    3.5 rc1 SBC Pause.g not executing
    Beta Firmware
    • nikschaundefined
      nikscha
      Hi all,
      pause.g is present but it's not running when I pause the print via the webinterface, the printhead just stops moving.
      M122: https://pastebin.com/ZXgpTmJX
      pause.g:
      echo "pausing..."
      G10.1             ; retract
      M98 P"CT_off.g"
      G91               ; use relative positioning
      G1 S2 Z10 F5000   ; lift Z 5mm
      G90               ; back to absolute positioning
      G1 X0 Y200 F50000 ; move out the way.
      running M98 P"pause.g" runs just fine.
      Stay in school
        RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1 (2023-08-31 16:19:24) running on Duet 3 MB6HC v1.01 (SBC mode)
        Is it pause.g or Pause.g?
        nikschaundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD
          What happens when you run
          M98 P"pause.g"
          If there is a problem with your G10.1.g macro or the other macro being called, then it might be aborting pause.g
          • nikschaundefined
            nikscha @OwenD
            @OwenD Running M98 P"pause.g" works just fine, the whole macro executes, so the problem is not in G10.1
            Stay in school
            • nikschaundefined
              nikscha @Phaedrux
              @Phaedrux it's "pause.g"
              Stay in school
              • Phaedruxundefined Phaedrux moved this topic from General Discussion
              • nikschaundefined
                nikscha
                I found the issue:
                I have another axis defined, which I don't use for normal printing.
                If this axis is not homed then pause.g isn't executed.
                Homing all axis solves my issue
                Stay in school
                • nikschaundefined nikscha has marked this topic as solved
