First manual extruder move at full speed.
When I reboot my machine I have noticed that the first extruder move (manual or through paneldue) is at full speed. I have searched the forum but cant find anyting on it. It might just be this firmware as only recently noticed it.
Firmware v 3.4.1
anyone else had this?
@danharcombe said in First manual extruder move at full speed.:
is at full speed.
What exactly do you mean by this? Faster than the selected feed rate?
Firmware v 3.4.1
Can you update to 3.4.6 and see if you experience the same thing?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.6/Duet2and3Firmware-3.4.6.zip
yes faster than the selected rate for the first manual move through the paneldue or DWC.
normally i do a manual prime if I need to check things but if it goes flat out it strips the filament.
I will try a firmware update but I had downgraded as I was trying to diagnose some other issues.
was fixed in 3.42
Under certain conditions an extrusion-only move was executed at maximum speed instead of the requested speed -
