    $wire Shenanigans 1LC
    • smaaashundefined
      smaaash
      Is this the correct fan to board pinout?
        dc42 administrators @smaaash
        @smaaash that's correct for a 4-wire fan, except that the pin that the Control wire connects to is labelled OUT1_NEG on tool boards.
        smaaashundefined 1 Reply Last reply Reply Quote 0
        • smaaashundefined
          smaaash @dc42
          @dc42 in my FW d I need anything mor than :
          M950 F0 C"!121.out1+out1.tach" Q500
          Do i need to call out the control wire or does tach imply it? My CANBUS address is default BTW.
            @smaaash that command looks correct to me, except that Q25000 is recommended for 4-wire fans.
            • smaaashundefined
              smaaash @dc42
              @dc42 What setting does the "Q" represent?
              dc42undefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                @smaaash said in $wire Shenanigans 1LC:
                The PWM frequency.
                • gloomyandyundefined
                  gloomyandy @smaaash
                  @smaaash See: https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m950-create-heater-fan-spindle-or-gpioservo-pin
                  Qnn (optional) PWM frequency in Hz. Valid range: 0-65535, default: 500 for GpOut pins, 250 for fans and heaters. For LED strips (supported in RRF 3.5.0-beta.4 and later only) this is the LED clock frequency.
