[3.5.0-b2] DWC Strange Slider Behavior
Hello? Should I have posted this on Github?
@CCS86 thanks for the report, here is the right place for it.
@chrishamm I have reproduced the issue with DWC in SBC mode 3.5b2 . It appears that the "Tool Fan" is being set between 0 and 1 rather than between 0 and 100.
@CCS86 Thanks, I could confirm that the tool fan didn't work correctly, that will be fixed in 3.5-b3.
The speed factor slider works as intended, it updates the min/max values whenever the speed factor value changes.
@chrishamm yes, the speed slider was (AFAIK) being moved in the video to show an example of how a slider should work!
@T3P3Tony Speed/extrusion are somewhat special because there's no hard limit of 0..100 for them.
@chrishamm sure, i was just pointing out that there was no bug alleged with the speed slider.
Awesome, thanks guys!
undefined chrishamm referenced this topic
Any progress on this @chrishamm ?
@CCS86 It's been fixed since 3.5-b3, see the DWC changelog on GitHub:
- Fixed tool fan on the Job Status page
