    Parts fan always on
    • ortondaleundefined
      ortondale
      Sorry to bother you kind folks again
      On testing my new install with Duet3 Mini5+ and toolboard 1LC v1.3, I find the parts cooling fan run continuously from power up. The hot end fan is ok coming on at temp 45c.
      Connected fan to OUT5 on main board and it worked ok, coming on at second layer.
      Have I got the wrong pins connected on the toolbord?
      Should it be +VOUT and out1 pins not GND and +VOUT
      Toolboard
      Config.g
      M950 F0 C"121.out1" Q500
      M106 P0 S0 H-1
      M950 F1 C"121.out2" Q500
      M106 P1 S1 H1 T45
      Also in Web Controller both fans show up, but when I adjust /move one slider the other slider moves the same.
      Any advice would be appreciated.
      Phaedruxundefined ortondaleundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @ortondale
        @ortondale said in Parts fan always on:
        There are two sliders. One is for the currently selected tools fan and one for the fan itself. Sometimes they are the same, like if you only have one tool.
        Yes. You have it wired as an always on fan right now.
          ortondale @ortondale
          @ortondale Hi Phaedrux
          I don’t want it to run all the time
          I require it to run say on second or third layer. Should the black negative be on pin out1 for this to happen or on out1.tach.
          ortondaleundefined 1 Reply Last reply Reply Quote 0
            Phaedrux Moderator @Phaedrux
            @Phaedrux said in Parts fan always on:
            +VOUT and out1 pins
            You had it right here. Out1 is the PWM switched ground.
              @ortondale thanks once again
