    firmware problems
    Using Duet Controllers
    337
    • oolykundefined
      oolyk
      when placing dwc firmware in an sd card, do I need to unzip the file? and if so, which unzipped parts need to go in? also, paneldue responds "files on card 0". how to solve?
      thanks
        A Former User
        This post is deleted!
        oolykundefined 1 Reply Last reply Reply Quote 0
        • oolykundefined
          oolyk @A Former User
          @Herve_Smith
          thanks
          I have no access to the dwc. but do you mean that the software can deal with the zip file, meaning that I can load the zip file into the card?
            A Former User @oolyk
            • oolykundefined
              @Herve_Smith
              unzip, copy paste everything into the sd card? under "firmware" or where?
              I built a delta printer and had it working flawlessly for couple of years. then I lost the dwc and the communication with the paneldue. more or less abandoned it but now returned, modified the wifi to ethernet, but can't get the dwc to work.
              gloomyandyundefined 1 Reply Last reply Reply Quote 0
              • gloomyandyundefined
                gloomyandy @oolyk
                @oolyk You need to unzip the DWC zip file into a top level directory on the sd card called www. The following page shows what your sd card should look like at the end of the operation...
                https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#creating-the-file-structure
                • oolykundefined
                  oolyk @gloomyandy
                  @gloomyandy
                  looks like the right place to start. will try.
                  thanks
                    Sounds like you may need some additional assistance getting going.
                    Start here: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
                    When you receive the board there should already be firmware installed and a working SD card. Get connected to the board over the network and then updating the firmware is quite easy.
                    If for some reason you've wiped the firmware there are a few alternative methods to update it.
                    https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
                    • oolykundefined
                      oolyk @Phaedrux
                      @Phaedrux
                      thanks to all
