s^2) ; Extruders ########################################################################################################### M584 E121.0:122.0:123.0:124.0 ; set extruder mapping M350 E16:16:16:16 I1 ; configure microstepping with interpolation ; NOTE: See Smart Drivers section for motor currents M92 E1756:2812:1756:1756 ; configure steps per mm M566 E1756:2812:1756:1756 ; set maximum instantaneous speed changes (mm/min) M203 E3600:3600:3600:3600 ; set maximum speeds (mm/min) M201 E1500:1500:1500:1500 ; set accelerations (mm/s^2) ; Tool actuator ###################################################################################################### M584 U125.0 ; set extruder mapping M350 U4 I1 ; configure microstepping with interpolation ; NOTE: See Smart Drivers section for motor currents M92 U30.578 ; configure steps per mm M566 U50 ; set maximum instantaneous speed changes (mm/min) M203 U7000 ; set maximum speeds (mm/min) M201 U800 ; set accelerations (mm/s^2) M208 U0:200 ; Probes ############################################################################################################# ; Endstops ########################################################################################################### M574 X1 P"125.pdec.a" S1 ; configure X axis endstop M574 Y1 P"0.io1.in" S1 ; configure Y axis endstop M574 Z1 S2 M574 U1 P"125.io1.in" S1 ; configure U axis endstop ; Mesh Bed Compensation ############################################################################################## M557 X0:380 Y114:364 S40 ; define grid for mesh bed compensation ; Sensors ############################################################################################################ M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B3950 ; configure sensor #0 M308 S1 P"121.temp0" Y"thermistor" A"Nozzle 1" T100000 B4725 C7.06e-8 ; configure sensor #1 M308 S2 P"122.temp0" Y"thermistor" A"Nozzle 2" T100000 B4725 C7.06e-8 ; configure sensor #2 M308 S3 P"123.temp0" Y"thermistor" A"Nozzle 3" T100000 B4725 C7.06e-8 ; configure sensor #3 M308 S4 P"124.temp0" Y"thermistor" A"Nozzle 4" T100000 B4725 C7.06e-8 ; configure sensor #4 M308 S5 P"125.temp0" Y"thermistor" A"WATER IN TO COOLER" T10000 B3435 ; configure sensor #5 M308 S6 P"125.temp1" Y"thermistor" A"WATER OUT OF COOLER" T10000 B3435 ; configure sensor #6 M308 S7 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet M308 S8 Y"mcu-temp" A"MCU" ; configure sensor 3 as on-chip MCU temperature sensor ; Heaters ############################################################################################################ M950 H0 C"out0" T0 ; create heater #0 M143 H0 P0 T0 C0 S110 A0 ; configure heater monitor #0 for heater #0 M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0 M140 H0 R35 ; map heated bed to heater 0 M950 H1 C"121.out0" T1 ; create heater #1 M143 H1 P0 T1 C0 S250 A0 ; configure heater monitor #0 for heater #1 M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 M950 H2 C"122.out0" T2 ; create heater #2 M143 H2 P0 T1 C0 S250 A0 ; configure heater monitor #0 for heater #2 M307 H2 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #2 M950 H3 C"123.out0" T3 ; create heater #3 M143 H3 P0 T1 C0 S250 A0 ; configure heater monitor #0 for heater #3 M307 H3 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #3 M950 H4 C"124.out0" T4 ; create heater #4 M143 H4 P0 T1 C0 S250 A0 ; configure heater monitor #0 for heater #4 M307 H4 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #4 ; Heated beds ####################################################################################################### M140 P0 H0 ; configure heated bed #0 ; Fans ############################################################################################################# M950 F0 C"!out6+out6.tach" Q450 ; create fan #0 M106 P0 C"MAIN BOARD NOCTUA" S1 L0.15 X1 B0.3 H7:8 T25:35 ; configure fan #0 M950 F1 C"out7" ; create fan #1 M106 P1 C"BERDAIR PUMP" S0 L0 X1 ; configure fan #1 M950 F2 C"!out5+out5.tach" Q25000 ; create fan #2 M106 P2 C"COLLER NOCTUA FANS" S1 L0.5 X1 B0.3 H5 T25:35 ; configure fan #2 M950 F3 C"!out4+out4.tach" ; create fan #3 M106 P3 C"WATER PUMP" S1 L0.35 X1 B0.3 H6 T20:70 ; configure fan #3 ; Tools ############################################################################################################# M563 P0 D0 H1 F1 S"TOOL 1" ; create tool #0 G10 P0 Z4.922 ; Set tool #0 offset from the bed M568 P0 R20 S30 ; set initial tool #0 active and standby temperatures to 0C M563 P1 D1 H2 F1 S"TOOL 2" ; create tool #1 G10 P1 Z4.947 ; Set tool #1 offset from the bed with tool-0 as a reference. M568 P1 R20 S30 ; set initial tool #1 active and standby temperatures to 0C M563 P2 D552 H3 F1 S"TOOL 3" ; create tool #2 G10 P2 Z-3.75 ; Set tool #2 offset from the bed M568 P2 R20 S30 ; set initial tool #2 active and standby temperatures to 0C M563 P3 D3 H4 F1 S"TOOL 4" ; create tool #3 G10 P3 Z-3.75 ; Set tool #3 offset from the bed M568 P3 R20 S30 ; set initial tool #3 active and standby temperatures to 0C ; Emergen1cy Stop ##################4################################################################################## M950 J1 C"io0.in" ; Define Emergency endstop - emergency stop switch condition M950 P4 C"io0.out" M581 P1 S0 T2 ; Define action to be taken with activation of emergency stop switch M582 T2 S0 ; set trigger #3 pending unconditionally other problem or isn't it. i would like that if temp go up then i would like that to pwm signal goes in to slower mode not faster.
just because when i cooling water i want that to flow through cooler slower. that i will get more heat out of water. -
@matej1006 here is also diagnose
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.4.4+1 (2022-11-15 17:36:33) running on Duet 3 MB6HC v1.02 or later (standalone mode) Board ID: 08DJM-9P63L-DJMSS-6JTD0-3S46L-9UFZ8 Used output buffers: 3 of 40 (18 max) === RTOS === Static ram: 152740 Dynamic ram: 100312 of which 172 recycled Never used RAM 97448, free system stack 200 words Tasks: NETWORK(ready,29.7%,218) ETHERNET(notifyWait,0.1%,445) HEAT(notifyWait,0.0%,344) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.1%,799) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.0%,91) MAIN(running,62.9%,925) IDLE(ready,0.3%,30), total 100.0% Owned mutexes: === Platform === Last reset 00:00:46 ago, cause: power up Last software reset at 2023-07-25 18:49, reason: User, GCodes spinning, available RAM 97448, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Step timer max interval 127 MCU temperature: min 25.1, current 31.3, max 31.4 Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 11.8, current 12.2, max 12.5, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 8, reads 64014, writes 14 timeouts 0 Driver 1: standstill, SG min 0, mspos 8, reads 64015, writes 14 timeouts 0 Driver 2: standstill, SG min 0, mspos 8, reads 64015, writes 14 timeouts 0 Driver 3: standstill, SG min 0, mspos 8, reads 64016, writes 13 timeouts 0 Driver 4: standstill, SG min 0, mspos 8, reads 64016, writes 13 timeouts 0 Driver 5: standstill, SG min 0, mspos 8, reads 64018, writes 11 timeouts 0 Date/time: 2023-07-25 19:05:26 Slowest loop: 3.98ms; fastest: 0.06ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.3ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 463, received 3512, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 621, free buffers 50 (min 49), ts 233/232/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 3.60ms; fastest: 0.03ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 = Ethernet = State: active Error counts: 0 0 0 1 0 0 Socket states: 2 5 2 2 2 0 0 0 = WiFi = Network state is disabled WiFi module is disabled Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485 Socket states: 0 0 0 0 0 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0 -
… and less heat away from the hotend. So it’s better to improve the cooling than to reduce the flow.
@matej1006 said in Digital input problem's / pwm signal output:
............... for emergency stop on main board (6HC). i have 3.3V connected to COM on emergency contact and than signal back to io0.in................................
M950 P4 C"io0.out"
M582 T2 S0 ; set trigger #3 pending unconditionallyIf I've read that correctly, you want to detect when 3.3 v goes to to pin io0.in. So your trigger (M581) ought to be set to detect a rising edge (inactive to active) which is S1 not S0.
@deckingman no i want to when it goes form 3.3 to 0. i did add a resistor 10kohm to gnd and io0.in. isn't helping and also i did try pull up in code nothing was working.
@infiniteloop ok yeah that far i wasn't thinking yeah
@matej1006 Here is what I have which triggers two macros based on the presence or otherwise of 3.3V on an io pin.
M950 J1 C"0.io3.in"
M581 P1 T2 R0 S1; io from low to high
M581 P1 T3 R0 S0; io from high to lowOther than using a different io pin, the only differences I can see between your code and mine is that I explicitly use board 0 (C"0.io3.in) but it should default to board zero if none is specified, and I use R0 to specify that the trigger should be acted on at any time rather than when printing from the SD card, but again, that should be the default behaviour. Maybe you have a wiring issue?
For info, the first line of my trigger2 file is M118 S"Trigger2" and the first line of my trigger3 file is M118 S"Trigger3" so I can easily see when they trigger.
@matej1006 you should connect your NC switches (or 2 switches in series) between the IOx_IN pin and ground. Leave the 3.3V pin not connected. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_endstops#microswitch.
@dc42 damm i missed this info sorry
@infiniteloop so now i have temp. set to hold between 20 to 25 C.
what would you recommend to set between 50 to 60 C -
what would you recommend to set between 50 to 60 CYou didn’t tell us, but I assume you want to cool your hotend. In this case, the effective temperature above the heatbreak is influenced by many factors: temperature of the heater, efficiency of the heatbreak, retraction settings, temperature of the surrounding air (think of a hot summer or of a heated chamber), heat transfer rate of the cooling jacket, …
Frankly, I cannot calculate any of these properly, so for me, it’s try & error. My pump is thermostatically controlled, it steps-in at 35 °C and runs full power at 65 °C (back flow). With these settings, I reliably avoid any heat creep. But with your system, you might need to apply different values.
@infiniteloop yes ok that i know. i just didn't know what cca temp i would like to have in system running.
