    Duet V3 6hc stepper problems
    • 3DGarageundefined
      3DGarage
      Hello, so I have installed and compiled firmware for my modix printer on Duet V3 6hc, but cant get it running propertly. Main problem is that while homing x axis y axis moves to, same happens if I try to home y. Checked the firmware with few engineers everything seems to be right. Any Ideas what could be causing this anomaly that both y and x steppers get signal from the same command?
      • infiniteloopundefined
        infiniteloop @3DGarage
        @3DGarage
        Modix printer on Duet V3 6hc, [ ]. Main problem is that while homing x axis y axis moves to, same happens if I try to home y.
        According to the Modix website, all models are equipped with Duet 2 controllers. Is this info outdated, or did you replace the controller with a 6HC on your own?
        If the 6HC was provided by Modix, they are the first address to ask for support.
        To get assistance from this forum, please provide us with the config.g you’ve created. Use the </> symbol from the header of the thread's edit section to tag the text.
        From what you describe, it looks like you didn’t tell the Duet controller about the kinematics of the printer: to my (severely limited) knowledge, all Modix' are CoreXY, so you should have this in your config:
        M669 K1 ; switch to CoreXY mode
        For details, refer to this documentation: Configuring RepRapFirmware for CoreXY Printer
        3DGarageundefined 1 Reply Last reply Reply Quote 0
        • 3DGarageundefined
          3DGarage @infiniteloop
          @infiniteloop
          Our old Modix duet 2 controller had a short and burned its drivers, so we have ordered a new controller Duet V3 6hc as I mentioned before. I'm attaching link to the drive to the whole firmware folder with all the files including home and config.g . Firmware zip folder its named new compiled firmware.zip. I also included videos of whats happening exactly. I would appreciate if you guys would be able to check what am I doing wrong.
          Link to the drive - https://drive.google.com/file/d/1rWz-rtWuztu5LfidsEUuygnTc86CAnKw/view?usp=sharing
          infiniteloopundefined 2 Replies Last reply Reply Quote 0
            @3DGarage OK. Here's your config.g replicated inline so that forum members can easily read and contribute:
            ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.16 on Wed Sep 13 2023 04:05:59 GMT+0300 (Eastern European Summer Time)
            M575 P1 S1 B57600                                  ; enable support for PanelDue
            G90                                                ; send absolute coordinates...
            M83                                                ; ...but relative extruder moves
            M550 P"Modix"                                      ; set printer name
            M669 K1                                            ; select CoreXY mode
            M551 P"banga"                                      ; set password
            M552 P192.168.2.1 S1                                   ; enable network and acquire dynamic address via DHCP
            M586 P0 S1                                         ; enable HTTP
            M586 P1 S1                                         ; enable FTP
            M586 P2 S1                                         ; enable Telnet
            M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
            M569 P0.5 S1                                       ; physical drive 0.5 goes forwards
            M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
            M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
            M584 X0.2 Y0.5 Z0.1 E0.0                           ; set drive mapping
            M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
            M92 M92 X401.08 Y100.20 Z4010.32 E932 ;E424.000                 ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z360.00 E1200.00            ; set maximum speeds (mm/min)
            M201 X1500.00 Y1500.00 Z250.00 E2000.00               ; set accelerations (mm/s^2)
            M906 X1500.00 Y1500.00 Z2400.00 E800.00 I80                       ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                            ; Set idle timeout
            M208 X-20 Y-20 Z-1 S1                                   ; set axis minima
            M208 X620 Y630 Z600 S0                             ; set axis maxima
            M574 X2 S1 P"io1.in"                               ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io1.in
            M574 Y1 S1 P"io4.in"                               ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io4.in
            M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
            M950 S0 C"io5.out"                                 ; create servo pin 0 for BLTouch
            M558 P9 C"io5.in" H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X43 Y38 Z2.5                              ; set Z probe trigger value, offset and trigger height
            M557 X15:615 Y15:585 S50                           ; define mesh grid
            M308 S0 P"temp1" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin temp1
            M950 H0 C"out2" T0                               ; create nozzle heater output on out1 and map it to sensor 1
            M307 H0 R1.180 K0.222:0.000 D6.51 E1.35 S1.00 B0 V24.1                                 ; disable bang-bang mode for heater  and set PWM limit
            M143 H0 S280                                       ; set temperature limit for heater 0 to 280C
            M950 F1 C"out7" Q500                               ; create fan 0 on pin out7 and set its frequency
            M106 P1 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
            M563 P0 S"out2" D0 H0 F0                             ; define tool 0
            G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
            G10 P0 R0 S220                                       ; set initial tool 0 active and standby temperatures to 0C
            ; Custom settings__________________________________________________
            ;M591 D0 P C"e0stop" S1							; Regular filament sensor for E0
            ;M591 D1 P1 C"e1stop" S1
            @3DGarage said in Duet V3 6hc stepper problems:
            I am unable to locate any videos on your public drive.
              @3DGarage For reference, here's a config.g (for Duet 2, RRF 3.4.5) published by Modix on GitHub. I'm not sure if it matches your printer, and it doesn't match your 6HC for sure.
              ; Modix Big-60 V2 to V3 upgrade, Electronics only system upgrade, Dual Printhead
              ; Configuration file for Duet WiFi (firmware version 3.4.5)
              ; Generated by Modix - Version 3.4.5 Config B
              global config_version = "Version 3.4.5 Config B"
              global generation = 2 ; Version 2 to version 3 printer
              global printhead = 0 ; Aero printhead
              global expansion = 0 ; no expansion board is installed
              global printheads = 2 ; Dual printhead, change this value to 1 to switch it to a single-printhead setup
              ; General preferences_________________________________________________________
              M555 P2 													; Set output to look like Marlin
              M575 P1 B57600 S1											; Set auxiliary serial port baud rate and require checksum (for PanelDue)
              ; Network_____________________________________________________________________
              M550 P"Big 60 V2 to V3"                      				; set printer name
              ;M551 P"MODIX3D"               								; Set password (optional)
              M98 P"config_networking.g"									; load networking settings
              G4 P300														; wait 300ms
              ;M552 P0.0.0.0												; Uncomment this command for using Duet Ethernet board
              ; Drives_________________________________________________________________________
              M569 P0 S1                                            		; Physical drive 0. X-Axis
              M569 P1 S0                                                 	; Physical drive 1. Y-Axis
              M569 P2 S0                                                  ; Physical drive 2. Z-Axis
              M569 P3 S0													; Physical drive 3. Primary Extruder
              M569 P4 S0													; Physical drive 4. Secondary Extruder
              ;Motor to stepper motor driver mapping_________________________________________________________
              M584 X0 Y1 Z2 E3:4 P3										; Driver mapping
              ;Settings_________________________________________________________
              M350 X16 Y16 Z16 E16:16 I1									; Configure microstepping with interpolation
              M92 X100 Y100 Z2000 E418.5:418.5							; Set steps per mm
              M566 X360 Y360 Z30 E3600:3600 P1							; Set maximum instantaneous speed changes (mm/min)
              M203 X9000 Y9000 Z200 E5000:5000							; Set maximum speeds (mm/min)
              M201 X1000 Y1000 Z200 E5000:5000							; Set accelerations (mm/s^2)
              M204 P500													; Set print and travel accelerations  (mm/s^2)
              M906 X1800 Y1800 E1000:1000 Z2300 I50						; Set motor currents (mA) and motor idle factor in per cent
              M84 S100													; Set idle timeout - 100 seconds
              M208 X0 Y0 Z-3 S1                               			; set axis minima
              M208 X600 Y600 Z600 S0                          			; set axis maxima
              M574 X1 S1 P"xstop"                            				; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
              M574 Y2 S1 P"ystop"                            				; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              M558 P9 C"zprobe.in" H5 F120 T6000 A1 R0.7					; BLTouch probing settings
              M950 S0 C"exp.heater3"										; set probe pin
              M376 H50			                						; Height (mm) over which to taper off the bed compensation
              G31 P500 X-14 Y21                         					; BLTouch X and Y offset from nozzle
              M557 X{move.axes[0].min + sensors.probes[0].offsets[0] + 1, move.axes[0].max + sensors.probes[0].offsets[0] - 1} Y{move.axes[1].min + sensors.probes[0].offsets[1] + 1, move.axes[1].max + sensors.probes[0].offsets[1] - 1} P10:10   						; define mesh grid
              M98 P"config_probe.g"										; Load the Z-offset from the config_probe.g file
              ; The Z_offset value is now set in config_probe.g, not in config.g
              ; Adjust the values there, do not adjust anything here.
              ; Heaters___________________________________________________________
              M140 H-1                                       				; disable heated bed (overrides default heater mapping)
              ;E0_________________________________________________________________
              M308 S0 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8   			; configure sensor 0 as thermistor on pin e0temp
              ;M308 S0 P"spi.cs1" Y"rtd-max31865"							; Configure sensor 0 as PT100 via the daughterboard
              ;M308 S0 P"e0temp" Y"pt1000"								; Configure sensor 0 as PT1000 on pin e0temp
              M950 H0 C"e0heat" T0                            			; create nozzle heater output on e0heat and map it to sensor 0
              M98 P"PID_tune_E0.g" R1										; PID calibration
              ; M307 is not used in this config. The M307 files are stored and executed from the PID_tune_E0.g file. You can verify the values there.
              M143 H0 S285                                    			; set temperature limit for heater 0 to 285C
              if {global.printheads} = 2
              	;E1_________________________________________________________________
              	M308 S1 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8   		; configure sensor 1 as thermistor on pin e1temp
              	;M308 S1 P"spi.cs2" Y"rtd-max31865"						; Configure sensor 1 as PT100 via the daughterboard
              	;M308 S1 P"e1temp" Y"pt1000"							; Configure sensor 1 as PT1000 on pin e1temp
              	M950 H1 C"e1heat" T1									; create nozzle heater output on e1heat and map it to sensor 1
              	M98 P"PID_tune_E1.g" R1									; PID calibration
              	; M307 is not used in this config. The M307 files are stored and executed from the PID_tune_E1.g file. You can verify the values there.
              	M143 H1 S285											; set temperature limit for heater 1 to 285C
              ; Fans & LED_________________________________________________________
              M950 F0 C"fan0" Q500										; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H-1 C"Primary blower fan"						; set fan 0 value.
              M950 F2 C"fan2" Q500										; create LED on pin fan2 and set its frequency
              M106 P2 S0 H-1 C"LED"										; Disable fan channel for LED
              	M950 F1 C"fan1" Q500									; create fan 1 on pin fan1 and set its frequency
              	M106 P1 S0 H-1 C"Secondary blower fan"					; set fan 1 value.
              ; Tools______________________________________________________________
              ;T0_________________________________________________________________
              M563 P0 S"E0 Primary" D0 H0 F0                  			; define tool 0
              G10 P0 R0 S210                                  			; set initial tool 0 active and standby temperatures to 0C
              	;T1_________________________________________________________________
              	M563 P1 S"E1 Secondary" D1 H1 F1						; define tool 1
              	G10 P1 X0 Y51.5 Z0										; set tool 1 axis offsets
              	G10 P1 R0 S210											; set initial tool 1 active and standby temperatures to 0C
              ; Automatic power saving____________________________________________
              M911 S22.5 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"  	; Set voltage thresholds and actions to run on power loss. Power Failure Pause
              ; Filament sensor settings__________________________________________________
              M591 D0 P1 C"e0stop" S1										; Regular filament sensor for E0
              M591 D1 P1 C"e1stop" S1										; Regular filament sensor for E1
              ; Add-on settings__________________________________________________
              ; Primary hotend Clog detector__________________________________________________
              ;M591 D0 P7 C"e0stop" S1 L3.2 E10 R10:300					; Clog Detector E0 [Add-On]
              ;Secondary hotend Clog detector__________________________________________________
              ;M591 D1 P7 C"e1stop" S1 L3.2 E10 R10:300					; Clog Detector E1 [Add-On]
              ; Crash detector__________________________________________________
              ;M950 J2 C"zstop" 											; create Input Pin 2 on Z-endstop to for M581 Command.
              ;M581 P2 T0 S0 R0											; Crash Detector   [Add-On]
              ; Emergency stop button__________________________________________________
              ;M950 J3 C"exp.e6stop" 										; create Input Pin 2 on pin E6 to for M581 Command.
              ;M581 P3 T0 S1 R0 											; Emergency stop [Add-On]
              ;M581 P3 T1 S1 R1											; Emergency stop, pause the print [Add-On]
              ;M581 P3 T1 S1 R0 											; Emergency stop, pause always [Add-On]
              A noticeable difference to your config is in the definition of the X endstop: according to Modix, it is positioned at the low end. In a first step, you need to verify this to match the printer's geometry.
              Apart from being quite elaborated, you may want to incorporate at least some of the values Modix has set for Accel, steps/mm, speed changes, axis limits etc. in your own config.g.
              EDIT: I was wrong with my assumption of the Modix being a CoreXY - please remove
              M669 K1
              from your config.
