Startup error on RRF 3.5.0 rc1
@dc42, I removed the second Z microstep configuration in M350 but the error code remained unchanged.
@jens55 you need to remove the doubled up Z values from here too
@jay_s_uk I removed all the doubled up Z lines in stepper_settings_default.g but the error message is still there
@jens55 can you post the output of
M98 P"config.g"
m98 p"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabledThere were a couple of other errors reported but I fixed those and re-ran the command
@jens55 said in Startup error on RRF 3.5.0 rc1:
M98 P"/sys/Toffset.g"
maybe this one not being fully formed? missing the
0:
Changed the formatting on both M98 lines - no change
Error in start-up file macro line 46: in file macro line 46 column 35: M92: array too long, max length = 0
Line 46 in config.g is:
M92 X80.20 Y80.15 Z400.00:400.00 E400Going back to that original message, the error states that it expected an array of length 0. You also said that if you separate the E value into a separate M92 line, the error moves to that line.
The likely cause is that you have no extruders configured at the point at which that line is executed. If it's a CNC or laser machine that has no extruders, just remove the E parameter. If it's a 3D printer and you do need extruders, move the M92 line to a position later in the file than the M584 command that creates the extruder(s).
Edit: this is indeed the problem, your M92 E command is at line 49 and the M584 command is line 56.
@dc42, thank you. I moved M584 to before the M92 commands and now , after a minor other fix, everything is working and there are no error messages.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
