Updating 6HC with SBC to a specific version number.
Firmware installation
452
    techpriest.taro @droftarts
    @droftarts
    How do i find the list file?
    undefined 1 Reply Last reply 5 Oct 2023, 09:58 Reply Quote 0
      droftarts administrators @techpriest.taro
      @techpriest-taro It should be on your Raspberry Pi's SD card. How are you connecting to the Raspberry Pi? SSH or VNC from another computer, or do you have a keyboard or monitor attached? Connecting to your RPi is covered here https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup#h-5-accessing-the-sbc-through-sshvnc
      If using the RPi directly, or using VNC, you should be able to browse the RPi folder structure and find the .list file in /etc/apt/sources.list.d/.
      If using SSH, you'll need to use terminal commands to change directory to it, eg
      pi@duet3:~ $ cd /etc/apt/sources.list.d/
      pi@duet3:/etc/apt/sources.list.d $ ls
      duet3d.list raspi.list vscode.list
      pi@duet3:/etc/apt/sources.list.d $ cat duet3d.list
      deb https://pkg.duet3d.com/ stable armv7
      The 'cat' command shows the contents of the file.
      undefined 1 Reply Last reply 5 Oct 2023, 10:07 Reply Quote 0
        @droftarts I have setup with a monitor currently.
        The file says: "deb https://pkg.duet3d.com/ stable arm7" so it should update to 3.4.6? Because when i tried before it went straight to 3.5
        undefined 1 Reply Last reply 5 Oct 2023, 10:36 Reply Quote 0
          @techpriest-taro Are you sure? I've just updated my SBC, and it's updated DWC and DSF to 3.4.6.
          Note that if you have updated the Duet board separately to a different firmware, it won't automatically reflash the firmware. Send M997 to update/downgrade the Duet to 3.4.6.
          undefined 1 Reply Last reply 5 Oct 2023, 11:02 Reply Quote 0
            undefined 1 Reply Last reply 5 Oct 2023, 11:04 Reply Quote 0
              @techpriest-taro What DWC/DSF version is running? Like I said, if you send M997 it should update or downgrade the Duet firmware to the same version.
              undefined 1 Reply Last reply 5 Oct 2023, 11:12 Reply Quote 0
                undefined 1 Reply Last reply 5 Oct 2023, 11:16 Reply Quote 0
                  @techpriest-taro Well, that's weird. @chrishamm may need to help you with this one.
                  undefined 1 Reply Last reply 5 Oct 2023, 11:19 Reply Quote 0
                    @droftarts alright, thanks for the help so far 🙂
                    undefined 1 Reply Last reply 5 Oct 2023, 11:28 Reply Quote 0
                      @techpriest-taro How are you going back to 3.4.4? By re-imaging the SD card? Try re-downloading the SD card image, see https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup#h-1-flash-the-image-file
                        chrishamm administrators @techpriest.taro
                        @techpriest-taro You were on the unstable package feed so you need to downgrade the packages again to 3.4.6. See https://docs.duet3d.com/User_manual/Machine_configuration/DSF_RPi#downgrade-packages
                        Duet software engineer
                        undefined 1 Reply Last reply 5 Oct 2023, 11:35 Reply Quote 0
                          techpriest.taro @chrishamm
                          @chrishamm The guys i work with also want to test 3.5 so that is fine, we just need a 3.4.6 as well.
                          undefined undefined 2 Replies Last reply 6 Oct 2023, 09:40 Reply Quote 0
                            @techpriest-taro If you need 3.5, you can upgrade again using the unstable package feed but to use 3.4.6 you need to downgrade as outlined in the docs. Under normal cicrumstances it isn't possible to have two different package versions installed at once.
                              @techpriest-taro you could use two SD cards for the Pi, one with the stable feed (3.4.6) one with unstable feed (3.5). Swap as required. When you swap, run M997 to flash the appropriate firmware.
                              15 out of 19
