Panel due or touch screen problem
PanelDue
1.7k
    vhoward
    Panel Due and 7" screen When I received my shipment fro Filastruder 3 months ago of my Duet Ethernet and the panel due and 7" screen, I plugged the panel due and screen in temporarily to check that it works. I unhooked it and put it away as I hadn't gotten around to printing a case for it. So yesterday I printed a case for it and today I put it together and mounted it and now the touch screen does not work. The screen comes on and I can read it, it just does not respond to touch. I have checked the ribbon cables and they are fulley seated and they are not broken anywhere. Anyone know why the touch part would quit working?
      vhoward
      I just saw the panel due section in the accessories and addons. Can a moderator move this there? Thanks.
        It's probably a fault on the TFT panel. The touch membrane ribbon cable is the small 4-conductor one.
          vhoward
          Is there a way to test what is bad? Everything looks visually good
            vhoward
            I don't know how long Filastruder will honor a warranty. I tested it when I first got it, but then it sat for 3 months and now the touch portion doesn't work. What should I get as replacement? Just the screen? Just the panel due? Both?
              The PanelDue controllers are very reliable, so I suggest you ask Filastruder for a replacement screen first - but they may want you to send both back so that they can see which part isn't working and replace it.
                vhoward
                I just sent Filastruder an email. I will see what they say. Thanks.
                  elmoret
                  Received the return, looks like the touch overlay itself is faulty. The electronics (LCD PCB and PanelDue) are all OK.
                  Will send a brand new LCD/touchscreen, with the same PanelDue as before.
                    vhoward
                    Thank you Filastruder for the quick turn around. I received my screen yesterday and it works fine.
                    1 out of 9
