Solved Emergency Stop
I added a physical E-Stop to the system that will cut power to the board and my expansion board. After the power is cut, I want the fans to remain off. Right now they are turning back on when power is restored and the emergency stop is disengaged. Is there a command that will allow me to turn them off and remain off or even reset them to their initial state. I saw the command M911 is to configure auto save on loss of power. Would this be appropriate in this situation?I am using firmware 3.4.6 and here is the config file
f905920d-4d54-4cba-be09-73d3b5addd86-config.g -
@msugar what fans are turning on?
If they're thermostatically controlled and the temperature is above the set point, they will turn on -
I am not using these outputs for actual fans I am using the fan pins as general outputs for different tools. It is turning on the pins for fans 4-7 on the duex 5 expansion board.
I actually figured out a solution. I made an additional trigger function and turned off all the tools and rest the machine with the command M999.
