    Losing connection while trying to record motion profile
    • tomasfundefined
      tomasf
      I just installed the Duet3D accelerometer board, connected it to my Mini 5 and set it up with
      M955 P0 I64 C"spi.cs2+spi.cs1". So far so good, but when I try to Record Motion Profile, it moves to the correct Z height, stops, and after a couple of seconds, the board resets and I get Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin) followed by Connection to Duet established and Warning: SPI connection has been reset.
      The very first time I tried it, I did get results back (but with The selected motion profile contains overflows. It may not be accurate.), but every time since then, I get the reset.
      SBC mode. RRF 3.5.0-rc.1.
      Any ideas?
      • tomasfundefined
        tomasf
        I tried downgrading to RRF 3.4.6 to see if a stable version improved things, but it didn't help.
        • tomasfundefined
          tomasf
          Here's M122 after a reset if that could help:
          RepRapFirmware for Duet 3 Mini 5+ version 3.4.6 (2023-07-21 14:09:13) running on Duet 3 Mini5plus WiFi (SBC mode)
          Board ID: MPKT6-F396U-D65J0-40KM8-3A03Z-R0UUN
          Used output buffers: 1 of 40 (12 max)
          Static ram: 103712
          Dynamic ram: 99580 of which 24 recycled
          Never used RAM 38396, free system stack 206 words
          Tasks: ACCEL(notifyWait,0.0%,346) SBC(ready,1.3%,434) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,342) TMC(notifyWait,0.0%,124) MAIN(running,97.4%,557) IDLE(ready,0.5%,30) AIN(delaying,0.8%,273), total 100.0%
          Owned mutexes: HTTP(MAIN)
          Last reset 00:00:54 ago, cause: software
          Last software reset at 2023-10-12 17:23, reason: HeatTaskStuck, GCodes spinning, available RAM 38252, slot 1
          Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0000080f BFAR 0xe000ed38 SP 0x200134b0 Task ACCE Freestk 4294936825 ok
          Stack: 2001948c 20012e5c 200014e8 e000e000 000000a5 00091d55 000905a6 6100f000 00000001 e000e000 00091d55 20019074 000000c8 20019088 0008ac65 bd0ae633 00000005 3e638e37 20019074 00000005 00000006 200135a0 0008ae6d 20019074 20023ad8 20023a50 00027ac6
          Error status: 0x00
          MCU revision 3, ADC conversions started 54608, completed 54608, timed out 0, errs 0
          Step timer max interval 1489
          MCU temperature: min 28.8, current 29.1, max 29.8
          Supply voltage: min 1.3, current 1.3, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
          Events: 0 queued, 0 completed
          Driver 0: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 5: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 6: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2023-10-12 17:24:35
          Cache data hit count 129047879
          Slowest loop: 3.63ms; fastest: 0.08ms
          === Storage ===
          Free file entries: 10
          SD card 0 not detected, interface speed: 0.0MBytes/sec
          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === CAN ===
          Messages queued 489, received 0, lost 0, boc 0
          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 273/0/0
          Tx timeouts 0,0,272,0,0,215 last cancelled message type 4514 dest 127
          === SBC interface ===
          Transfer state: 5, failed transfers: 0, checksum errors: 0
          RX/TX seq numbers: 11189/2147
          SPI underruns 0, overruns 0
          State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x0f178
          Buffer RX/TX: 0/0-0, open files: 0
          === Duet Control Server ===
          Duet Control Server v3.4.6
          Code buffer space: 4096
          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
          Full transfers per second: 33.05, max time between full transfers: 95.2ms, max pin wait times: 34.0ms/2.5ms
          Codes per second: 0.49
          Maximum length of RX/TX data transfers: 3716/960
            What are you using for wiring?
            tomasfundefined 1 Reply Last reply Reply Quote 0
            • tomasfundefined
              tomasf @Phaedrux
              @Phaedrux It's the cable that came with the accelerometer.
                Perhaps @chrishamm has some ideas?
