    Set button color with variable
    Duet Web Control
    • Rodrigue Richallandundefined
      Rodrigue Richalland
      I want to change the color of a btn button following viarable value. Someone know how to do to it ?
      For exemple, if the door is close, global.closedoor = 1 => the button "close is gray"
      if the door is open, global.closedoor = 0 => the button "close is red"
      T3P3Tonyundefined MintyTreborundefined 2 Replies Last reply Reply Quote 0
        T3P3Tony administrators @Rodrigue Richalland
        @Rodrigue-Richalland is this using btn-command?
        Rodrigue Richallandundefined 1 Reply Last reply Reply Quote 0
          Rodrigue Richalland @T3P3Tony
          @T3P3Tony
          Exactly. I use btn pluging to bluid my own interface.
          • MintyTreborundefined
            MintyTrebor @Rodrigue Richalland
            @Rodrigue-Richalland This is not currently possible
            NodeDSF - Native Node-Red integration with Duet boards.
            BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
            ReleaseMgr - Duet update info inside DWC.
            Repo
              Rodrigue Richalland @MintyTrebor
              @MintyTrebor
              Thanks for your help.
              Can I ask this fonctionnality for futur versions ?
              It will be so nice to custom correctly our owns interfaces.
