    NPN sensor for Z probe Issue
    • Drakundefined
      Drak
      Hello I am trying to setup my Z probe (using a NPN sensor) and ultimately complete a mesh level of my bed. When i home the z, it goes to the first probe point in the x and y directions but the Z axis doesn't move. Then it says homing is completed with a random Z value listed as homed.
      Here is my Config:
      M584 X4 Y1:2 Z9:8 E0                                  ; set drive mapping
      M569 P0 S0                                         ; physical drive 0 goes forwards
      M569 P1 S0                                         ; physical drive 1 goes forwards
      M569 P2 S0                                         ; physical drive 2 goes FORwards
      M569 P3 S0                                         ; physical drive 3 goes forwards
      M569 P5 S0
      M569 P6 S0                                         ; physical drive 3 goes forwards
      M569 P7 S0                                         ; physical drive 3 goes forwards
      M569 P8 S0                                         ; physical drive 3 goes forwards
      M569 P9 S0
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X816.5 Y793.4 Z626.4 E100.00                  ; set steps per mm
      M566 X500.00 Y500.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X600.00 Y600.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X25.00 Y25.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M208 X0 Y0 Z0 S1                                   ; set axis minima
      M208 X300 Y400 Z500 S0                             ; set axis maxima
      M574 X1 S1 P"!xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop+!e0stop" ; configure active-high endstops for low end on Z via pins zstop and e1stop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      G31 X20 Y0 Z9 P25
      M557 X15:762 Y15:762 S20                           ; define mesh grid
      M140 H-1                                           ; disable heated bed (overrides default heater mapping)
      M308 S0 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 0 as thermistor on pin e0temp
      M950 H0 C"e0heat" T0                               ; create nozzle heater output on e0heat and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H0 S260                                       ; set temperature limit for heater 0 to 260C
      M563 P0 D0 H0 S"Main"                                      ; define tool 1
      G10 P0 X0 Y0 Z0                                    ; set tool 1 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
      M501                                               ; load saved parameters from non-volatile memory
      Here is my homez.g:
      G91              ; relative positioning
      G1 H2 Z5 F6000   ; lift Z relative to current position
      G90              ; absolute positioning
      G1 X15 Y15 F6000 ; go to first probe point
      G30              ; home Z by probing the bed
        As far as I can see you don't actually have a probe defined at all. There is no M558 command.
        Is this your full config?
        Can you also share the results of sending M122 and M98 P"config.g" in the gcode console?
        Drakundefined 1 Reply Last reply Reply Quote 0
        • Drakundefined
          Drak @Phaedrux
          @Phaedrux
          I added the M558 line to the config and now it goes to probe. However during probing the bed moves in the wrong direction.
          here is the new config: the homez.g is the same as before:
          M569 P5 S0
          M569 P9 S0
          M558 P5 C"^zprobe.in" H5 F120 T3000
          G31 X20 Y0 Z9 P25
          here are the M122 and M98 responses:
          9/7/2023, 11:40:45 PM 	M98 P"config.g" i
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: bad grid definition: Too many grid points; suggest increase spacing to 37.3mm
          Error: Heater 1 not found
          Error: Heater 2 not found
          Error: Heater 4 not found
          Error: Heater 5 not found
          Error: Heater 6 not found
          Error: Heater 7 not found
          9/7/2023, 11:40:19 PM 	M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1 (2022-06-01 21:05:28) running on Duet WiFi 1.02 or later + DueX5
          Used output buffers: 3 of 26 (23 max)
          Static ram: 23860
          Dynamic ram: 75200 of which 0 recycled
          Never used RAM 12948, free system stack 134 words
          Tasks: NETWORK(ready,13.7%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,296) DUEX(notifyWait,0.0%,24) MAIN(running,85.8%,410) IDLE(ready,0.5%,30), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:03:43 ago, cause: software
          Last software reset at 2023-09-07 23:36, reason: User, GCodes spinning, available RAM 13108, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 32.8, current 34.1, max 34.8
          Supply voltage: min 12.2, current 12.2, max 12.4, under voltage events: 0, over voltage events: 0, power good: yes
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min n/a
          Driver 1: standstill, SG min 0
          Driver 2: standstill, SG min 0
          Driver 3: standstill, SG min n/a
          Driver 4: standstill, SG min 0
          Driver 5: standstill, SG min n/a
          Driver 6: standstill, SG min n/a
          Driver 7: standstill, SG min n/a
          Driver 8: standstill, SG min n/a
          Driver 9: standstill, SG min n/a
          Driver 10:
          Driver 11:
          Date/time: 2023-09-07 23:40:15
          Slowest loop: 59.06ms; fastest: 0.16ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.2ms, write time 3.0ms, max retries 0
          DMs created 83, segments created 3, maxWait 15424ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 17, completed 17, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
          === AuxDDARing ===
          Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty
          === DueX ===
          Read count 1, 0.27 reads/min
          === Network ===
          Phaedruxundefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @Drak
            @Drak said in NPN sensor for Z probe Issue:
            Then you'd likely need to reverse the motor rotation direction for the Z motors in the M569 commands.
            M569 P8 S1
            M569 P9 S1
            Test carefully.
            • Drakundefined
              Drak @Phaedrux
              @Phaedrux Thank you, I got this error when homing, I leveled the bed again and got same error but at a lower max error. how do i establish a a Z=0 datum?
              Warning: Skipping grid point X=15.0, Y=265.0 because Z probe cannot reach it
              Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
              24 points probed, min error 0.302, max error 3.056, mean 1.826, deviation 0.716
              Height map saved to file 0:/sys/heightmap.csv
              9/9/2023, 5:45:40 PM 	Warning: Skipping grid point X=15.0, Y=165.0 because Z probe cannot reach it
              Warning: Skipping grid point X=15.0, Y=215.0 because Z probe cannot reach it
              9/9/2023, 5:44:32 PM 	Warning: Skipping grid point X=15.0, Y=65.0 because Z probe cannot reach it
              Warning: Skipping grid point X=15.0, Y=115.0 because Z probe cannot reach it
              9/9/2023, 5:43:23 PM 	G28 Z
              Warning: Skipping grid point X=15.0, Y=15.0 because Z probe cannot reach it
                Should probably update your firmware.
                Upload this zip file to the system tab in DWC.
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.6/Duet2and3Firmware-3.4.6.zip
                This is done by using the probe to home Z with a G30 first.
                Make sure you've measured your probes offsets accurately first.
                https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
