    Problem Closed Loop tuning plugin (DWC 3.5 RC1)
    256
    • kj3dundefined
      kj3d
      Problem installing Closed Loop tuning plugin (DWC 3.5 RC1 and DWC 3.4.6)
      Hi, It would be appreciated if anyone could throw any light on this.
      I have been able to install version 3.4 B1 (https://github.com/Duet3D/Closed-Loop-Plugin/releases/tag/v3.4-b1)
      If I remove that version and try to install a later version the installation fails.(The same message shows for https://github.com/Duet3D/Closed-Loop-Plugin/releases/tag/v3.5.0-b1
      https://github.com/Duet3D/Closed-Loop-Plugin/releases/tag/v3.5.0-beta.4
      I have tried this with DWC 3.5RC1 and DWC 3.4.6 installed on MB6HC (M122 shows the version installed and is as expected in both cases) In both cases it fails and shows these messages
      AND:
        jay_s_uk @kj3d
        @kj3d you need to have the newer version of DWC installed to use newer plugins
        kj3dundefined 1 Reply Last reply Reply Quote 0
        • kj3dundefined
          kj3d @jay_s_uk
          @jay_s_uk
          Hi, I have tried to use DWC 3.5 RC 1 - is that not the latest version?
            jay_s_uk @kj3d
            @kj3d they may be coded to a specific version. try DWC 3.5b4
            • kj3dundefined
              kj3d @jay_s_uk
              @jay_s_uk - I have tried it, sadly it does not work
                jay_s_uk @kj3d
                @kj3d strange. I'm running 3.5b4 on DWC 3.5-rc1. I would check again to make sure you've updated DWC
                • kj3dundefined
                  kj3d @jay_s_uk
                  @jay_s_uk - Just reinstalled 3.5RC1 and attempted to install plugin 3.5b4 (Powered down after install of3.RC1 and booted again)
                  I am uploading using the "upload system files" and "install plugin buttons", both methods give the same result
                  • kj3dundefined
                    kj3d @kj3d
                    But - General tab still shows it as DWC 3.4.6
                    • kj3dundefined
                      kj3d @kj3d
                      URIKA - I reloaded the DWC Web Control - SD file.zip and all sorted
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.0-rc.1/DuetWebControl-SD.zip
                      Thanks everyone for the help
