    6HC + external servo drives at high step rate
    • Andreyundefined
      Andrey
      Hi all!
      Is it possible to hookup 2x external servo drives to 6HC without using 1XD? Can I use I/O pins while sacrificing some minor functions? High step rate needed.
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Andrey
        @Andrey unfortunately not.
        your options are
        • 1XD boards
        • A 6XD in expansion board mode
        • An STM32H7 board in expansion board mode
        Andreyundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @Andrey
          @Andrey that's not currently supported. In principle we could support one or two external drivers as an option, but it would have some limitations:
          • you would need to use 2 output pins per external driver if you don't need the Enable signal, or 3 if you do
          • if using the ioX_out pins then you would need to boost the drive voltage from 3.3V to 5V
          • Andreyundefined
            Andrey @jay_s_uk
            Thank you for your reply.
            @jay_s_uk
            I have couple of 1XD for Z-axis motors and it works just fine but unfortunately it can not handle 220-250 kHz step rate needed for XY-axes (maybe it could be a good idea to develop hi-speed version of 1XD).
            6XD itself is more than enough for my task and I have two boards in work right now. 6HC is one of my first Duet boards and it works great for several years now I just want to prolong it's life in new project.
            STM32H7? I can get any STM32H7 development board and connect it via CAN-FD?
            Yes 4 output pins looks like fair price for external drives. Enable signal does not that important and XY-axes drives definitely can share it (so OK, it is 5 pins needed).
            Hi-Speed logic level shifter adds something around $6-10 and it is OK I think.
              jay_s_uk @Andrey
              @Andrey the STM32H7 boards that are supported by the STM32 port are listed here https://teamgloomy.github.io/supported_boards.html#stm32h7-boards-with-native-support although I would discount the Fysetc Spider King.
