    Duet 2 v1.04c to v1.06 swap issues
    344
    • la_rdundefined
      la_rd
      The SD card slot on my Duet 2 wifi (revision 1.04c) seemingly failed after a few years, so I purchased a new duet 2 ethernet (revision 1.06). Swapped out the board, and kept the connections identical from before. Now when I try to home any of the axes, I get the message:
      Warning: Driver 1 warning: phase A may be disconnected, phase B may be disconnected
      The 3-D printer is a Voron 2.4, and I have a connected duex for the Z-axis. How can I fix this? Were the motor phases changed between board revisions?
      Thanks for the help.
      • la_rdundefined
        la_rd
        config.g
          Double check the crimps and connection. Try moving another motor to that driver and remapping and see if it still follows.
          la_rdundefined 1 Reply Last reply Reply Quote 0
          • la_rdundefined
            la_rd @Phaedrux
            @Phaedrux I have double checked the crimps and connection. After remapping to driver 4. The warning, as before showed up. This time I also saw both the A and B motor drivers warnings.
            Warning: Driver 0 warning: phase A may be disconnected, phase B may be disconnected
            Warning: Driver 4 warning: phase A may be disconnected, phase B may be disconnected
              Phaedrux Moderator @la_rd
              @la_rd said in Duet 2 v1.04c to v1.06 swap issues:
              How did you change the wiring and mapping exactly? Before it was driver 1 and now it's 0 and 4?
              If it was a problem with the driver itself the error would stick with the driver, but it seems to be following the motor?
              • la_rdundefined
                la_rd @Phaedrux
                @Phaedrux Hello, it is more like this issue:
                All drivers, including the Z-drivers on the Duex have been outputting this errors. It was fine before on my other duet2. M906 and M913 show that the proper current is allegedly outputting.
                When I try to home XY the AB motors error Screenshot 2023-10-01 at 10.32.43 PM.png
                And when I try to home the Z axis the Z-axis motors error.
                  dc42 administrators @la_rd
                  @la_rd which firmware version?
                  • la_rdundefined
                    la_rd @dc42
                    @dc42 the latest release: 3.4.6
                    I tried erasing with the jumper and fresh re-installing the firmware via SAMBa last night, to still receive the same errors.
                      Can you also try disconnecting the Duex? Do you also get the same errors? Can you send the output of M122? With and without the Duex?
