Solved Duet does not auto-connect to WiFi
I suggest you send
M588 S"*"
to clear all saved networks and then use M587 to re-add your prefered network. -
@Phaedrux
M588 S”*”
ok
M587
Remembered networks: none
ok
M587 S”TP-Link_1D56” P”70259605”
ok
M587
TP-Link_1D56 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
okBut when I disconnect USB and switch on the PSU it does not connect.
Should there be an IP in the Remembered networks or should it be 0.0.0.0?
When you still have usb connected can you send M552 S1?
@Phaedrux
Connects fine and reachable with DWCM552 S1
ok
WiFi module started
Error: WiFi module reported: no known networks found
WiFi module is idle
WiFi module is connected to access point TP-Link_1D56, IP address 192.168.1.66 -
@Bassbadger
I notice this file is the config-network.g
Is this the same as config.g as I don't seem to have one of those? -
Am I missing the config.g file and if so, where can I find it?
I'm using an Ooznest Workbee with a Duet 2 WiFiBoard: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.5 (2022-11-30)
Duet WiFi Server Version: 1.27 -
You have no config.g in your sys folder?
You may want to check in with Oozenest to make sure you have all the files they provide for configuration.
@Phaedrux
Thanks. I think I mistook config-network.g for config.g
So I'm guessing config.g calls config-network.g I'll check the Ooznest site for a config.g file. -
@Phaedrux
Got it! Added the config.g file to the system and now I have Wifi connection automatically.Thanks to all for your help.
